Question about HP Vs17 17" LCD Flat Panel Monitor
Display goes dark after about 1 second after power up
    Master:
  • 388 Answers
Check all conections you may have a bent pin chek the mouse and keyboard conections as well.
Posted on Oct 06, 2010
Screen goes dark
Had this problem on a Philips 170X6 display. When switching on the LCD lighted a few seconds and then went dark. Other displays may have similar problems.
Cause= bad electrolytic capacitors in the power supply. Had to replace 4 x 470 µF/25V and 1 x 125 µF/25V.
(in many cases you will see trace of leakage or a bulged top)
Access is by removing 3 screws on the back and pulling of the front frame (which fits very tight). Then you can lift out the LCD and you will find the power supply on the back of it. Carefull, the mains section can have high voltages.
Sep 21, 2015 | Videoseven V7 R19W11 19 inch Monitor
Lg flatron w2353vp
make sure the 'VGA' lead is plugged in properly. if still dark turn up the brightness on the monitor. if still dark after that, go onto the computer settings and turn up the brightness on the display settings.
Hope this helps!!!
Feb 21, 2014 | Computers & Internet
When I turn monitor on, it stays on only 2 seconds, then goes dark. When I turn the monitor on, it lights for another two seconds, then goes dark. It is a MAG Innovision TCO 03 display. Thank you!
It could be two things. 1). The video card is set to a resolution the monitor does not support. 2). The monitor's power supply is bad. You can try to boot into rescue (or "safe") mode, and adjust the video card to a resolution the monitor supports. OR, power supplies usually go bad because capacitors bulge or otherwise go bad. Most monitor power supplies are hard to get, so people typically repair them. If you disassemble the monitor shell, you can see the power supply (where the AC cord goes). You can look at the metallic, cylindrical looking things with minus signs down one side, and if they look bulged on top, you can replace them. You can get replacements at mouser.com.
Mar 30, 2013 | Mag Innovision 19" LCD Flat-Panel Monitor...
My screen will not come on
Replace it with a new LCD Inverter, you can address the following issues:
Screen image, but the power light stays in
Dark display, but still readable
Flashing on and off of the screen between 1/2 to several seconds
The power indicator stays on, but no display and sound
Screen images, but LCD TV still has sound
Picture cycle on and off, as well as high-power LED lights
More information in: http://lcdinverter.info
Feb 26, 2013 | Archos 70 Internet Tablet
The screen goes dark. When U cycle the power switch off then on again the screen display returns for about 1 second then goes dark again. I would appreciate suggestions on what to do.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
May 21, 2010 | Samsung SyncMaster 174V 17" Flat Panel LCD...
Dell ADAMO 13 w/Vista 64 Random power failure...goes dead in 1 second. Battery fully charged. Happened with external power and when on battery. I have latest BIOS v6.0. I ran pre-boot diagnostics...
If the power totally fails (i.e. power is cut off, LEDs turn off, fans stop, ... etc), then this more likely to be because of a short circuit developing in a failing semiconductor component, or a power supply problem.
However, if the laptop is still running & only the display on its LCD is cut off but the laptop itself stays powered on, then your laptop might be experiencing a failing screen inverter board, a failing screen backlight lamp, or a failing LCD screen cable.
TYPICAL INVERTER FAILURE SYMPTOMS
1. When you turn on the laptop, the screen lights up for a short period of time and then goes dark. You still can see an image but it is very dark, almost invisible and definitely not usable. When you restart the laptop, the screen lights up and then goes dark again. The laptop works fine with an external monitor.
2. Your laptop turns on but the screen remains dark all the time. You still can see a very dim image outline. The laptop works fine with an external monitor.
3. The laptop screen works fine for hours or even days, but sometimes it goes very dark as it mentioned above. When you restart the laptop, the screen works fine again.
Inverter failure symptoms are very similar to backlight lamp failure symptoms and in most cases you cannot tell which one is causing the problem until you replace either the inverter board or the backlight lamp. From my personal experience, inverter boards fail more often than backlight lamps. If you have to guess, replace the inverter first.
Feb 07, 2010 | Office Equipment & Supplies
After working normally for several years, my Inspiron 1100 display went dark but will come on normally if I press Fn+CRT/LCD BUT ONLY FOR 1 OR 2 SECONDS then goes dark again. Tried holding F8 during...
there is a ribbon cable going from the lower [keyboard unit] to the upper unit [display] that has been going bad over time. or the display panel backlight is bad.. you might be able to save old betsy by taking her to a laptop shop and see what they can do..goodday
Nov 09, 2009 | Dell Inspiron 1100 Notebook
Powers up temporaly displays goes dark
Your monitor has a bad back light. Send it back to your friend
Nov 22, 2007 | BenQ T705 17" LCD Monitor
Monitor is on, goes light to dark in 1 second
I have the same problem with my Dell 17" monitor. I've been reading and what others with similar problems say is that the power supply has a bad capacitor.
Aug 08, 2007 | ViewSonic VE155b 15" LCD Monitor
HP Vs17 17" LCD Flat Panel Monitor Logo
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
