Question about LG Cell Phones
LG TU915 phone : Forgotton security code. Can this be reset to factory default ?
  • 4102 Answers
SOURCE: LG CE 0168 phone security code Lock
have you left the phone off for 24 hours if you switch it on and it is asking for security code i can get the master override code for your phone but i need the imei number and the code number off the back of your phone under battery the imei is 15 or 16 numbers long might be like123456/44/22343/2 and then the other one is about 6 numbers long 123456 if you give me these i can give you master code if your phone dont ask for code then you need to get it flashed at a shop to unlock it hope this is some help
Posted on Nov 25, 2007
SOURCE: LG DHINE KE970 security codes
On the home screen dial 2945#*# the call and it will give you the engineers menu, you just select factory reset and it resets the phone.
Posted on Aug 08, 2008
SOURCE: Forgot Lock Code - Samsung m500 Cell Phone
try to use last 4 digit of your phone number . go into the menu then setting then security then enter four digets and you can find these 4 degits into in setting then phone info enjoyyyyyyyyyyyyyy
Posted on Jun 05, 2009
SOURCE: I bought a phone from ebay, and the security code
on the touch keypad "dial" 1809#*365# to enter Engineering Mode and select 4-Master Reset. You'll lose everything stored ON THE PHONE but will retain SIM card stuff and of course SDMicro stuff. The phone itself will be in out-0f-the-box condition
Posted on Sep 05, 2009
nanbuenbrazo
  • 553 Answers
SOURCE: security code for motorola rokr e8
try this
*#06# IMEI
*#300# software versiom
*#301# keypad functions
*#303# set defaults
*#304# engineering mode
19980722 Ok master unlock code
Posted on Nov 06, 2009
Hard reset
You can reset and restore the factory default settings of your LG Attune UN270 mobile phone by following below instructions:
  • Touch Phone Settings and Security.
  • Enter the four-digit Lock Code.
  • Touch Master Reset.
  • Touch OK
  • A message will pop up that says "All settings will revert to factory default."
  • Touch Revert or Cancel.
  • If you touch Revert, enter the four-digit Lock Code. The phone returns to the configuration default.
May 22, 2013 | LG Attune
Forgot lock code for LG Extravert , need to reset to factory default.
Steps to Reset Settings This will reset the phone to factory default settings.
  1. Unlock the touch screen by dragging Slide up to unlock up and touch the Menu Quick Key.
  2. Touch Settings.
  3. Touch Phone Settings.
  4. Touch Security.
  5. Enter the four-digit lock code. The default lock code is the last 4 digits of your phone number.
  6. Touch Reset Default.
  7. After reading the warning message, touch OK.
  8. Touch Revert.
for Steps to Restore Phone visit my Blog
http://pcgadgetdeni.blogspot.com/2013/02/factory-reset-lg-vn271-extravert-to.html
Feb 14, 2013 | LG Extravert MobiPhone - Black Verizon...
Unclock security code
Steps to perform Master Reset
All configuration settings will be set back to their factory defaults. Personal data and downloaded content, however, will not be lost.
  1. From the standby screen, press Menu.
  2. Scroll to and select Settings.
  3. Scroll to and select Phone Settings.
  4. Scroll to and select Reset Settings.
  5. Select Master Reset.
  6. Select Yes.
  7. Enter Security code, then press OK. The default security code is 0000.
Steps to perform Master Clear
All configuration settings will be set back to their factory defaults. Also, all personal data (including contacts) and downloaded content will be erased.
  5. Scroll to and select Master Clear.
  6. Select Phone.
  7. Select Yes.
  8. Enter Security code, then press OK. The default security code is 0000.
Warning!: While reset/restore operation under process, you are advised not to remove your battery until the operation is completed and cellphone restarts otherwise phone damage may occur.
Dec 20, 2012 | LG Neon GT365 Cell Phone
Went back to factory settings.but have forgotton my password.help
You may try default phone and security code to remove restrictions.
ur defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
Oct 31, 2012 | Cell Phones
A while ago I changed the default security code 12345 on my nokia 2760 and now have forgotton the changed code because I have not used it for long time. My mobile IMEI number is 353116/02/385223/6. Pls...
You will need to get a Nokia Authorized Repair Agent to upgrade the software on your phone and reset the phone back to factory default - including the security code back to default 12345.
As this is not a warranty issue, it would most likely cost you a non-warranty fee to do this.
Apr 06, 2012 | Nokia 2760 Cellular Phone
How to unlock LG TU915 cell phone?
You can unlock your LG TU915 using the codes.I found an unlocking service at Classicunlocking.com .Through this you can unlock your mobile easily.
Jan 09, 2012 | LG GD510 Cell Phone
How to do hard reset lg r500
I am supposing you are using the LG Xenon GR500.
Soft Reset
To perform a soft reset, remove and re-insert the battery.
Master Reset
IMPORTANT: All configuration settings will be set back to their factory defaults. Personal data and downloaded content, however, will not be lost.
  1. From the standby screen, press the menu icon.
  2. Tap the Settings Icon.
  3. Tap the Phone icon.
  4. Scroll to and tap Reset Settings.
  5. Tap Master Reset.
  6. Tap Yes.
  7. Enter the device's security code, then tap OK. The device will reset.
    NOTE: The default security code is 0000.
Master Clear
IMPORTANT: All configuration settings will be set back to their factory defaults. Also, all personal data (including contacts) and downloaded content will be erased.
  5. Tap Master Clear.
  6. Tap Phone.
  7. Tap Yes,
  8. Enter the device's security code, then press OK.
Oct 27, 2011 | LG Shine KE970 Cellular Phone
I forgot the lock code to my rumor touch and can still access the phone but cannot lock it because i forgot the code... what do i do?
hi dear.. please help me.. i forgot my NOKIA E63 restore factory settings lock code. please send the how to reset my lock code to manikanta.art@gmail.com
May 24, 2011 | LG Rumor Touch
the default security code for many LG phones is the last 4 digits of your phone number. I think it is called the PIN sometimes too.
Apr 30, 2008 | LG Shine KE970 Cellular Phone
Cell Phones Logo
136 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
