Question about Belkin Wireless G Plus MIMO (F5D9230-4) Router (1010835)
Have been having problems today with the router i have disconnected and reconnected it
    Novelist:
  • 125 Answers
Hi clarke,
May I know the version number of the router plz so that i can give you clear idea.
Thanks,
Prema
Posted on Oct 06, 2010
Why does my acer aspire 5315 wifi keep disconnecting and reconnecting?
hello sir.
Reason :-
1.Make sure your acer aspire is in range.
2.cheack is it your wireless disconnecting and reconnecting or is it your internet disconnecting and reconnecting.
3.Are you facing this issue with any other machine or is this the only one.
If this is the only computer in which your wifi connection is dropping then there is issue with wireless connectivity.
solution:-
1.Turn of your router and modem and then check the wireless connectivity.
If issue still persist then:-
2.Create a new network name and wireless security key and then connect to it:- Now check the wireless stability whether is it still disconnecting an reconnecting or is it stable now.
If issue still persist then bright your laptop close to router and then check wifi disconnecting any more or not if not then change the channel to 1 or 11 from your wireless router page.
Let me know if this worked for you or not.
If worked then please rate my solution.
May 25, 2012 | Acer Aspire 5315 Notebook
Comcast ipad wifi problem
I'm sure you've done this but try turning off wifi on iPad and then turning back on. Does your wifi name show?
Jun 17, 2017 | Apple iPad 32 GB 3G Tablet PC
I have a d-link wrb-1310 router. i have gone through full installation but am getting a erro code 111. what can i do?
make sure your modem is disconnected power down the router wait 30 seconds and reconnect your modem. disconnect modem power and coaxial cable they need to refresh IP address and reconnect to each other might need to restart computer after modem and router boot up might take 4 min
Mar 02, 2011 | D-Link Computers & Internet
How to tell your net gear router is no longer working correctly It connects to the internet throuigh the modem I am plugged into port # 4 and I have tried port # 1. At any given time I loose connection and...
HI jamesbigble. To see if I understood your problem correctly. You are using a computer thru a router. And the router is connected to a modem. After a while all the lights on the router are lit. And then you have to unplug it and plug it in again and it will work for a while right? Well, if that's the case, that's the router for sure, you need to replace it. If you see something like that happening to the modem, well the same answer for the modem. If any modem, router or switch have all the lights lit, it means some serious problem. Maybe hardware/power or firmware issue. In case you dont want to spend money, I would recommend go to the netgear website and download the latest firmware for your router and try it. I hope this helps. Please dont forget to rate and write positive feedback for our fast-free support today. Thank you :D
Apr 30, 2010 | NetGear WIRELESS-G WGR614 802.11G WIRELESS...
Router has reset itself to jumpstart-p1 something
This may be a router at the what is call the "end-of -life and no longer serviceable.
You may have to go an get the latest router at your computer store.
Firmware may be obsolete for the connectivity.
Apr 24, 2010 | D-Link RangeBooster G WBR-2310 Wireless...
It worked fine last nite;came home today and it wont pull up the eweb or start or anything I click on? It said at one point I was not connected to any network;now it says am connected to Netgear network. I...
There are lots of possibilities here. The first thing is IF you are connected through a wireless network, Disconnect from the network. If you are networked directly into the Comcast modem, disconnect from the cable modem. If you disconnect from the network entirely and things seem to return to normal, then it is possible that you have a cable modem problem, a wireless router problem or someone has hacked into your network. The latter is most likely if you are running a wireless router and it is unsecured as this allows others to use your wireless network without your permission. If you disconnect from the network and things seem to improve only slightly, try running a virus scan while disconnected from the network and see what pops up. If anything has been downloaded to your computer a virus scan should find it. I would also recommend going in and making sure file sharing is turned off. If things seem okay after a virus scan, then try hooking back up to the network. If everything seems okay at that point, then most likely the cable modem or router are okay. If you still have a problem after reconnecting to the network try resetting the cable modem and the router. If you continue to have problems, I would call Comcast at that point and have them help you troubleshoot the cable modem to see if there is a problem with the modem.
Jan 06, 2010 | Acer Aspire 5500 5570-2609 Laptop
I cannot connect to internet with ps3 using belkin g plus mimo..
you might need to disconnect your modem for 30 secs then reconnect it . i have just reset my router and then the pc would show a connection but it only went to the router not through to the web.disconnect your modem reconnect then do a reconnect on the pc
Aug 21, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
I have to disconnect and reconnect my TEW-432BRP router
Hi! please try to download the firmware of your router the routers website and upgrade the routers firmware.possible is. the firmware is corrupted..
Jul 18, 2009 | Trendware TEW-452BRP Wireless Router...
Problem connecting to router
Log into the Belkin router and make sure that the DHCP services are running. If it is, and you still are not getting addresses, perform a factory reset of the router. There is a link in the web management console to do this.
Jun 22, 2009 | Toshiba Satellite Pro A200-EZ2204X...
Computer disconnects from wireless router
This could be a problem with the router. It sounds like there is a timeout that is not set properly. What is the make/model/serial # of the router? Who is your broadband provider? This information will help diagnose the problem further.
Nov 19, 2007 | Computers & Internet
Belkin Wireless G Plus MIMO (F5D9230-4) Router (1010835) Logo
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
