Question about HP Pavilion a6600f Desktop PC
The video card on my motherboard no longer works when I put in the new card the in the PCI express slot the monitor still does not fire up, do I need to disable the one on the motherboard and how?
  • HP Master
  • 5,660 Answers
1) Computer off, unplug power to the computer. (Remove the power cord from the surge protector, Not from the back of the computer. {Power Supply)
2) Press the Power On button, and hold it in. Hold it in for a count of Five seconds. (Count, 1001, 1002, 1003, 1004, 1005)
Let go of the Power On button.
DO this procedure 2 more times.
(Imperative!)
What you are doing is clearing CMOS Error Codes, and resetting BIOS Setup back to the factory default settings.
Back to using Integrated Graphics again.
(By the way. The graphics 'engine' is the GPU.
Graphics Processing Unit.
http://en.wikipedia.org/wiki/GPU
Integrated Graphics is also referred to as OnBoard Graphics.
Meaning On the motherBoard.
The GPU is soldered to the motherboard.
A graphics card is also referred to as a Graphics Adapter Card.
(Or Video Card, or Video Adapter Card)
The GPU is soldered to the adapter card.
The adapter card is removable from the computer.
Integrated Graphics is not removable from the computer.
Hence it is not a Graphics Card.
Just wanted to clarify, in case you are referring to the Nvidia Geforce 7100 Integrated Graphics that is on the motherboard, or are indeed referring to a graphics card ]
Now plug the monitor cable into the VGA port, or DVI port, on the back of your Pavilion a6600f computer.
When Windows loads put the Installation Disk (CD) that came with the graphics card, into your optical drive.
(CD/DVD drive)
Load the software. If asked to restart your computer - NO!
Close all windows.
Shut your computer down normally. (Start>Turn Off Computer>Turn Off. Example is WinXP)
Unplug the power to your computer. Observe Anti-Static Precautions.
Anti-Static Precautions:
Your body carries Static electricity.
Static WILL fry out (Short Circuit) the hardware components inside a computer.
You may not even see it, or feel it. POOF!
Computer on a table, computer unplugged from power, computer case open.
TOUCH the metal frame of the open computer case.
If you leave your computer in the middle of working on it, upon your return be SURE to Touch the metal frame again
Plug the Monitor into the motherboard. (VGA or DVI)
Plug the computer into power.
WAIT 1 minute, turn the computer on.
Appreciate hearing the outcome of this. Post in a Comment.
If this doesn't do it, then yes, you'll have to go into the BIOS Setup Utility, and change from the motherboard setting to PCI Express.
To enter BIOS Setup:
As soon as you press the Power On button, start tapping on the F10 key. Tap in 2 second intervals. The beep you will hear is a Stuck Key beep.
You're supposed to press the F10 key as soon as the HP splash screen, (Logo) appears. problem is if you are not quick enough, the screen will go by, and you'll have to restart the computer, try again.
Tap the F10 key instead.
When you get to the blue, and gray screen of BIOS Setup, you cannot use your mouse cursor anymore.
Use the keys on your keyboard.
At the top of the BIOS Setup utility screen are the headings,
Main, Advanced, Power, Boot, and Exit.
Use the Right Arrow key to highlight Advanced.
You are now in the Advanced BIOS Options screen.
Use the Down Arrow key to highlight -
Primary Video Adapter
Press the Enter key.
(You are Not making any changes just yet. Just looking around)
A pop-out sub-menu will appear. Use the navigation key to highlight your choice. The Up or Down Arrow key is the navigation key here.
Select Item
Don't know what is offered with the a6600f.
Tell me if there isn't a logical choice available, that you would choose.
Suspect is will state Slot-Type for one of the choices.
This is what you want.
Once you have your choice highlighted, press the Enter key.
You now have to save your changes, or it will be like you have done nothing at all.
If there is a Y/N offered, press the y key. (It is not a capital Y. The capital Y is just shown for clarity)
Then press the Enter key.
You have now saved your changes.
If Yes/No is offered make sure you highlight Yes, then press the Enter key.
Exit to save changes.
Your computer should restart, and your graphics should work.
Posted on Oct 06, 2010
  • 68 Answers
When you install a compatible video card to your PC, it's automatically detected, and therefore, overrides the onboard video. Be sure that it's seated correctly else you'll encounter problems. Sometimes taking the card out and putting it back in fixes the problem. Also, be sure that your PSU (power supply unit) is capable of handling the new card. There are usually specs listed on the box which inform of the right amount of amp-age of the PSU required to match up with the video card.
