Question about Sony FD Trinitron WEGA KV-32FS120 32" TV
Power light in front of tv not working and when i turn on the tv my stand by timer light flashes then goes out
  • 577 Answers
Sony TV has a feature that if this light for several times it means there is a malfunction in one of the board/circuits inside.
In fact the number of flashing describes exactly the problem board.
If you have an user manual please go look for the troubleshooting section to find out the problem.
If you do not have the manual please visit the below web site to download manual.
I am afraid that your TV may need to go to service unless you can repair yourself.
My Regards
http://esupport.sony.com/US/perl/model-documents.pl?mdl=KV32FS120&LOC=3
Manuals
Posted on Oct 06, 2010
Won't turn on.stand-by light flashes.timers are
my Sony trinitron kv-g21s2 TV not working . conned to the power blink in TV power indicator led
May 29, 2011 | Sony FD Trinitron WEGA KV-13FS100 13" TV
TV will not power up. Timer light continues to flash, will not reset.
You could have shook a fuse loose moving it ,,,or blew a fuse,,take the back off and check the fuses,,good luck ,,
Oct 06, 2008 | Mitsubishi WS-55859 55" Rear Projection...
Sony KP-41T65
is there a cadence to the blinking timer light?
Jul 17, 2009 | Sony KP-41T65 41" Rear Projection...
Sony Trinitron TV. No picture; red standby/timer light flashes.
My Sony trinitron has the stero lite on steady and standby lite flashes four times then pauses and repeats. Can you tell me the circuit/condition causing the set to not turn on.
Jul 15, 2009 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Cannot get tv out of stand by mode..
upon hitting the power button, the red light showing on the front of the tv should flash a couple of times, the screen should come on and the light goes off..the red "stand by " light stays on and we cannot get the screen to come up..needless to say, cannot get to the menu to change any display options...any suggestions?
Apr 10, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Tv tunrns on then goes to stand by flashes 4 times & repeats
turn tv on picture comes up 2to3 seconds later tv blacks out then stand by red light flashes 4 times in a row repeatedly..can not turn on or off when stand by light starts flashing but before tv blacks out you can turn tv on and off repeatedly and picture and sound work.You have to unplug power cord for 30 seconds after stand by light comes on to get tv to turn on.
Mar 13, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Tv wont turn on get audio then tv shuts off timer lite blinking
If TV stays in stand by with audio but no video, then common faults are the ballast board, or a fault on digital board.
If the led stays blinking , and tv turns off then the TV is on protect mode.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
Also ensure that the fault is not coming from a faulty receiver box sending bad signal, check if you get same problem with no receiver box or dvd connected.
If that does not work, and you keep having a flashing led on front of the TV, and tv turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible reasons.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , startingthe flashing light.
If you are in situation one, then theTV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occur are a blown capacitor on power board, a convergence IC has blown, or a fault on Digital board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
Dec 21, 2008 | Mitsubishi WD-62531 Projection Television
Timer light is flashing but tv wont turn on!
When the timer light stoped flashing the remote control would not turn on the TV. The next time the light quit flashing I held the power button in on the TV for about 5 seconds and it came on and has had no problems since then with the remote or the local TV power button.
Greg Allen
Aug 29, 2008 | Mitsubishi Televison & Video
Timer / Stand by light flashes
could be high voltage problem. time for your local repair shop.
May 27, 2006 | Sony KP-53HS10 TV
Sony FD Trinitron WEGA KV-32FS120 32" TV Logo
193 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
