Question about RTO PasLode 900420 Impulse Framing Nailer
My paslode framer only shoots 10d nails half way
Idaho_Biker
  • 32 Answers
SOURCE: Paslode framing nailer loss of power.
Here's what I found at the Paslode Troubleshooting Site:
Tool will not cycle - fan runs, indicator light
is solid green.
Lockout bracket is stuck in lockout position.
Work-contacting element is bent, or build-up of
debris in track restricts operation.
Follower is not behind fasteners.
Fuel Cell empty.
Spark wire out of spark plug.
Spark plug is dirty.
No spark is generated.
Check lockout.
Remove and inspect lower probe. Clean and
lubricate track with Paslode Impulse® oil.
Repair or replace lower probe as required.
Position follower behind fasteners.
Replace fuel cell.
Remove cap and check spark lead, insert in
spark plug and replace cover.
Clean tool cylinder head and spark plug.
If this doesn't work, I suggest contacting Paslode directly 800-222-6990
Posted on Mar 27, 2009
  • 14 Answers
SOURCE: nail gun
have you activated the fuel cell by pressing the black nozzle down onto the cylinder?
Posted on Aug 04, 2009
rowdy45176
  • 2176 Answers
SOURCE: Paslode cordless nail gun which way does the
chamfer side goes towards the nails/magazine
Posted on Aug 18, 2009
  • 55 Answers
SOURCE: Brand New Paslode 900420, I bought the red gas,
Also try and check whether or not the slide where you insert the nails that you push the button down that way it is pushing the nails forward
Posted on Dec 02, 2009
rsmith972278
  • 160 Answers
SOURCE: how to load nails in the paslode f350s framer
Hi, I found you a free owners manual for your model. Click on the link below and save or print.
http://www.paslode.com/uploadedFiles/pneumatic_ops_manual.pd f
Hope this Helps, RSMITH972278 P.S. PLEASE RATE MY ASSISTANCE
Posted on Dec 29, 2009
Paslode 900600 Trim nailer not sinking nails
The firing pin can be completed or part of it crooked worn and can have a little burr on its way and stuck in the cylinder somewhere o-rings worn and hardened, have a tilting piston on the firing pin somewhere in the cilinder
Jul 27, 2017 | Air Tools & Compressors
Just cleaned gun, shot about 300 nails, and wont shoot nails anymore, all within 2hrs.
wow 300 nails in an hour for this gun is alot. I am a professional framer and would not recomend this gun for that kind of use. The only time I use the pasload is when I have a small punch list. Not sure how old your gun is or how long you have been using it under that much of a load, but my guess is you may have burnt it up. The only real answer for these guns is to take them to a qulified repair person.
Mar 03, 2010 | RTO PasLode 900420 Impulse Framing Nailer
How to load nails in the paslode f350s framer purchased a used nailer now trying to figure out how to load the nails
Dec 29, 2009 | RTO PasLode 900420 Impulse Framing Nailer
Cleaned impulse framer 900420 put in new fule
If this is a framer there isn't a lockout for it. you would need to pull the front assembly to remove a jammed nail or look for problem.
Oct 20, 2009 | RTO PasLode 900420 Impulse Framing Nailer
I have a paslode nail framer 900600. the problem i have is the same after 3 exchanges. The gun will stop firing. i have oiled it, replaced gas,etc. the hammer simply will not come down to force the nail...
It may be as simple as making sure the spark plug lead is in the spark unit all the way.( Black box in the handle). Good Luck!! If you get stuck call Adelaide Nail Gun Repairs. They may be able to help you over the phone.
Oct 11, 2009 | RTO Paslode 902000 IM250 Ii Cordless 16...
Paslode air framer not sinking some nails
Your air pressure is dropping everytime you fire. It sound like your compressor is not cutting back in untill it to low. Not giving your tool enough continuess pressure. Your compressor cut in pressure should be around 90-100psi no less. and your max. pressure no more then 120psi. (Make sure your regulator is set at 110psi)
good luck...!
Aug 11, 2009 | RTO Paslode #650027 2500CT Placement Nail
Nail gun
Jul 27, 2009 | RTO PasLode 900420 Impulse Framing Nailer
Firing pin not retracting far enough to allow nails forward
Yes,this is a common "mis fire" by Pasilode. I own the 16p Framer and the Angle nailer and I never get it from the Framer but I do get it seldom from Trim Gun,nothing you can do ,its just a misfire.
Please rate jj505
Mar 20, 2009 | RTO Paslode 902000 IM250 Ii Cordless 16...
Nail size
Hi, No you can't, it is generally a metal framer and the nail size is up to 2 1/2 x .131 , .148, or .162. Hope this Fixsya!
Feb 24, 2009 | Tools & Hardware - Others
RTO PasLode 900420 Impulse Framing Nailer  Logo
57 people viewed this question
Top RTO Air Tools & Compressors Experts
yoopertech
John Trevino
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a RTO Air Tool and Compressor Expert? Answer questions, earn points and help others