Hope this helps. :)
Can i put 1gb video card to my RC410m-L
im in the car forum , why is this here?
i truly dont know....... but if true, answers will be hard to find.
that RC4 card is old and slow....
id computers too, and can answer.
the card you have , uses what is called a buss.
what you do is , read the mobo spec for you PC
and find which expansion slots you have.
then match the video card to that slot.
some E-machines (warmart junk) have no slot.
msi page, (home) shows
One PCI Express x 16 slot. (supports PCI Express Bus specification v1.0a compliant)
• One PCI Express x 1 slot. (supports PCI Express Bus specification v1.0a compliant)
• Two 32-bit v2.2 Master PCI bus slots. (support 3.3v/5v PCI bus interface)
so you have these slots.
find a video car that 1 one of those bus, connectors.
and if said video car , needs special, power connectors
your old power supply will not do that. its too old.
go to geek squad, they know the ropes.
ask them for options
better, ask and say why you need to change video on such
an old slow machine.?
Sep 13, 2013 | MSI RC410M-L Motherboard
How to add second monitor on ECS RS482-M
Doesn't work that way Max.
You can use EITHER the OnBoard Graphics,
OR;
the Add-On Card graphics. (Graphics card)
BIOS will NOT support both at the same time.
If you wish to use dual monitors, get an AGP card that has more than one graphics port on it.
For example, although I'm using a graphics card based on the PCI Express technology, and not AGP technology; my card has a VGA port, DVI port, and HDMI port.
1) VGA Connector; http://en.wikipedia.org/wiki/VGA_Connector
http://en.wikipedia.org/wiki/File:Male_VGA_connector.jpg
2) DVI; http://en.wikipedia.org/wiki/Digital_Visual_Interface
http://en.wikipedia.org/wiki/File:Dvi-cable.jpg
http://en.wikipedia.org/wiki/Digital_Visual_Interface#Connector
3) HDMI; http://en.wikipedia.org/wiki/HDMI
I use the VGA port, and the DVI port.
RCA EN-V L26HD31, (26 inch HDTV) to the VGA port.
HP 2009M 20 inch Widescreen monitor to the DVI port.
Had to install drivers for HP 2009M.
Let's say I had two DVI ports on the graphics card.
(ATI Radeon HD5450 is the graphics card I have)
But I have a monitor with a VGA cable, and a monitor with a DVI cable.
I would (And have) use a VGA to DVI Adapter.
One example,
http://www.directron.com/dvi.html
Note that the DVI is Male, and the VGA is Female.
The graphics card DVI connector is Female.
The VGA Cable connector is Male.
So.............what is the manufacturer name, and model number of the graphics card; plus what type of monitors are you trying to use?
That is, what type of monitor cables do they have?
Know this;
My HDTV I'm using as a monitor is Digital. However I'm using a VGA cable on it. Best quality would be achieved if I got off my lazy rear, and attached a DVI Cable to it. It uses both.
VGA is Analog. A computer however puts out a digital video signal.
The computer has to convert the digital video signal to an Analog one. This slows the video signal down, and the quality is not as good.
Best to use a digital monitor. (Or a digital monitor WITH a digital cable. DVI Cable. Such as I need to do)
You are also using a PCI Express graphics card, NOT an AGP graphics card.
I'm wrong? OK.
In the meantime turn the computer off, unplug from power, and yank that AGP card out of the slot you put it in.
Tell me what expansion slot on the motherboard you put it in.
The Orange expansion slot on the motherboard, is a PCI-Express x16 slot. Uses a PCI Express graphics card -> ONLY
The white expansions slots are PCI.
Can use a PCI graphics card. CANNOT use an AGP graphics card.
Post back in a Comment.
Regards,
joecoolvette
http://www.newegg.com/Product/Product.aspx?Item=N82E16814131338
Feb 18, 2013 | DFI 661GX-MLV SIS661GX CHIPSET SOCKET775...
ASUS m2n68-am se2 and graphic card's problem
Sounds like the PCI slot is no longer working.
Jan 10, 2013 | ASUS M2N68-AM SE2 Motherboard
Dual monitors t3516
Is it just like this with NO graphics card installed?
http://products.pacificgeek.com/emachines_t3516_celeron_d_3_20ghz_512mb_120gb_cdrw_dvd_xp_1013070674.php
If so, Not happening.
The I/O area is to the left side. (Input/Output area)
In this rectangular area you see;
1) PS/2 mouse port, and PS/2 keyboard port, at the top.
2) Orange port below them.
3) Black port below it.
4) Down below all of the above is the blue VGA port.
If you do not have a graphics card, your monitor is plugged into this blue VGA port.
If so you are using Integrated Graphics. Another term used is OnBoard graphics. ON the motherBOARD.
Do Not try to use a splitter cable, and run two monitors off of this VGA port. Ain't happening.
See the four long slots at the bottom of the computer? The bottom one has the Ethernet adapter card in it?
A graphics card, (Video card. Same/same), is installed on the motherboard, and the end of it sticks out one of those 3 unoccupied slots.
Each of those slots are known as Expansion Bay Slots.
When you choose what slot you want, you remove the Expansion Slot cover, for that slot.
My sources indicate the motherboard is an Intel D101GGC motherboard,
http://www.e4allupgraders.info/dir1/motherboards/socket775/D101GGC.shtml
There are 2 white PCI slots at the bottom.
