Question about Meade LXD55 Telescope
I dropped by LXD -55 autostar handcontroller and now the display won't light up and if it does the backlight is so low I can't read it. Can it be saved or do I have to buy a replacement?
  • 3,186 Answers
Buy a replacement, You broke something inside the hand controller. Possibly the screen ribbon cable was jarred loose a little. After you get the new hand controller, carefully open up the hand controller and make sure the internal cables are all secure.
Posted on Oct 06, 2010
I have an lxd 75 goto mount. When I align on a star the ra motor skews to infinity and registers a motor fault. It skews just fine from the hand controller but when I try to align during setup it goes...
most probably has a faulty shaft encoder on the ra motor. If the encoder is working correctly the fault will lye in the H-Bridge circuit that drives the motor or if you're really unlucky, further up the signal path from the detectors
Sep 06, 2013 | Coronado LXD75 Mount and Tripod with...
55" westinghouse vr-5525z Sound but no picture
Check its back-light inverter board and back-light CCFL lamps. If you wish to get more details, check the site linked below. Pull up older posts there. Check the site with patience, as it has over 2400 posts now. All are related to electronic equipment repair help. If you search the site in Timeslide option, which can be selected from the drop down list at the top left of the display window, it will be easy to locate the related post. You can also do a search by type in the brand name to your device into its search box at the top right of display window. http://electronicshelponline.blogspot.com/
May 02, 2013 | Westinghouse 55" 1080p 120hz LCD HDTV -...
Display problems on hand controller display screen
Best bet (and cheapest) would be to get a new cable for the controller. They are made with thin telephone wires and break easily. If that does not fix it, you need to buy a new controller.
Dec 20, 2011 | Meade LXD-55 Telescope
Hi guys my telescope will only move up and down in the asention. it will not move left or right and motor fault scrolls across the controler. its a lxd55. can you advise me please.
Are you using a separate 12 volt power pack? which you should use.
Change the batteries to fresh ones. Turn the scope on and do a Calibrate Motors.
This adjusts the motors for the electric voltage being used. Your scope will go crazy when the batteries drop to about 60% of charge. That's why a separate 12 amp hour 12 volt power pack is preferred.
Jan 05, 2011 | Meade LXD-55 Telescope
I changed the batterys in my 1F78-151 thermostat and now the backlite does not work.....
• Display Backlight - (Not available on earlier models.) The display backlight improves display contrast in low lighting conditions. Selecting backlight ON will turn the light on for a short period of time after any button is pressed. Selecting backlight OFF (default) will keep the light off. Turn the display backlight feature ON as follows: 1. Press TIME and RUN buttons at the same time. The display will show "d-L" and "OFF" alternately
Dec 22, 2010 | Heating & Cooling
Etx-ls update to 1.2g failed, how to i restore or try the update again the autostar iii handbox does nothing
Easy.
If the firmware in your Autostar crashes and you cannot access the "DOWNLOAD" menu item on your handbox, you can use the "SAFE LOADER" feature of your new Autostar software. To get into the safe loader, follow these simple steps: 1. Make sure the Autostar and ETX are turned off.
2. Press and hold the "ENTER" key and the Scroll Down Key located to the right of the help key on the Autostar handbox.
3. While depressing both keys, turn on your Autostar power switch. This will require you using both hands.
You should see "FLASH LOAD READY" on your display. This indicates that you can proceed to Update new software to your Autostar.
Oct 08, 2009 | Meade Optics
My scope goes to everything from the meridian to the west, but will not center on things to east.
Scope is going to do a meridian FLIP-- during the "flip" the gotos can get off a bit-- just center a star on the other side of the flip and SYNC on it using the handcontroller.
Mar 09, 2009 | Meade LXD-55 Telescope
Meade autostar hand unit fails after 2 seconds changed hand units
Does the Autostar start to come on then fail, ie you get the bleep and initial display, then nothing more? If so, it sounds like it is not completely blown.
I wonder if you need to reload the firmware? You can do this if you have a serial cable to connect it to a PC. To put the Autostar into "Bootstrap loader" mode, power off, then hold down the top left and bottom right buttons on the Autostar whilst you turn the power on (needs at least 3 hands!). The screen displays a different message and waits for new firmware to arrive up the serial lead. Look on Mike Weasner's site www.weasner.com/etx for full instructions.
Mar 04, 2009 | Motorola Mobility RAZR V3
Meade LX200GPS telescope
The front panel for the telescope has an internal fuse. Remove the screws and look at the circuit board for a fuse. Replace with the same type and rating. The telescope has a diode with the fuse that gives some protection against reverse polarity, and the telescope should function on this fix.
Apr 22, 2008 | Optics
Autostar 497 freezes
When warm and indoors (!) connect Autostar to scope and by serial lead to a PC, allow Meade Autostar suite to update the Autostar Firmware to the latest version (2009!!)
Frome www.meade.com/support/auto.html :
How To Upgrade Your Handbox
To upgrade your Autostar first click on the link below to download the Autostar Update (ASU) Client Application for Windows. If your web browser allows you to open the installation file, you may choose that option when prompted. Otherwise, just save the install file to your local hard disk drive. When downloading is complete, double click on the saved file to start the installation. Follow the instructions provided to install Autostar Update (ASU) on your machine. When installation is complete, start ASU by selecting "Start Menu" -> "Programs" -> "Meade Inst" -> "ASU". If you have an active Internet connection and your telescope with Autostar is connected using the appropriate cable as listed above, ASU will detect and install the correct Autostar code directly from Meade's web site via the "Upgrade Autostar Software Now" button.
Autostar Update
Autostar Update is an application that functions to transfer the event files and software updates from your computer, through the serial port, USB or Connector Cable Set depending on your telescope model. The Autostar Update application is available as a stand-alone client application for Windows. The most recent versions of AutoStar Update automatically check for the newest versions of the AutoStar Updater and download it if necessary. It is critical that you use the most recent AutoStar Updater to ensure that you get the proper software updates for your system.
06/02/09 Autostar Update (ASU) Client Application for Windows, Version 5.6 (1,654 KB). This is the latest Autostar Update. Rev. 5.6 is compatible with the ETX-LS and #497EP Hand Controllers. This version is compatible with all versions of AutoStar II and #497 AutoStar computer controllers. This installation will automatically update the Update Client Application in AutoStar Suite™ Software. If you have previously installed the Autostar Update (ASU) Client Application for Windows, Uninstall the old version before installing this new version. 07/27/09 #497 AutoStar hand controller software update. Version 5BE2 (1,039 KB).
General update. Fixes many known bugs. Real time clock corrections. LXD75 polar alignment. Various LX90 pointing and tracking fixes. Adds new magnetic/true north alignment.
REQUIRES VERSION 5.6 AUTOSTAR UPDATER.
Jan 17, 2008 | Meade Autostar Suite Autostar Suite...
Meade LXD55 Telescope Logo
76 people viewed this question
Top Meade Optics Experts
Experi
Level 1 Expert
Joe Wright
Level 1 Expert
Hjalmer Lamminen
Hjalmer Lamminen
Are you a Meade Optic Expert? Answer questions, earn points and help others
