Question about Toshiba e-STUDIO 352 Black and White Copier
It says that the both paper trays are empty, however they are not. I have removed the trays and there is nothing jammed, that i can see.
    Sniper:
  • 66 Answers
What has likely happened is your traylift motor/ gearbox has become damaged in some way. If both trays are gone you will likely have to replace the motor but there is a small chance that it just got unplugged. Take off the back covers and look for a beige coloured gearbox near the bottom of the copier. There is a Two wire black and red connector coming out of it, make sure it is connected to something.
Posted on Oct 07, 2010
My 8400 shows that Tray 2 is empty when it is not empty, and that the printer is suffering a paper jam when it is not suffering a paper jam.
Remove the paper, and look inside where the paper goes, if you see dust bunnies, remove them, clean the area really good, then try again.
Mar 26, 2013 | Office Equipment & Supplies
Tray is not feeding paper properly. Its making a weird clicking noise when paper is being fed. Paper gets jammed on most attempts.
Remove the paper tray and try to see some paper jammed somewhere around it. When pulling off paper jam. Just pull gently and slowly so that you can remove all and nothing left behind and doesn't damage the part when removing unwanted paper jam. Maybe it is the cartridge just repalce new cartridge if not the fuser drum maybe damage.
Dec 08, 2010 | Brother MFC-7820N Printer
Says Paper Jam but ther is no paper jam
It appear from here that the exit sensor may be dirty and you can use canned air and blow it out.
You may also be missing the paper out sensor that is located at the bottom of the printer oposite of the paper tray when you pull it out. When the flag arm has fallin out, it will give a false paper jam error when the last sheet has printed from the tray, not knowing or detecting that the tray is now empty.
Jul 02, 2009 | HP LaserJet 4 plus Printer
Hi I get this 250.07 paper jam check mp feeder on Lexmark t644
Please try this
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Jun 09, 2009 | Lexmark T644 Laser Printer
The paper feed jammed allowing some print/now says empty but not
Look at the paper path very carefully. There might be a piece of paper that got torn off and is either jammed up in the fuser or the registration assembly.
Jan 06, 2009 | Lexmark E232 Laser Printer
Hp psc 1315 paper jam
. Switch off the printer and disconnect the power supply. Allow any residual charge inside the all-in-one printer to dissipate before putting your hands or any metal tools inside the chassis.
2.
Pin down the exact location of the jam. The 3 hot spots for a jam are before a sheet completely leaves the paper tray, anywhere between the feed tray and print carriage or between the print carriage and output tray.
3.
Take off the front paper tray if the sheet jammed while still in the front area of the printer. If here, you should be able to see most of the paper.
4.
Pull the sheet with both hands and steady pressure. Do not tug as you might rip the paper, leaving a piece deeper inside the machine.
5.
Open the back panel to reach paper jammed between the feed-tray area and print carriage. Carefully remove the jammed paper.
6.
Use the carriage access door to get at a jam further inside the printer. You may need to remove the print carriage to get to the jam.
7.
Replace all parts and return any access panels to their closed and locked positions. Plug your printer back in and flip the power switch.
Jun 18, 2008 | HP PSC 1315 All-In-One InkJet Printer
Not printing, making me crazy
A paper jam has occurred. To solve the
problem, see “Clearing Paper Jams” on
page 6.3.
• The front or top cover is opened. Close the
front or top cover.
• There is no paper in the tray. Load paper
in the tray.
• The waste toner container is not
installed or full. Check the container.
• Your system has some problems. If this
problem occurs, contact your service
representative.
  • Also i can indicate that the Toner Cartridges are empty and need replaced with Genuine Samsung Cartridges
Jun 17, 2008 | Samsung CLP 300 Laser Printer
Toshiba e-STUDIO 352 Black and White Copier Logo
120 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
