Question about Fisher and Paykel IWL12 Top Load Washer
Ran machine through diagnostic for drain pump. coil on pump was burnt up but operated for few seconds. lost all pwer display on machine. removed pump, verified malfunction of pump, purchased and installed new drain pump. reassembled machine, no power displayed on machine. circuit is good.WTF. "customer support" will only speak to "authorized repair center"
  • Fisher and P... Master
  • 713 Answers
Hi Adam just found your posting,Do you still need help?If you do reply back and I will help you rectify this fault.Looking forward to your reply.
Posted on Oct 10, 2010
The pump will operate for 5 to 10 seconds and stop. 2 or 3 minutes later it will pump again for a few seconds. It takes a long time to drain the machine.
Drain the machine. Then turn power is off at the wall socket. Then tip machine back against the wall as far as you can. Get down under front right of machine & remove the wires going to the drain pump. Next remove the drain pump by turning it 90 deg clockwise. There is a white clip near the top edge of pump on R.H. side - hold that out while you turn it. Once it is out check pump & up in the pump outlet hole for obstructions. Put pump back with wiring plug facing R.H.side of cabinet then rotate 90 deg anti clockwise. Re attach wires and stand machine up.
Jan 04, 2016 | Fisher and Paykel GWL11 Top Load Washer
Cabrio. Why does it stop during rinse cycle?
Possibly the pump has something clogging it and it takes too long for the water to drain out therefore causing the internal time to take too long. Remove pump and see if its clogged.
Jul 26, 2015 | Whirlpool Washing Machines
Washer will not run or complete a diagnostic.
1. The washing machine needs to be plugged in and in stand by mode with all indicators off.
2. Choose any one button on the washer's console except Power, Start, or Stop. Press/Hold 3 Seconds - Release 3 Seconds - Press/Hold 3 Seconds - Release 3 Seconds - Press/Hold 3 Seconds.
3. If the diagnostic test mode has been successfully entered, all of the indicator lights will glow for five seconds with 88 on the time display. (If it didn't work try #2 again One one thousand...Two one thousand...Three one thousand)
4. If there are any saved fault codes they will be displayed. If there are no save fault codes all indicator lights will turn off for a moment then back on with 88 displayed and the automatic diagnostic test mode will begin in five seconds.
5. If you are unable to enter the diagnostic test mode, press the power button and verify that the button you were trying to use operates properly to program the washer's cycle function. There may be something wrong with that function button. Find another button on the control that appears to work and try to enter the diagnostic mode with that button. You may also want to verify that the user interface has a good connection to the washing machine control board at the P11 terminal.
Back to Top
Note: Pressing the STOP or POWER button at any time to exit the washing machine's diagnostic mode.
Mar 14, 2015 | Kenmore Washing Machines
Whirlpool Cabrio won't drain or only intermittently with LD code
Sound like there were threads wrapped around the impeller shaft inside the pump. Matter of fact I just replaced a pump for a client cause a nickel had gotten inside the pump and got between the impeller and outer casing. The nickel punched a hole in the housing of the pump therefore causing a leak. Couldn't get just the housing. Had to get the whole pump.
But it sound like the drain pump is under a lot of strain and probably needs to be replaced. Strain from threads around the impeller shaft or something else. So the pump motor gets hot from stress and strain causing the coil to heat up and short out causing an electrical smell. I found used pumps very reasonable for this unit on ebay.
Apr 07, 2014 | Whirlpool Cabrio WTW6600SBT Top Load...
Fisher and paykel gwl15 wont completely drain
Also check the clear pressure tube for blockages,
Blow air down the pressure tube to remove any blockages
that would prevent water level from changing.
Jan 02, 2012 | Fisher Paykel EcoSmart GWL15
Washer displays Ld and won't drain. won't restart or anything. kenmore oasis
The LD fault code indicates that the washer took longer than 5 minutes to pump out the water and reset the water level pressure switch. You should be able to press STOP/CANCEL to clear the display.
Check you drain hose for kinks or clogs. You could have a clog or failure in the drain pump that is causing this problem.
You can use a diagnostic test to start the drain pump. To start this diagnostic test, press the following keys in this order: SET DELAY TIME, END OF CYCLE SIGNAL, SET DELAY TIME, END OF CYCLE SIGNAL. The display should show "dt" after this key dance. Press the JEANS/COLORS key to start a 60 rpm spin and drain test that will terminate after 40 seconds. Listen for the drain pump. It should be running during this test. Also listen for unusual noises from the pump that could indicate that it is clogged. You may be able to drain the water from the washer using this diagnostic cycle depending on the severity of the clog or failure. If not, you may need to manually remove the water. If you are able to safely access and clear a clog in the drain pump or drain line, you may be able to repair this problem yourself.
Jan 07, 2011 | Kenmore Washing Machines
Water pump failure?
The water pump drain motor has something stuck in it or it has gone bad like most LG parts.
Remove the drain pump and look for any foreign object to be removed.
Check the drain pump for a failed pump motor.
LG is pretty.
Feb 02, 2010 | LG WD-3274RHD Front Load Washer / Dryer
Kenmore Elite Oasis HE washer error code F2
The error code must be cleared first to make the machine back into operation. You have to press the PAUSE/CANCEL button twice to clear the error on the display.
The only filter the machine has is the one you removed to clean the pump. When the error is cleared, you can check the pump whether it is operating properly or not by running the diagnostic test.
Diagnostic Test Mode Procedure
  1. Close the door.
  2. Select the DRAIN/SPIN.
  3. Select NO SPIN by pressing the SPIN SELECT button.
  4. Press RINSE/HOLD or PREWASH OPTION button four times within five seconds.
  5. "C:00" will show on the display indicating that the door is locked and the diagnostic test starts.
  6. Press the button you pressed in step 4 above two times. "C:01" will show on the display and the machine starts to fill.
  7. Press PAUSE/CANCEL button two times when there's enough water inside the tub to stop the test.
  8. Observe the water level falls as the pump starts draining the water. Replace the pump if the water inside the tub does not drain. You have removed and cleaned the pump so you can easily replace it too.
Please inform me about the result of the diagnostic test and if you still need any assistance regarding this problem.
Jan 20, 2010 | Washing Machines
Front load waher will not drain
Hi, your washer water pump, could be burnt out, or clogged up, but first check drain hose for kink, remove back of machine, locate water pump, device that your drain hose are connected to, remove all hoses, pump from washer, and clean, sometimes foreign objects get into it, and prevent pump impeller from spinning, also check water pump winding (coil) with ohm tester, place tester lead, one on each terminal on pump (motor) if you hear beep sound, pump motor o/k, if not, pump burnt out, replace it, but first remove pump, and clean it. after cleaning replace pump, try machine. you could put drain hose, close to floor, into buck, and water will empty by gravity, if water is not emptying, that's evidence your water pump is block, small object (handkerchief, coins etc.) gets into them, from time to time, first clean your water pump, `and check for kink, in drain hoses. . always disconnect power, before attempting any repairs. good luck.
Aug 13, 2009 | Frigidaire ATF6000ES Front Load Washer
Fisher and Paykel IWL12 Top Load Washer Logo
52 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
