Question about Insignia Audio Players & Recorders
Do I use the receiver line out to connect 2 Bose 102-EA extension amps to an Insignia NS-R200 receiver?
SOURCE: insignia ns-pdvd8
Thanks, Its WORK !!!!!!!!!!!!
Posted on Dec 25, 2007
  • 16 Answers
SOURCE: my bose pmcii lcd remote control does not receive a signal from a bose lifestyle 48 receiver
Have you tried using the remote antenna supplied with the Bose system? This connects to the "Remote antenna" socket on the rear of the media centre and is made up of 2 parts: a shielded section (black in colour) that runs past any sources of interference - mains or signal cables, other electronics products - and the unshielded antenna (clear plastic covered copper wire) that must be fully extended vertically to act as an aerial. Position this away from sources of interference and as close to the second room as possible (Bose do a longer version, free of charge in some countries....)
The remotes only have a range of up to 20metres - this will drop the more walls it passes through and the thicker the walls. Any interference can affect this - radio transmitting equipment (WiFi, video sender, but especially products transmitting on the same frequency - 27MHz or 40MHz, e.g wirless thermostats or alarm systems....) or products with poorly shielded transformers. Experiment with swtiching off other electical equipment (including lights if they have a transformer - e.g. halogen spot lamps). If you identify a source, can you move it away.....?
Posted on Jan 16, 2008
SOURCE: insignia NS pdvd10
Unlock
Insignia NS pdvd10
It`s really works
1) On the remote control type "SETUP" button
2) Select "PREFERENCES" in the menu with
3) Validate it with the button "OK"
4) Enter the code : "224455"
5) With the direction keys type:
a) Left key : < (Nothing happens)
b) Down key : v (a menu appears on the screen
with all region)
6) Select the Region : 0 (all) with the direction keys
7) Validate it with the button "OK"
8) Finish the process by typing the "SETUP" button.
Posted on Oct 03, 2008
Unlock
Insignia NS pdvd10
It`s really works
with all region)
YourZEN
  • 820 Answers
SOURCE: where can i download free insignia NS-DA1G
Features, specifications and support for NS-DA1G on next site:
http://insigniaproducts.com/products/portable-audio/NS-DA1G.html
Guides and drivers under the support tab, see:
http://insigniaproducts.com/products/portable-audio/NS-DA1G.html#supportTab
Posted on Oct 15, 2009
Where can I get a remote control.
I believe that you want the INSIGNIA KOR3551. You can find the remote using the following website.
http://ezremotefinder.com/results.php?mfg=INSIGNIA&mdl=KOR3551&keywords=&page=1
Jan 29, 2016 | Insignia Ns-r2000 200w 2ch Stereo Receiver
Tip
Insignia gps receiver
my insignia NS-CNV20 car gps is not working propely.
my question is i need insert same map gps update for my gps?
on Sep 30, 2009 | Insignia NS-CNV20 Car GPS Receiver
NS-R5100
Probably a short in the amp that will need to be repaired.
Feb 27, 2013 | Insignia Ns-r5100 Av Digital Home Theater...
Insignia ns-dxa1-apt receiver is not picking up signal and all cables are connected correctly, we have suddenlink cable. Does this receiver not work with them?
Hi- My name is Shannon and I am with Suddenlink. If you are still experiencing trouble, I would be happy to assist you. Please email me directly at shannon-AT-suddenlink-DOT-com. Thanks!
Nov 04, 2012 | Insignia NS-DXA1-APT
How do you hook up an mp3 player to insignia ns-r2000
You will need an Dual RCA to 3.5mm stereo cable. One similar to this: http://www.dcables.net/Dual-RCA-to-3_5-mm-Stereo-Cable-5-Feet.aspx
It would probably be easier to pick one up at your local Wal-Mart or Radio Shack.
Just connect the RCA connectors to one of the audio line inputs and the 3.5mm to your mp3 player. Set your insignia to receive the source you just connected.
Hope this helps
Apr 07, 2011 | Insignia NS-R2000
Used power -in and now auxiliary imput won't work
What do you mean you 'used power -in'? Did you connect something to AUX in that wasn't supposed to be connected to it? It's for Line aLevel inputs (standard analog audio) only.
http://insigniaproducts.com/cms/documents/NS-H2002%20UM%20EN.pdf
Please elaborate.
Jan 28, 2011 | Insignia 200W Stereo Receiver
Insignia GPS INSIGNIA NS-CNV20 Pover Up and Shutting down
Try resetting your navigator by inserting a tin tool (e.g. unbent paper clip) into the reset port. A schematic can be found in the owner's manual. Also, ensure that the unit is securely connected to power or that the battery is fully charged. If these steps don't resolve the problem, return with the unit to the place of purchase to pursue service options.
Mar 10, 2010 | Insignia NS-CNV20 Car GPS Receiver
Manual for Insignia model NS-LCD19W-09 missing . Kindly submit. Best Buy suggested getting manual on line. . Would appreciate receiving manual on line. Thank you.
Here is a link to your Product Manual.
Click on your model number and it will load your manual in a PDF version.
 http://www.insignia-products.com/pc-340-14-insignia-19-720p-widescreen-flat-panel-lcd-hdtv.aspx
Let me know if I can assist further.
Please rate this solution. Lone99star
Mar 03, 2009 | Televison & Video
82 people viewed this question
Top Insignia Audio Players & Recorders Experts
Alan Matzke
Alan Matzke
Curt Larson
Level 1 Expert
Are you an Insignia Audio Player and Recorder Expert? Answer questions, earn points and help others
