My Montior 40 heater is running but no heat is coming out and the burner is not lighting what do i do?
  • 674 Answers
First, do not keep trying to light it. The igniter may be bad and kerosene will keep building up in the burner. Test the igniter with an ohmmeter. I don't know the exact value at this second but it should be less than 20 ohms. You can also use a clamp on ammeter around one of the leads. If the igniter is drawing current, it is good.
Does the fuel pump make a loud ticking or thumping sound. If it does, you have a fuel problem. This could be caused by the filter at your tank, a dirty fuel sump strainer, no fuel in the tank, or an air bubble in the fuel line.
You should also check the flame rod. It can be cleaned with some steelwool or fine sandpaper.
Check the circuit board by checking for 120vac at the 2 pins where the igniter connects while the heater is starting.
Also check the air line going to the air pressure switch for cracks and splits. If the air pressure switch isn't made, the fuel pump will not run.
Check the flue pipe for obstructions like bees nests from the summer.
I hope this helps, let me know if it doesn't. If you need parts I can also get them.
Posted on Oct 07, 2010
I have a gas heater. The pilot light is steadily lit and blue but no heat is coming out.
pilot lights are not heaters
the main burner is what heats and it appears that the jet for that burner is blocked
it is not diy so get a gas fitter in for the repair/fix
Jan 26, 2017 | Heating & Cooling
Heater will not activate until outside temp. is above 40 degrees
If you have a heat pump the compressor is locked out below that temp. If you have a dual fuel - hp/gas, the gas burners should come on as would the electric heaters if you have electric heat as backup.
Jan 19, 2016 | Heating & Cooling
GCV 40 100 Burner and pilot shuts off when heating up
Get more fresh air to the unit.
Clean the air intake/ flame trap/ flame arrestor located on bottom of tank.
http://waterheatertimer.org/images/Flame-trap-inspection-325.jpg
Post question on pro water heater forum.
http://www.thetankatwaterheaterrescue.com/forums/forum3/
Add a comment with type of gas control valve, for possible troubleshoot.
Copy following link to read service manual by type of gas control valve:
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
Aug 17, 2012 | A.O. Smith GCV-40 Promax Residential Water...
Burner will not light rheem water heater 21vp40e1pa
electric heater I see that is noted so one of the heating elements are bad. there is two of them running vertical on each side of the tank
Mar 05, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
How do I light my Rheem water heater if my peizo ignitor switch isn't working
Remove the burner access cover under the control valve. Press the pilot light button (gas control) and hold it down. At the same time, light the pilot. Continue to hold the lighting button for a few seconds until the thermocouple heats up. Release the button. Twist the gas control knob to the ON position, and the burner should fire up after a few seconds. Replace the access cover. Good luck.
Feb 09, 2010 | Rheem 40 Gallon FVR NATGAS Low WATER...
Minimax 400 heater not operational
what is ok on the water pressure? th heater need from 40 to 60 gpm in order to work properly clean the filter and let me know
Sep 10, 2009 | Pentair Minimax NT Heater
I have a power vent2 water heater by Rheem products. Problem seems to be with blower fan turning on when thermostat calls for heat. Fan makes un-able to start noise and thermostat stops. If I turn the...
your blower motor is trying to seize up on you, it is time to change it, if the fan doesn't come on first your water heater should not light, the fan comes on first to get eccess gasses out of the burner compartment,, do not light with ot the fan first it could combust
Jan 27, 2009 | Bosch & Power Vent Water Heater
Fan cycles on and off to often the burner stays on and the fan cy
what is happening is that the heat exchanger has to get to a certain temperature before the fan comes on that way you have warm air blowing out of the grilles and when the heat excahnger gets cool it shuts off until it warms back up again.
Jan 15, 2009 | Honeywell L4064B2236 Fan/Limit Control...
Heating & Cooling Logo
62 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
