Question about Philips Audio Players & Recorders
Hi I am Looking for a manual for a philip Hi-Fi turntable is AK 591 Amp is F1395/65 The Six CD changer is AK 791/65 Can you help me please thank you
  • 55 Answers
Phillips Electronics was bought out by LG Electronics in China. You may check with LG
Posted on Oct 08, 2010
Changer keeps turning
It is likely worn drive belts. There are 2 within this hi-fi. I replaced my belts with elastic bands. No issues so far.
1) Remove power and unplug unit
2) Remove 4 x lid screws and lid
3) Remove both side panels.
4) Remove silver plate from shielding cd drive
5) Replace belts with 25mm diameter bands
6) Reverse the strip down.
New belts are $6 each on e-bay.
Jan 10, 2014 | Philips MC-70 CD Shelf System
Hi I have a Technics SCEH790 CD Shelf System, plus a pre amp phono stage for my turntable, I have had this working in the past as it was a friend who whirerd it all together, I have moved my hi fi to a...
PHONO PREamp. Does that suggest anything?
No picture necessary. YOU can see it. I can visualize.
Turntable to the Pre-amp IN. Preamp OUT to ANY available RCA input (usually AUX,).
Mar 22, 2011 | Technics SCEH790 CD Shelf System
Where can I get the "rubber band" that drives the
I think you are looking for tray loading belt as it is marked in below exploded view taken from service manual of CDP-C505
Belt part number is as follows:
492639901 ... Belt Square
It is available with PartStore.com for $5
Hope these info will help you, let me know if you need service manual copy.
Thanks.
Nov 27, 2010 | Sony CDP-C505 5-Disc CD Changer
Sound coming from speakers is very low.Turntable connected to a Sony home theater system has no jack for turntable. I have it plugged into the sat/tv/cd jack.
if there is no phono input on your home theatre amp, plug the turntable into the auxillary sockets and not the sat/tv/cd input as it wont work properly in that socket. if after putting the turntable into the auxillary socket it is still too quiet then you should purchase a specially made small pre-amp booster amplifier designed for turntables to inprove the signal to noise ratio from a reputable hi-fi shop/dealer. good luck
Sep 14, 2009 | Kenwood KD-291RC Turntable
Wont play dvd says enter pasword
Found this information on the Phillips USA website. http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?scy=US&slg=AEN&cat=DVD_HOME_THEATER_CA&sct=DVD_PLAYERS_SU&session=200906 This information is in the owners manual on page (45). I hope this information helps you with your problem You need to enter your six-digit
password to play a prohibited disc or if
prompted for a password. The same
default password is used for both
Parental and Disc Lock.
A In ‘Preference Page’, press 􀁓 􀁔 to select
{ Password }, then press 􀁘 to select
{ Change }.
B Press OK and the menu appears on the
TV screen.
Old Password
New Password
Confirm PWD
OK
C Use the alphanumeric keypad 0-9 to
enter the six-digit password.
􀃎 When doing this for the fi rst time,
enter the default password ‘136900’.
􀁺 If you forget your old six-digit password,
D Enter the new six-digit password.
E Enter the new six-digit password a
second time to confi rm.
􀃎 The new six-digit password will now
take effect.
F Press OK to confi rm.
Jun 01, 2009 | Philips BDP7200/37 Blu-Ray Player
Harmon Kardon FL8450 CD turntable won't turn...
check your belt on drive, it might be broken.
Mar 20, 2009 | Sony CDP-CX300 CD Player
Panasonic sa-ak20 5 CD changer does not work
hi i heared about you cd changer problem. i have a same hi-fi system an i have the same problem. it seems it appears when you hit.move or turn upside down the cd changer. you can solve it by unscrewing the top of the hi-fi with a regullar screw there should be 5 screws on the back and 4 on the sideways after this take the top off by pulling it upwards then you should plug in the hi-fi at the outlet and try to change the cd if it doesn't work try seeing if any of the cd is stuck in there if it is try to push it with your fingers but watch your fingers and do not touch any metallic part if in doesnt work like this eithertray looking if the cd-reader is stuck in any way......try to free it with your fingers but watch your fingers too if it doesnt work try to contact me at :tavi0815@yahoo.com il help you with any sound-sistem problem :D ;)
Sep 07, 2008 | Audio Players & Recorders
Philips Magnavox Mini Hi Fi System
My FW14 MX 3701 CD Mini Hi Fi System will not play The CD stored in it.  The screen says DEF. Thanks.
May 16, 2008 | Audio Players & Recorders
No sound from turntable bought for our hi fi system
Most if not all turntables would need to be connected to a PHONO INput which is high impedance with a high gain pre-amplifier stage. It will not work when connected to an AUX, CD or any line level inputs. Alternately, if your amp does not have any Phono Inputs, you can feed the turntable output to a preamp which can then be connected to any any line level inputs. An example may be found here or here. Additionally, there are some turntables with a built-in preamp.
Hope this be of help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Jan 16, 2008 | Audio Players & Recorders
177 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