There is 1 black PCI-Express x1 slot above them.
There is a longer black PCI-Express x16 slot above it.
The PCI-Express x16 slot is for a graphics card. It is the best graphics card slot on your motherboard.
(The white PCI slots are lame. The PCI-Express x1 slot, is NOT used for a graphics card)
Suggest you use a PCI Express graphics card for your computer, and run two monitors at the same time.
From here it depends on what the two monitors are. Do you have two monitors that use a VGA cable?
Example of a VGA cable, and a VGA connector,
http://en.wikipedia.org/wiki/VGA_connector
Or do you have a monitor that uses a VGA cable, and a monitor that uses a DVI cable?
Example of DVI connectors,
Or do you have one monitor with a VGA cable, and a monitor that has a DVI cable?
Post in a Comment as to the monitor manufacturer name, and model number.
[ For example I am using an HP 2009m (20 inch widescreen), and a 26 inch RCA EN-V HDTV, as dual monitors ]
This is an example of a very economical PCI Express graphics card, that will run dual monitors,
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130755
You can use a monitor with a VGA cable (Blue port), and a monitor with a DVI cable.
You can use two VGA monitors, with using a VGA to DVI adapter, for one of the monitors.
You can use two DVI monitors, with using a DVI to VGA adapter, for one of the monitors.
Already have a graphics card, and two monitors connected to it?
1) Right-click on an empty area of your desktop screen.
2) At the bottom of the list left-click on Properties.
3) In the Display Properties window, left-click on the Settings tab.
4) Left-click on the rectangular monitor icon, that has the 2 in it.
5) Go below to the left, and left-click on the empty square next to-
Extend my Windows desktop onto this monitor
6) Go below to the right, and left-click on Apply.
7) Go below to the left, and left-click on OK.
Your desktop screen is on your second monitor.
Need guidance past this post in a Comment.
Regards,
joecoolvette
Jun 09, 2012 | Computers & Internet
New motherboard GA-p67x-ud3-b3 no video on boot
  1. 1 x PCI Express x16 slot, running at x16 (PCIEX16)
    * For optimum performance, if only one PCI Express graphics card is to be installed, be sure to install it in the PCIEX16 slot.
  2. 1 x PCI Express x16 slot, running at x8 (PCIEX8)
    * The PCIEX8 slot shares bandwidth with the PCIEX16 slot. When the PCIEX8 slot is populated, the PCIEX16 slot will operate at up to x8 mode.
  3. 3 x PCI Express x1 slots
    (All PCI Express slots conform to PCI Express 2.0 standard.)
  4. 2 x PCI slots
Apr 29, 2012 | Gigabyte Computers & Internet
Hi Is there a PCI Express slot on the motherboard MSI K9VGM-V I see 2 PCI slots and another white slot above is this for a PCI Video card THANKS
On your MSI K9VGM-V, you do have a PCI-Express x16 slot, which is used for most video cards now days. You can see the full slot diagram on the picture below.
The one for the video card is labeled: PCI Express x16 Slot
Hope this helps. If it does, please accept and rate the solution! Contact me with any more questions you may have. Thanks for using FixYa!
May 24, 2011 | MSI K9VGM-V Motherboard
We have an emachine w3400 and need and new video card but don't know if it is PCI standard or PCI express how do i find out?
The eMachines W3400 desktop computer has an MSI MS-7145 motherboard.
(MSI = Micro Star International, Inc)
This is the MSI MS-7145 motherboard,
http://www.e4allupgraders.info/dir1/motherboards/socket754/msi7145.shtml
The MSI MS-7145 motherboard, has one PCI Express x16 expansion slot, which is used for a graphics card.
Viewing the bottom left of the photo, you will see three white PCI slots.
Right above them is a longer white slot.
This is a PCI Express x16, expansion slot.
Scrolling down to the subheading - Expansion Slots,
You will see - One PCI Express 16x slot, listed.
Should you require information in installing a PCI Express graphics card, or information on which PCI Express graphics card may fit your needs, state so in a Comment.
(Believe upper right of your page)
Jun 16, 2010 | E-Machines eMachines Desktop PC
Complience of motherboard and video card on new PC
remove the GFX and try onboard or try chainging ram slots...
Mar 14, 2009 | Evga e-GeForce 9800 GX2 DDR3 PCI-Express...
MSI k8ngm2-h mobo doesn't recognize PCI-E slot anymore!
Just a suggestion for you to try.
This is to check whether your PCI-E card is ok or not.
The BIOS setting option should be on PCI Express.
Take out the power cable from the hard disk - we don't want to mess around with window driver or system that might be the culprit.
Now turn on the computer, if ok, you should see some texts on your screen. This is a confirmation that your PCI-E card is still working. So then for you to work on your windows to solve the problem. Good luck.
Feb 18, 2008 | Intel Motherboard
HP Pavilion a6600f Desktop PC Logo
257 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
