Question about Whirlpool Dryers
The problem is with the dryer door. It does not "push closed tight" to give that "click" sound. The door will stay in an "almost closed" position, but does not push all the way closed. Unaware of any prior incident / accident to cause this problem. Model: LER 7646DQ1 Serial #: MF 1011111 Stock #: LER 7646D
  • 5,911 Answers
The problem is probably attributed to a worn door strike and catch assemblies. This can happen through normal wear and tear and is fairly simple and inexpensive to repair. If the dryer still runs and heats, but you are having problems getting the door to stay closed properly, replace the catch and strike. These parts are sold as a kit. The part number is 279570 and usually costs $5 or less. Replacements parts can be purchased at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
All these sites are reputable, offer great service and have competitive prices, so shop and compare. The first three sites on the list also have helpful exploded view parts illustrations to assist you with locating and properly identifying any parts you may need. The catch and strike assemblies are listed as items 30 and 33 under the "Cabinet Parts" listing.
If you need further assistance, please post back and let me know. I hope you find this information helpful.
Posted on Oct 06, 2010
LG dryer doesn't dry clothes on one cycle. Lint collects around bottom of door rubber seal. Have noticed, the door is not closed tight. How to get door to stay closed tightly?
It sounds like you have a plugged up vent causing air to try to blow out around door instead of out vent. Also check door latch to see if anything is broken.
Mar 28, 2016 | LG Dryers
When I push the start button my dryer only clicks.
Electric dryer no start does nothing
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage.
CHECK THERMAL SHUT OFF THERMOSTAT USUALLY LOCATED ON THE BLOWER. for OHMS or resistance with a meter. Should show a closed circuit. Ohms WHEN THIS FUSE BLOWS IT WILL SHUT DOWN EVERYTHING.
NEXT Test the PUSH start switch with meter for OHMS. Should show OHMS when pushed in or on start, and no ohms or infinity when in off position.
If you hear a humming/clicking sound from motor area you more than likely have a bad motor.
Try this test out to see if u have weak windings or relay/capacitor on motor.
Open the dryer door and turn by hand the drum while machine is on ON position. And you or someone else presses the door engagement switch in. If it starts up then u have bad windings
Another thing to check is the belt safety switch. With a multi meter.
Especially if u just replaced the belt. The belt safety switch is attached to the Tensioner and motor. IT LOOKS LIKE A DOOR SWITCH SOMEWHAT a little black pc of plastic with 2 prongs going into it. Sits at bottom of motor. Under the Tensioner. Attach meter clips to the 2 prongs on switch, Then when the little white push button is pressed in it should show continuity and none when released.
Lastly check ur DOOR SWITCH for continuity with a meter when the button is pushed in the (on/Door closed position,) it may have gone bad.
https://www.youtube.com/watch?v=sTRP6kHqAFs
Apr 17, 2015 | Maytag Dryers
Model # GLEQ2152ESO will not start just humming sound when you push start button. Error code rE5
Apr 13, 2015 | Frigidaire Dryers
Hello I have a Zanussi TC 7102 condenser tumble dryer which has suddenly stopped working. It now makes a noise that sounds like it is about to start turning - except that is doesn't turn.
Feb 14, 2015 | Zanussi Dryers
Dryer wont start.
Oct 30, 2014 | Dryers
Why wont my Samsung DV220AEW/XAA start ?
Hey GOD IS GOOD !!!!
GOD IS GOOD !!!!
Sep 04, 2014 | Samsung Dryers
MY LG DLG2526W gas dryer won't start it has power and sounds like it wants to start but nothing happens
Sep 03, 2014 | LG DLG5932W Gas Dryer
Kenmore dryer model 110.74994300 push start does not stay on
Kenmore Whirlpool Dryer Won Start Easy Fix
Jul 01, 2014 | Kenmore 62602 Electric Dryer
Top freezer door does not close tight
Sounds like the top hinge is loose. If the hinge has a cover, remove it then hold the door in the correct position and tighen the hinge screws.
Aug 31, 2009 | GE GTS22KBP Top Freezer Refrigerator
Dryer won't start; light stays on whether door is open or closed.
Sounds like the door switch is not functioning or shorted......in other words the dryer thinks the door is open so it won't turn on.
Jun 22, 2009 | Dryers
Dryers Logo
80 people viewed this question
Top Whirlpool Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
