Question about Skil 6267 04 5.5 Amp Keyless Drill
Can't remove the chuck from my Skil Mdl 6237, 3/8" drill. The jaws are locked open as far as they will go and I can't figure out how the chuck is attached to the drill.
Hi
1) check if the chock have a screw fasting it to the arbol if there is one you need to take it out and these crews are left hadle thred
try to fit a pic steel or tool in the chock and tap it hard clock wise then you can take off the screw after tacking off the screw put back the pic steel and tap it hard contra clock wise while holdng the drill and hoppfully it will be out.
Posted on Oct 07, 2010
Ryobi 12 volt drill/driver- cannot unlock the keyless chuck
replace the part you have taken out .
get a pair of stilson spanner adjust it so it goes around the chuck and do it and then it will ease off to do it up by hand
Sep 21, 2017 | Skil 2887 - 06 Factory - Reconditioned 18V...
The drill chuck is locked and not shifting forward or reverse
Check that there is not a reverse screw in the bottom of the chuck which has become loose. This can jam the chuck, screw it in (anti clockwise) or Spray inside with WD40, then use a large pair of grips to free it in both directions.
May 12, 2012 | Skil 6237-04 3/8 Corded Drill/ Driver
How do i take out a skil 12 volt battery drill bit. i havent used the drill in a year or so and i forgot please help, or not
Hi ladogers,
Welcome to fixya!
This drill has a keyless chuck. To remove the bit, just turn the chuck to the right (looking from the handle to the front) to open the jaws. To put in another bit, tighten the chuck to the left to close. You have to use both hands. You will see where the ridged portion of the chuck is in two sections. Hold on to the back section with your left hand to keep it from turning while you turn the front section with your right hand.
A lot of the time I just push the button to put the drill in reverse, hold on the front section of the chuck and turn it on. It will loosen by itself. Then when you put the new bit in, put it in forward and hold on to the chuck and press the switch. The bit will be in nice and tight.
Good luck,
Please place a vote when you accept this solution.
Thanks,
Handie Andie
Aug 16, 2011 | Skil 12 Volt Drill/Driver with Built In...
I have a skill 18v drill and the chuck jaws that hold the bit has one stuck down and two even, i have taken off the chuck but was wondering how to disassemble the chuck itself or if there is another way to...
Lube the chuck with some penetrating oil and bring the two loose jaws near the surface. Take a brass or soft hammer and pound the face. The stuck jaw should come down. They have a spring to push them down, but sometimes grits or other contamination causes them to stick.
Apr 26, 2011 | Next Generation Power Engineering Skil 18V...
How can i remove the chuck from my cordless dewalt power drill
Hello, W/D here.
To remove your chuck, open the jaws of the chuck fully, but don't open them so tight that they lock in the open position. Remove the screw inside the chuck. Spray the inside of the chuck with penetrating oil. Tap around the edge of the chuck, while pulling it away from the motor.
It should come right off, with a little effort.
Best regards, --W/D--
Feb 08, 2011 | Dewalt 18v Battery Hammer Drill Dcd950...
My drill chuck is defective,i want to know how to replace it
If the chuck will open far enough, reach in with a screwdriver and remove the retaining screw. If a key type, insert the key and tap the key in a CCW direction to loosen. If a keyless type, use 'Channel-lock' pliers and tap them lightly in a CCW direction. Reverse the operation with the new chuck. Good luck!
Mar 14, 2010 | Makita 12 Volt Cordless Drill/Driver Kit
Chuck jaws on Makita 8444D fell out
There is suppose to be a flat head Left hand thread chuck screw in there. It may have fallen out. You will not be able to put the jaws back into the chuck. You will have to replace the chuck with a new one. If you make sure that the chuck screw is not there you can remove the chuck with a couple of steps. Make sure the drill is in it's lowest gear. Use a strap wrench or some large vise grips on the chuck. If there is still one jaw in the chuck make sure it is all the way open and locking the collar to the chuck. The chuck will come off in the regular lefty loosey configuration. It may be stubborn. If this is the case, You may have to cut the collar off the chuck and use a pipe wrench. Or bring it to a professional to get it changed out.
Sep 23, 2009 | Makita 18 Volt Cordless Hammer Drill Kit ...
How do I change the chuck on a 5 amp skil drill. It is keyless.
If it's anything like their other drills, there is a safety screw with left-hand threads inside chuck.
  1. Turn it clockwise until loose.
  2. Then insert the short arm of a 3/8" hex wrench and tighten.
  3. Strike long arm of wrench sharply counter-clockwise and chuck should loosen to unthread from spindle.
Jun 06, 2009 | Skil 6237 04 5.0 Amp 3/8 Inch Keyless...
Jaws of my Hitachi 18V cordless drill are locked shut
Other than two quick squirts of WD40 and nice new chuck key?
Apr 07, 2009 | Hitachi 18V Lithium Ion Cordless Hammer...
Keyless chuck problem
I had the locking screw come loose in the center and bottom of the chuck it has a left hand thread and is a torx head . It had backed out and prevented the chuck from closing.
Mar 14, 2008 | Dewalt 18 Volt Compact Drill Kit
Skil 6267 04 5.5 Amp Keyless Drill Logo
202 people viewed this question
Top Skil Drills Experts
epangan29
Are you a Skil Drill Expert? Answer questions, earn points and help others
