Question about Harman Kardon Sony CDPCX355 CD Player
Have a Sony cd. player and it keeps open the tray. After about 30 second to 3 minutes it will finally read it and then play. Is there anyway to fix this problem?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 73 Answers
This is a problem you should refer to a qualified audio tech. it may be mechanical, but more likely a digital/logic control problem. Either way, an untrained person has no chance of resolving this problem. You may have to consider if the unit is worth the repair cost.
Posted on Oct 07, 2010
  • bmcdoodle Oct 15, 2010
    try opening the case unplugged of course and cleaning the laser lens.
  • rocksteadyha Oct 15, 2010
    The comment by bmcdoodle may be O K, but CD player lenses rarely, if ever, need cleaning. You didn't say whether this happens on all disks you play, or not. The first thing you should do when this happens is clean the CD with soap and water, drying with a lint-free cloth. If this fails to correct the problem, the disk may be scratched or damaged perhaps beyond repair, or there i sa fault with the player.
My hk 30 player tray flashes (disc error) with every digital audio disc. help
Often times the tray and pickup lift assembly are related and there is a cam alignment. IF you pulled out with force the tray the alignment may have been upset to where the cam is not completing the lift of the Pickup and if not in the right position the laser will not be able to focus. The correct solution is at a Technicians bench where a new belt could be put in, lubrication that is required and some cleaning will be done.
Jan 21, 2013 | Harman Kardon CDR30 2-Disc CD Recorder
Dvd player will not eject or play dvd. It just keeps spinning and says "reading." I've tried unplugging for 2 minutes, pushing close/open and stop at the same time(hold for at least 3 seconds)....
Plug the power cord back into the electrical outlet and turn the player ON. Attempt to open the disc tray. Depending on the model number of your DVD player, simultaneously press the POWER + STOP + EJECT buttons. If the disc tray still does not open, simultaneously press the DISC1 + STOP + EJECT buttons.6 Jan 2013
Solved: DVD is LOCKED will not eject. please help. Manual ... - the ...
https://community.sony.com/t5/Home-Theater.../DVD-is...will-not-eject.../td.../55919.
or try this link. Dvd player will not eject or play dvd Google Search
Oct 18, 2017 | RCA DRC8295 DVD Recorder/VCR Combo
My JVC DR-M70 dvd recorder tray won't close.
Sorry for the delay in following up. My tray problem appears to be resolved, but I wanted to wait a few days to see if the problem returned.
After reading several suggestions on various sites for other makes and models, I started experimenting to see if any would work on my machine. I made several failed attempts before hitting on the right sequence of steps. To the best of my memory, THIS is what finally worked for me:
1) I gently pushed the tray back to it's closed position (note: the solution did not work during previous attempts when I left the tray open)
2) I unplugged the machine for 30 seconds,
3) holding down the remote's open/close button, I plugged the machine back in and immediately pressed the stop button on the player, holding both buttons down for 30 seconds.
4) I unplugged the player AGAIN for 30 seconds, then plugged it back in.
A MIRACLE! Upon hitting the open/close button on the remote, this time the tray opened exactly as it should, and it's been behaving itself ever since. I don't know if any of the steps I performed were unneccesary. All I can tell you is that every time I left out a step, it failed. The first time I followed every step, I had success.
As for my remote: I put in fresh batteries. The open/close button still occasionally tells the tray to open and close simultaneously. tvdokter has suggested cleaning it on the inside, but unfortunately, I only see one screw (inside the battery compartment.) I can't see how to get in without breaking it. Oh well, at least I'm back to be able to play and record my dvds.
Anyway, thanks for the advice. I hope this solution will be helpful to someone else down the line. If anyone has any questions or comments, feel free.
Aug 27, 2009 | Televison & Video
Jvc dvd player not playing
Even you don"t have a remote you can play it manually and DVD player play it automatically.Just try this open the tray put the DVD disc on the tray and close it then turn it off for 30 seconds then turns it on then it play automatically if not then there's something wrong to the player.
Hope it may help you:
Regards:
VOTIT
Mar 23, 2009 | Audio Players & Recorders
TEAC CD P1120 wont play
hi there krell
you definetly have a fault in your cd players main board best solution take to electrical shop and ask them to test all the circuits it wont cost much to get them checked out and see how you go
hope this helps and if you have the time please rate me if you dont mind
thank you
fixya
Jan 10, 2008 | Teac CD-P1120 CD Player
Cd player opens when turned on and will not function
JVC recommends leaving the unit unplugged for 30 minutes to reseet the system - I'm trying that now, and will keep you posted!
Dec 07, 2006 | JVC FS-G5 CD Shelf System
61 people viewed this question
Top Harman Kardon Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Electro Med Services...
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
