Question about Seagate Hard Drive SCSI 73GB 10000RPM 3 year computergiants warranty not M/F drives (73.4GB) U32... (ST373307LW3)
The computer is heng not - Seagate Hard Drive SCSI 73GB 10000RPM 3 year computergiants warranty not M/F drives (73.4GB) U32... (ST373307LW3)
  • Seagate Master
  • 27,725 Answers
If you mean your computer is hanging
try uninstalling a few unnecessary programs then click start run type cmd then type chkdsk/r/f which will fix any bad sectors and automatically fix any corrupt files on your hard drive then defragment your hard drive
good luck with this
Posted on Oct 06, 2010
Jia heng lighter watch parts and configuration of components?
Jia Heng Butane Lighter Watch Battery Replacement
The battery replacement for the Jia Heng Butane Lighter Watch is fairly easy. The clock face actually gets removed from the lighter body. The only tools you will need are jewelers Phillips and slotted screwdrivers; Phillips and slotted.
Remove band by compressing spring pin with slotted screwdriver by pushing in the pin. These are standard watch band pins.Remove back 4 screws to remove backThe clock face is help on by 2 screws removed from the open back, there are at the 11 and 4 o'clock orientation when looking at the back.The front will drop off.Remove the plastic alignment spacer.Replace the 377 button battery.Put it back together by reversing the process.
Attached pictures
Front
Back
Clock face screws
Plastic alignment spacer
Battery placement
Oct 02, 2016 | Watches
We need to replace drivers door on 1987 chevy s10 and can find only 1 bolt. What all needs removed to replace door?
the door henges are welded on the s10 you will need to remove the henge pins in order to remove the door, get some help! it will take 2 of you to get the door off and a floor jack helps a lot. you can get a tool called a pin popper and i recomend you do it makes the job much eazer, and the tool kit comes with the procdeger to remove the pins, when reinstalling the door replace the pins and bushings they come as a kit and can be bought at almost any auto parts store......good luck
Jul 06, 2011 | Chevrolet S 10 Cars & Trucks
How to remove doors of a whirlpool 6vmw47 top mount fridge/freezer
Hello Hicherringto,
I understand that you would like instructions on how to remove the doors on your fridge. Most common on top mount freezers/fridges you need to start at the top and work your way down.
1. Locate the freezer hinge top part where the door swings.
2. Remove the plastic cover over the henge. (top of the box if covered)
3. Remove the screws holding the henge in place.
4. Lift up on the henge
5. Open the freezer door and lift up (the door should lift off the bottom pin)
6. Open the Fridge door and remove the screws from the hinge that the freezer door sat on
7. Remove the hinge from the fridge door by lifting up
8. Open and lift up on the fridge door
9.Reinstall in reverse
That is the easiest way to remove the doors on a top mount freezer fridge. Note that when you reinstall the doors you will have to adjust the hinges so that the seals seal properly. The hinges have enough of a grove that you use them to adjust the doors.
Thank you for choosing FIxYa.com
Justin
Apr 16, 2011 | Whirlpool Refrigerators
Windows xp not install heng problwm more restart
try uninstalling a few unnecessary programs then click start run type cmd then type chkdsk/r/f which will scan for and attempt to fix any bad sectors and automatically fix any corrupt files on your hard drive then defragment your hard drive
hope this helps
Nov 24, 2010 | Hitachi Deskstar® T7K250 160 GB SATA Hard...
To replace door hindge
Hinges rarely go bad the inserts in the door (plastic) and the plastic washers that allow the door to gluide on the henges and line it up wear out. You can get the plastic washers at most hardware stores. Any local mom and pop repair/retailer of appliances or Marcone in St. Louis Missouri. What problem are you having with your henges?
Aug 15, 2010 | Refrigerators
Getting heng frequently while attending incoming call
hi try formatting it hope it will solve it just switch off phone and then press green and red switch together and then while pressing this just switch it on your phone will get formated and if you are using memory card free 15 to 20 % of memory of its card the phone will get formated so do take backup.
regards aniruddh
May 28, 2010 | HTC Touch Diamond Smartphone
Kalu heng tu masalnya pa,,,,,ya... hp nokia52000
Memory terlalu besar bisa,atau masang apikasi yg ga sesuai,maen game terlalu lama atau bisa juga virus.umumnya sih kepenuhaan memory,usahakan sisakan 25% dari kapasitas max mmc.moga membantu.
Apr 18, 2010 | Nokia 5200 Cellular Phone
Take off freezer door
Why don't you just take off the handles? That is what we did and it worked just fine.
Oct 07, 2008 | LG LRSC26940ST 36" Side-by-Side...
Computers & Internet Logo
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Computer Links
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
