Question about Acer Computers & Internet
When I try to use the at @ button the " sign comes up. How can I reconfigure my keyboard for the uk not us
  • james80 May 28, 2008
    Thanks very much I will sleep tonight that has been bugging me for ages @@@@@@@@@@@@@@@@@
  • 77 Answers
Go to Start > Settings > Control Panel > Regional and Language Settings.
In that Menu, you should be able to change the keyboard configuration to the proper one.
Chris
Posted on May 28, 2008
What happen to my keyboard? When i typing button '@', sign " will appear. And same situation when i typing button ", sign @ will appear. Look a like " and @ swap. -fairulazwan@gmail.com-
You are using wrong keyboard type.
Numeric button 2 has @ sing in USA Keyboard and in UK Style Keyboard Numeric Button 2 has ".
Dec 26, 2014 | Lenovo Keyboard
Tip
When I try to type the ampersand ( @ ) I get the quotation ( " ) sign instead
PROBLEM: Some keyboard characters type incorrectly and are swapped. Most notably the Ampersand - @ and the Quote sign - "
RESOLUTION: The wrong country selection for the keyboard layout has been selected. An ENGLISH - UK keyboard with an ENGLISH - USA keyboard type selected or the reverse.
Go to CONTROL PANEL, REGIONAL AND LANGUAGE settings and select the correct keyboard for your system's country of origin.
on Apr 08, 2010 | Computers & Internet
Function lock or something is on and i cannot turn it off. I need to use the "at" sign (shift #2) althouht the @ sign works here were i need it when i use shift2 it comes up as "
Seems like you have selected English (UK) as your default language. Change it back to English (US). If you don't know how, follow these steps.
You have not indicated what OS you have. I'll assume you have Windows XP.
Go to Control Panel.
Open 'Regional and Language settings'
Click the 'Language' tab and click 'Details' button.
Following screen will appear. Click 'Add' button and select English (US).
Select the newly added language as your default language from the combo box on top and click 'OK'.
Rate my solution if you find it helpful.
Good luck and thanks for using FixYa!
Sep 11, 2011 | Acer Aspire 5610-4648 Notebook
My @ symbol is stuck on the " sign. I do not have an ALT GRA key. I have an ALT CAR key and and ALT key but neither seems to help. I've tried hitting the Fn key and 2 at the same time but still no...
Sounds like your keyboard in in UK mode, but is labeled for US. Or the other way.
In a UK keyboard, Shift+' (the key which is two spaces to the right of "L") should give you an @ sign.
Depending on your Operating System, you can use the CONTROL PANEL and REGIONAL SETTINGS to set the keyboard to be a USA keyboard, and then Shift+2 will give you an @ sign.
http://en.wikipedia.org/wiki/Keyboard_layout is a good reference for keyboard layouts.
Apr 17, 2011 | Toshiba 310CDT Keyboard
@ and " keys are reversed! How can I reconfigure
Hi John,
The standard keyboard language and widely used setting is "ENGLISH (US)"
Set the Keyboard layout to English US so that you have standard keys for symbols etc. like @ sign with SHIFT+2 etc.
The keyboard layout / Language of your PC may have been changed, so follow these steps to select the International keyboard layout:
- Go to Control Panel - Region and Language settings
- On the Keyboards and Language tab, click Change keyboards.
- Click Add.
- Expand the language that you want. For example, English (United States).
- Expand Keyboard list, select the United States-International check box, and then click OK.
- In the Default input language list, click Language name - United States-International (where Language name is the language that you selected in step 4), and then click OK two times.
- In the Regional and Language Options dialog box, click OK.
Hope it helps! Good Luck!
CreativeTECH
Apr 14, 2011 | Compaq Keyboard
I recently bought ASUS U31F and i am having issues with @ function on keyboard. If i try to get @ working on numberpad on top using shift function system is returning " sign and if i press " sign...
Go to the control panel and look for the Region and Language option. Make sure the options on the Formats tab correspond to your location. Then go to the Keyboards and Languages tab and click the Change keyboards button. If a keyboard for your location and language is not shown, click Add and add it to the list. Remove any other keyboards that are shown that you do not use.
The problem is caused by Windows thinking you are using an American keyboard in the UK or the other way around. Changing the Region and Language options above should fix the problem.
Best of luck!
Mar 09, 2011 | AMD ASUS Barebones Turion/Mobile Sempron...
I just got a new desktop computer and i am having difficulties using the keyboard, i want to use the @ sign but when i press shift 2 i get " instead the @ sign is there to how do i use it ???
This sounds like you have the USA keyboard language installed, IF you are in the UK, then installing the UK language for the keyboard will sort this out.
Dec 30, 2010 | Acer NSK8458AN Keyboard
The pound sign has disappeared from my pc keyboard, also the@ has changed it`s position to number 2 position
try reconfiguring the international settings to uk, it may have beens et to USA which is how it is confiured
Nov 19, 2009 | HP DeskJet F380 All-In-One Printer
I purchased a Samsung NC-10 in the UK. Cannot type 'at' key
Go to...Start<>Control panel<>Regional and language options<>Languages tab<>Details button<>(if you have a netbook with a UK keyboard, ADD the UK keyboard) (if you have a netbook with a US keyboard, ADD the US keyboard)<>OK
Cheers, Frank
Mar 31, 2009 | Samsung NC10-14GW Notebook
When trying to type @ i get " when i push shift and ' on the samsung R60plus platop keyboard the ony way i get an @ sign is when i push shift and 2 is there something not set up right on the laptop...
Keyboard is set to US and not UK, under control panel, regional and language options, languages tab, details button, set default input language to english UK, you me need to add the language choice in the bottom section.
Jul 27, 2008 | Computers & Internet
Computers & Internet Logo
22 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
