Question about Pride Jazzy 1113 Power Chair
My Jazzy 1113 is 7 years old. In the last six months it's broken down with different problems three times. Until now it's only broken down once every 3 or so years. Do you think it's time to get a new chair? Thanks. Phyllis
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 347 Answers
Hello,im disabled myself im here as i care,can ya please rate me as in thumbs up 1 to 4 for my answer.
My opinion is why renew something you were able to rely on.Everything is built nowadays not to last,you could buy a new 1 & be saying,i wish i had my old 1.As long as you get it serviced so you know its safe for you,why spend money on another 1.Have a nice day Colin.P.S.this opinion i give you is only my opinion,i know they give a life expectancy on things.maybe a second opinion from shoprider will help you decide Colin.
Posted on Oct 08, 2010
Jazzy 1113
check wiring and pcb in your chair...it may be loose connection in between the path
Sep 30, 2008 | Pride Jazzy 1113 ATS Indoor Power...
Can the batteries or my charger be bad on my Pride Jazzy 1113 ATS?
The MK batteries are far superior to Interstate batteries overall.
You can load test the batteries to see if they are working properly with a load tester. Your can test the charger output to the batteries with a digital voltmeter connected to the batteries with the charger plugged in. These 2 tests take less than 10 minutes and can be done at a local auto or scooter shop for nominal expense.
Make sure the charger and battery connections are tight and free of corrosion. On the VSI of the Jazzy 1113 there is a notorious problem with 8 pin connector and 3 pin molex at the back. You can clean these connectors but a complete electrical rebuild of the pins and receptacles is sometimes required if significant corrosion has set in. Try spraying electrical cleaner and use green Scotchbrite to clean the metal tabs on the 8 pin connector. Make sure the 3 pin molex sits in the receptacle and is making good contact.
Hope this helps.
Jul 22, 2014 | Pride Mobility Products Jazzy 1113 ATS
Pride jazzy 1113, controller light scroll back and forth, wont move, i bought one new battery, it has full charge other battery is a little over 10 volts. is there way to test charger with volt meter?
The voltmeter should read 29 volts when on. You should never replace one battery and leave an old battery in the chair. Replace them both at the same time.
Oct 17, 2013 | Pride Jazzy 1113 Power Chair
The chair is locked. I had this happen a long time ago and I needed to move the joy stick diferent directions to get it unlocked but I do not remember how. It is a Jazzy 1113.
If it is the older VSI controller, turn on chair. as the battery lights scroll, hold the joystick in the (UP) position until you hear a beep. Then immediately place the joystick in the (down) position until you hear a beep. then place the joystick in center position, once you hear the beep for the final time, it should be unlocked.
If you have a Dynamic controller, turn on chair then press the horn button to unlock.
Sep 15, 2011 | Pride Jazzy 1113 ATS Indoor Power...
Jazzy 1113 Unit has a full charge, but won't move. Battery indicator LED's go from empty to charge a couple times then flash the red and yellow. Think it might be the throttle pot. If so is it possible to...
Go ahead and try this web site.It will give you the flash codes and narrow down your search to finding the problem.http://www.pgdt.com/scenter/diagnostics/diagvsi.html
Jan 22, 2011 | Pride Mobility Products Jazzy 1113 ATS
The jazzy 1113 will not start, when you press the power button the speed light comes on gets full and then turns back off
How old are the batteries? If you've had them for a few years it might be time to change them. Even if batteries are charged correctly they eventually lose power with use and need to be changed. Here is a link to the battery needed for the Jazzy 1113 http://www.replacementupsbattery.com/UB12350-NB.html
Nov 08, 2010 | Pride Jazzy 1113 ATS Indoor Power...
Jazzy 1113 ats won't start
Nov 04, 2010 | Pride Jazzy 1113 Power Chair
What are the best batteries for my jazzy 1120.
andre Your Jazzy uses 2 Group 24 batteries and I would get MK batteries they are very good and can last 3-4 years if taken care of. Follow their charging recommendations and you should get great service from them Hope this helps you
Sep 18, 2010 | Pride Jazzy 1113 Power Chair
Pride Jazzy 1113 Power Chair Logo
63 people viewed this question
Top Pride Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
