Question about Kenmore Dryers
KENMORE SERIES 70 NOT HEATING PROPERLY.REPLACED HEATER CLEANED ALL VENT HOSES COULD IT BE THERMOSTST
  • 49 Answers
Yes it could. If the thermostat is faulty it can cause the dryer to short cycle. If you have a thermometer that you can use to check the heat coming out of the dryer when running with no load it should go off at around 170 degrees F and come back on after dropping 30 to 50 degrees. If it is cycling too soon the thermostat is the most probable problem.
Posted on Oct 06, 2010
I have a kenmore 70 series gas dryer. the dryer works pretty normal except the clothes take a little while longer to dry and they all smell badly of natural gas. i opened it up and and i can see the...
Check the vent hose for kinks . Also check the exhaust at the outside to make sure it has good air flow to the outside . A dryer either heats or not . Due to it heats , the only possible problem is vent hose blockage .
Sep 23, 2010 | Kenmore Dryers
We have a Kenmore 400 Series dryer. It heats up but our clothes is not getting dry. We have to cycle it twice to get our clothes dry on high heat. Any idea why it would take 2 cycles to dry?
This was the out vent of my dryer... If it gets this bad... open up the dryer housing and clean inside too. Also make sure the intake is free of lint.
Aug 23, 2010 | Kenmore 74602 Gas Dryer
Dryer takes long to dry cleaned vent hear burner go on but not for long thi is a gas dryer kenmore 70 series
to know if the vent is for sure cleaned unhook the dryer and start in timed cyc using high heat and see how long it runs does it run longer than when hooked up to vent if so vent is still restricted if not then the blower housing/lint screen is also plugged
Sep 10, 2009 | Kenmore Dryers
Kenmore Dryer won't heat up
thermal fuse is bad. replace fuse. clean out vent duct. thermal fuse usually blows when there is restricted air flow over heating element.
Jun 24, 2009 | Dryers
Kenmore electric dryer heats but does not dry the
Hi, Here are the obvious parts to check: Heater, High limit, Thermal fuse or thermostats...these are all generally located in the back but some models you access them from front. the most common cause is either heater or thermal fuse, I will include a picture of the thermal fuse. If you test these parts and find they all work you may be looking at a centrifiacal switch problem.
Here is a picture of the thermal fuse check this part first:
http://www.partselect.com/repair.aspx?appliance=dryer&part=replace-thermal-fuse
Please feel free to contact again if you have any other problems.
Hope this helps.
Jun 23, 2009 | Kenmore 63942 Dryer
Kenmore Series 70 Dryer
I'm not familiar with your dryer model but general advice regarding dryers with the problem that you have described would be to ensure that any filter on the outlet is clean, whether it be a condenser or traditional external vent.
Ensure, if it is vented rather than condensing (only connected to a drain) that the vent tube has clear access to expel the damp air circulated during the drying process.
If the wash load is heating to a substantial temperature in the dryer, it isn't the element causing the problem.
May 07, 2009 | Kenmore 60172 Electric Commercial Dryer
Heating element and/or replacement bulb
no light bulbs on its own line and routs through the door switch as for the heat check your temp select button or your thermostst in the control panel should be a tech sheet with specs but be sure to put it back when your done
Feb 11, 2009 | Kenmore 63942 Dryer
Clothes don't dry but dryer gets hot
ck vent to outside starting and dryer back to verify vent issue try drying a load with hose disconnected
Nov 24, 2008 | Kenmore 60172 Electric Commercial Dryer
Kenmore 70 series electric dryer
do you get any heat at all? is the drum turning? if yes and yes you need to check the dryer hose all wall hole to see if it is clogged,clean both out and see if this helps,if no heat the main heater fuse might be bad,check that also,hope this helps you-mike
Oct 26, 2008 | Dryers
Dryers Logo
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
