Question about Lands Phones
I have a Cora phone but no manual and caller id very faint can't read it, plus how to store numbers and what are M1` and M2 buttons for? How do I make caller id brighter so I can read it, I am visually impared.
5 Suggested Answers
SOURCE: caller-id quit working
This is a followup to my earlier suggestion. My caller id is working. So, the culprit had to be related to the 9V battery. Just try my earlier solution from 1/20/07. If it works..fine. If not, bye-bye to the phone.
Posted on Feb 10, 2007
SOURCE: Caller ID does not work
I FIXED IT!!!  YIPEEE!!
What I did was UNPLUG the base's power unit from the wall... waiting about one minute, and plugged it back in.  That caused it to "reboot" the entire system, and the CID now shows itself.
Posted on Mar 07, 2008
cnavarro
  • 2460 Answers
SOURCE: Nortel Meridian Norstar-Plus Compact ICS with #7310 phones.
I'm pretty sure CID is automatic on a CICS....IF you have a CID trunk card. You might want to post the part number on the face of the trunk and we'll see if it's the proper one.
Carl
Posted on Jan 08, 2009
VanDaniel
SOURCE: durabrand phone model ph-3238
While holding down ‘Delete’, tap the ‘Down’ button. You will then be able to use ‘Up ‘ and ‘Down’ to set contrast, language, area code, time, and then date. Tap ‘Delete’ once your selection has been made on each item to move forward to the next.
Hope this helps you and any others as I had the same problem, and it took forever to figure it out.
Posted on Dec 29, 2009
I need instruction manual to program speed dial
I was unable to locate a user manual for that particular device, however the basic instructions for programming speed dial functions are normally very similar between most phones.
Generally there are ONE TOUCH Speed Dial buttons labelled something like M1, M2, and M3 on the dial pad somewhere.
There should also be another button labelled PROG or STORE on the keypad as well.
Normally to program a number into a ONE TOUCH speed dial memory location you carry out the following procedure:
Lift the handset.
Then press the PROG (or STORE) button.
Now just use the number keypad to dial the full telephone number that you want to store in a Speed Dial location.
Once the full telephone number is dialed, then push the M1 button to store that phone number in the M1 One Touch Speed Dial location.
The phone may or may not show some kind of confirmation that the M1 location was just programmed, then just hang up the handset.
Now when you lift the handset and press the M1 button, the phone should automatically dial the phone number you programmed into it.
Now just repeat the same process for the M2 and M3 One Touch Speed Dial buttons with other phone numbers if necessary.
To change one of the Speed Dial numbers, just carry out the normal programming procedure for that location using the new phone number and the old number will simply be overwritten.
I truly hope that was helpful to you.
Good luck and take care.
Joe.
Dec 02, 2011 | Southwestern Bell FM-480 Corded Phone
I have a Living Solutions Caller ID Trim Phone model HAC W17J1578/ATC-1578 and I don't have instructions for storing my memory numbers. Could you help. Thanks.
Press the store button
enter the phone number to save
press the button you want to store it in (M1 to M3)
Hang up the phone.
Your number is now stored
Sep 03, 2010 | Lands Phones
Looking for conair cm200wcs manual
To store numbers into the phone's memory:
Lift receiver - you should hear dial tone. Then, press 'STORE', press key M1, M2 or M3.* Enter the number you wish to store. Then, press the 'STORE' key again. Now, press the memory position you chose above, (M1, M2 or M3).** Replace receiver back on cradle.
To use - lift receiver and press the memory key that was optioned, (M1, M2 or M3). If a numeric key, (1-9), was chosen - press the 'MEMORY'' key then the chosen number.
* To store in numeric 1 - 9, just press the 'MEMORY' key for this step.
** When storing in numeric 1-9, Press the 'MEMORY' key and then the number you wish to store in this step.
Tip: For a phone card, use M1 for the 800 number and M2 for the PIN.
Jun 30, 2010 | Conair TAD920 Corded Phone
Store a number in memory of Cable and Wireless CWP220
One-touch memory buttons (M1, M2, M3):-
-Lift handset.
-Press STORE button.
-Enter phone number to be stored (up to 16 digits).
-Press STORE button again.
-Press either M1, M2 or M3 button, depending on where you want to store number.
-Replace handset.
Two-touch memory buttons:-
-Lift handset.
-Press a keypad number 0-9, depending on where you want to store number.
-Replace handset.
Apr 12, 2009 | Lands Phones
I have a Vextra large button phone model # 4848-18 I do not have the manual to store numbers into the memory. Can you help me with steps? I see the store button but do not know the steps. Mary D.
1. Hit the store button
2. Type in the phone number
3. Hit store again
4. Hit the button you want it stored to M1, M2, or M3, if using the little auto dial buttons you need to hit the Auto button and then the little buttons.
To auto dial you just hit M1, M2, or M3. For the little buttons you need to hit Auto first then the little button. There is no beep when you hit the Auto button but it is working.
Hope that this helps
Mar 05, 2009 | Lands Phones
Uniden Model EXP7900 How do I program button m1
One-Touch Dialing
Your phone is equipped with three .One-Touch Priority. keys for
instant dialing (m1, m2, and m3). You cannot store phone
numbers directly into m1, m2, andm3. They are only used
to dial phone numbers stored into memory locations 1, 2, and 3
on the keypad.
1. To instantly dial phone numbers stored in memory locations
1, 2, or 3, simply press m1, m2, or m3. (There is no need to
press talk, the phone will automatically dial.)
2. If no phone number was stored in memory locations 1, 2, or 3
on the keypad, pressing m1, m2, or m3 will do nothing.
I hope this helps.
Rollin CBs
Dean
Nov 04, 2008 | Uniden Cordless Phone
Cannot enter a number for quick dial.
Hey Dilkin - what's the make and model # of your phone please. Thanks.
Jeff
May 19, 2008 | Lands Phones
Binaton big button combo telephone
Press Speakerphone button
Press Set/Store
Enter the telephone number
Press Set/Store
Enter the memory number (M1, M2, M3 or 1-9)
Press Speakerphone button to hang up.
To use the memory feature,
For M1, M2 or M3, just pick up the phone and hit that button.
For memory number's 1-9, pick up the phone, press auto button, then enter number 1-9 for who you want to call.
Apr 16, 2008 | Lands Phones
How to proram speed dial
Here is the solution:
1) Pick up the handset
2) Press the "Store" button
3) Dial the number that you want to store
4) Press the "Store" button
5) Press one of the Memory button such as M1, M2, etc.
6) hang up the phone (put the handset back to the base)
When you're ready to dial the number, just pick up the handset and press one of the Memory button that you just use to store your desired number.
Best of luck,
KP
Dec 18, 2007 | Sakar Talking Caller-ID Speaker Phone
Lands Phones Logo
519 people viewed this question
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
