Question about Toshiba Satellite (K000004080) Motherboard
My toshiba satellite a200 will run with the battery but when i take the battery out and plug the laptop into the wall to see if i get any power, i am not able to power on the computer
    Sergeant:
  • 191 Answers
Hello, does the battery charge when you plug into the wall ? If it doesn't then your AC cable has a problem and I suggest that before we conclude on that solution you try plugging into another wall to see if it works first. But if the response is still the same then your AC cable has a problem and you should change it as soon as possible. I hope this solution is helpful. Have a wonderful day.
Posted on Oct 06, 2010
Toshiba satellite A200-27Z power cord led flasing failure to post will try any suggestions
Have you tried another Cord with the EXACT same power specs? Remove the battery. Has the cord/charger/transformer been damaged? Has the AC jack been damaged? Due to pulling on the cord while plugged in? At the AC jack "wiggle" the plug a bit to see if the plug and AC jack are making a good connection or Loose. Sounds like a loose AC connection.
Jan 10, 2013 | Computers & Internet
I have Toshiba Satellite A200-1CC. It wont give a sign of life when the power button is pressed. AC power cord with jack are okay, Wall power cords are new. It won't fill the baterry, but when the bat
first try to check if your toshiba is still part of the warranty. if this is good, much better to go to the service center and they will replace the battery pack of your laptop.
Dec 15, 2011 | Toshiba Computers & Internet
We have a toshiba a200 satellite and it has no power.Took battery out and put it back and still no power. Charger is ok have checked it.Any ideas why no power?
There maybe something wrong with Toshiba power provide module but shouldn't be matter of toshiba satellite a200 laptop battery. It is a difficult problem can't be solve by some words or sentences,you'd better go to a professional laptop repair engineer to repair it. Good luck.
Feb 17, 2011 | Toshiba Computers & Internet
Toshiba satellite A200 - press power to turn on the machine and get blank screen and 3 beeps then nothing. Computer was left in sleep state for approximately 2 hours and now refuses to wake or reboot...
HI
Try to unplug the power supply and take the battery out. so it means there is no power going to the laptop. now press and hold the power button down for approximately 1 minute.
After that put the battery in and plug the adapter back.
Try to turn the laptop on most probably it will come on
If it still does the same thing contact ur laptop manufacturer
Jul 18, 2010 | Toshiba Satellite A200-16J01D Notebook
Laptop Toshiba Satellite A200 Model No. PSAF6A-02C01N fail boot
Try removing / swapping / reseating the memory.
Try booting with one stick only, if the top slot doesn't work, try booting the bottom slot. Try both sticks.
Let me know what happens.
Apr 04, 2010 | Toshiba Satellite A200-0ET00X Notebook
My Toshiba Satellite Pro A200 works fine if I use a battery charged on an identical machine, with the same mains charger. With the mains charger plugged in it either shows 'plugged in not charging' or...
It sounds like the connector from the A/C adapter to the motherboard is loose or the inside of the adapter plug that attaches to the motherboard is defective.
Jan 08, 2010 | Toshiba Satellite Pro A200-EZ2204X...
Toshiba Satellite A200 unstable on power
The problem is probably not in the motherboard itself, but may be internal to the laptop.
From what you've described the problem is either in the AC Adapter itself or in the power supply inside the laptop (the area where you plug the AC adapter into the computer.
The first thing to try is another AC adapter if you can get a hold of one or purchase one if need be as it's the most likely source of the problem. More than likely it's providing enough power for the system to recognize it's attached and draw power from it, but there is likely a short inside it or the cords keep the power from being constant.
If you do not have a full adapter to test with, you can replace the end that plugs into the wall with and universal plug - something you can buy at major retail stores. The adapters take a lot of wear and tear and can be damaged from all the stuff we put them through.
Dec 25, 2009 | Computers & Internet
Toshiba a200 flashing power light .. blue blue red red HELPPPPPPP
Remove battery and power
Remove memory in lower socket, the one on the system board and try reboot with just power cord. May have bad socket
Dec 11, 2009 | Toshiba Satellite A200-0ET00X Notebook
Toshiba Satellite (K000004080) Motherboard Logo
174 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
