Question about Kenmore Elite 45986 Front Load Washer
I am getting an error code that flashes F 06, what does that mean?
  • 5,911 Answers
"F6" is a Motor Speed error code. This is commonly attributed to either a broken or slipped drive belt, defective Drive Motor, bad Motor Control Unit (MCU), and/or the interconnecting wiring. The following link explains:
http://www.fixya.com/support/r3608706-f06_error_code
First, remove the back panel of the unit and make sure the drive belt is not broken, or has not slipped off the drum pulley.
Then, remove the top panel of the washer and check all the connector plugs between the Drive Motor, MCU and Central Control Unit (CCU). Check for loose connections and then unplug each connector and plug them back in (one at a time) to ensure they are snug and making good contact. The top panel comes off by removing the three screws that hold it in place in the rear of the washer. With the screws removed, the panel will slide back, then off.
NOTE: You only need to check the connectors that affect the drive motor and MCU circuitry.
The MCU has a tachometer mounted on it. If it is determined to be the cause of the problem, it is considered part of the MCU and cannot be replaced separately. The MCU is not serviceable and will require replacement.
Next, check the motor windings to ensure they are reading the proper resistance. Followed by continuity checks of all the interconnecting wiring between the drive motor, MCU and CCU. You should not need a service manual because each one of these washers comes with a technical data sheet.
For more in depth troubleshooting tips refer to your tech sheet located inside the washer behind the lower toe panel. You will need to locate and remove the screws under the bottom front edge of the toe panel. Once removed, the panel will drop down, then come off. If the tech sheet isn't located directly behind the panel, it will be affixed to one of the interior cabinet walls. The tech sheet includes all error codes, test points, diagnostic procedures and helpful illustrations to assist in troubleshooting and repair of your washer.
Replacement parts (if required) can be purchased at any of the following websites:
searspartrsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
Prices vary between sites, so shop and compare. The first three sites listed also have helpful exploded view parts illustrations to assist you with locating and properly identifying the parts you may need.
If you have any questions, or require additional assistance, please post back and let me know. I hope you find this information helpful.
Posted on Oct 06, 2010
Im getting error code f-06 what does this mean?
sorry but f-06 is not coming up as an error code for this model, if you can post up the full model number or product number illlook into it again
May 23, 2012 | Hotpoint Washing Machines
What is the error code 06 mean , every time i try to run the heater i get error code # 06 Please explain
It means you need to repeat the checks on fuel supply, thermal regulator, check for correct orifices, etc., per your owners manual. Check pages 42-43 for more information.
http://www.staritepool.com/pdfs/MaxETherm.pdf
John
May 06, 2011 | Sta Rite 333 Btu Natural Gas Heater...
My 632 is flashing EC 40. What is the problem?
Here's a list of all error codes for the 600-series Sub-Zeros.
http://fixitnow.com/wp/2006/06/29/error-codes-for-the-sub-zero-600-series-refrigerators/
EC40 = Excessive Freezer Compressor Run
Mar 24, 2011 | Sub-Zero 632 / S
My Kenmore Elite Calypso Model #110.24086200 SN #CR3808384 is not completing it's cycle and error code (06) shows up. What does code (06) mean?
Error codes start on page 46 and detailed instrustions to run diagnostics start on page 47.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/2c1e295a88aaaae885256c5d004632a4/$FILE/8178010.pdf
Mar 20, 2011 | Kenmore Washing Machines
What does it mean when the word "HOLD" appears blinking on my dashbord, I believe it has to do with the gears
Yes the HOLD light comes on when the computer detects a malfunction with the transmission....one quick flash of the hold light means a 01 code. six quick flashes would mean a 06 code. 5 long flashes would indicate a 50...6 long flashes would indicate a 60 code. Hope this helps.
Mar 14, 2010 | 1994 Mazda 929
F-06 error code
ck all wiring connections from motor to motor control to main control on top rear rail f06 means main control can't detect motor speed when you say mcu i assume you mean the motor control bd next to motor they and the motor both have given very few problems in our area i suspect the ccu (central control unit) is the most likely cause
Sep 19, 2008 | Whirlpool Duet GHW9150P Front Load Washer
42PF7320A/37
Replace X-tal (Viper) on SSB (item 1H00, order code: 2422 543 01397).
REMARKS:
- Error 5: Viper does not boot.
- Only a "reboot" is visible in the Debug menu.
- Error will appear after heating up of the xtal.
HISTORY:
23-03-'06: Chassis added. Text updated.
Jun 13, 2008 | Philips 42PF9630A 42 in. Plasma Television
Cd player
usually error 06 means a dirty lens cap, there for it cannot read the cd. try buying a cleaning disk
Aug 26, 2007 | Clarion DXZ365MP CD Player
Kenmore Elite 45986 Front Load Washer Logo
67 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
