Question about Karcher Garden
Ok i have a karcher with the 3.75 brigs and strat on it and it was running fine then it lost pressure and now will not build any back what is the problem
    Scholar:
  • 100 Answers
Unloader valve sticking is your issue, see link to fix problem
You might want to consider replacing the unloader valve, see attached link
Posted on Oct 25, 2010
Karcher hds745 m-eco builds up to pressure. Runs fine for 300 seconds then loses pressure buids up runs for 20 seco ds loses prwssure again checked. Dilter strainer water pressure seems good any ideas...
If nozzle is partially clogged, it can cause unloader valve to shift back and forth from high pressure to bypass. Air in the feed line can also cause this symptom. Some Karcher models have auto start/stop system which can behave this way if worn out, or out of adjustment.
Nov 10, 2014 | Garden
Lost pressure. Inlet water pressure fine. I fixed this a few tears ago and I cannot remember what I did.
first check the triger velve is working ok,, if its stuck strip it out and free it off
Aug 14, 2010 | Karcher 2500 PSI Pressure Washer
Karcher K4.97M electric waterblaster cycling
It sounds to me like the unloader valve is bypassing internally.
Nov 16, 2009 | Karcher K2.26 Electric Power Washer
Troy bilt pressure washer will not build or reach high pressure
check the non-return valves in the pump block. if these are damaged or dirty you pressure will be greatly reduced. they are located behind the 3 lage brass hexagonal caps.
I hope this helps
Sep 04, 2009 | Karcher 2500 PSI Pressure Washer
Karcher B402 pressure washer Motor runs as soon as power supply connected, on/off switch does not seem to make a difference and no pressure at outlet? Was working fine, stopped for half an hour, came back...
bob I had this happen to my Karcher, the pressure seals have blown. $Au200 for service and replacement from karcher dealer. tyhey would not sell the parts for a DFY
Jun 22, 2009 | Garden
Pressure is fine when first started ,if trigger released no Psi
Your uplift injector valve in the water pump is sticking. You need to remove this part. Lube the top o-ring only with a water proof grease. Reinstall this part. You will be up and running again.
You need to use needle nose vise grip tool to easily remove the valve. You need to grind down the vise grip tool to fit the opening where the valve is installed.
To prevent this problem from reoccuring use a pump guard additive.
Apr 05, 2009 | Karcher 2500 PSI Pressure Washer
Karcher 2500 no pressure problem
sounds like you have an inlet blockage to the pump or not enough volume to feed the pump. make sure hose is turned full on when washing and see what happens. if not you may have to remove adapter wher hose screws in and check for a blockage.
Jul 13, 2008 | Karcher 2500 PSI Pressure Washer
Won't build pressure
the adjustable wand or pressur regulator may be clogged with rust inside. it's economical to replaced the wand assy.
May 13, 2008 | Karcher 2500 PSI Pressure Washer
Karcher HD 655 S Does not come up to full pressure
yes...check the check valve. A one-way directional valve, this part is also known as a DUMP valve. It opens when too much pressure builds in the hand wand (when not spraying water) in order to protect the pump, by returning the high pressure to its source reservoir. I suspect the DUMP valve is stuck in open condition (or nearly open).
Jun 10, 2007 | Karcher 2500 PSI Pressure Washer
Garden Logo
114 people viewed this question
Top Karcher Garden Experts
John Trevino
andy just round the...
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
