Question about Kenmore Humidifiers
Kenmore 3000 central humidifer motor # 416-025-20 needs to be replaced had united checked, service man told me that it has to be replaced. The Model # is Siebe 416-025-20
3 Suggested Answers
mastatech
  • 478 Answers
SOURCE: my forced air central humidification system does not work
you need tocheck for power at solinoid valve or continuity of valve where water enters the unit. THe furnace must be on and humidistat calling...
Posted on Mar 12, 2009
SOURCE: NEED MOTOR, EATON 416 025 20 FOR SEARS FURNACE HUMIDIFIER
It`s pretty expensive but Appliance Factory Parts has the same motor except at 24 volt and you have to use the gear from your old unit and a step down transformer..as yours is 115 volt..
Around $80 as they will combine the shipping if you call them..
Local electric motor shop repaired my 1994 motor for $35 after I explained to them I could not find a replacement..
I talked to Sears repair service man, he said our units are too expensive to produce today but are better than these new high flow models they use allot of water that just goes down your drain..
Posted on Nov 03, 2009
Service light on Honeywell humidifier
Sounds like a Water Level Sensor problem. Read the service manual, pages 51 and 53.
http://www.forwardthinking.honeywell.com/related_links/humidification/69_2285.pdf
Unplug the power cord. Turn OFF water. Remove the Water Level Sensor - One screw holds down the spring clip. Remove water scale in the compartment and on the Sensor. Test Sensor with an ohm meter. If OK, reassemble and try again. If bad, replace the sensor.
If you have heavy scale buildup in the sensor compartment, you need better water filtration. Your problems are just starting. This system can be very difficult to clean thoroughly.
Nov 15, 2012 | Honeywell Truesteam HM512W1005...
Wondering why this humidifer does not shut off.? It runs all the time. We don't have a manual for it.
Since it's a Kenmore, you can get an Owners Manual from Sears Parts Central. You'll need tohave your Model # handy.
Mar 29, 2011 | Kenmore Humidifiers
I am replacing a kenmore 3000 humidifier with a Honeywell HE360A. Can I use the same electrical wires for the hoenywell that are allready there from the kenmore?
How did your replacment turn out? I also have a 3000 and am looking for a replacment unit where I do not have to make a lot of changes.
Dec 11, 2010 | Honeywell HE360A1027 Whole House...
Mar 17, 2009 | Humidifiers
My forced air central humidification system does not work
Mar 12, 2009 | Humidifiers
Kenmore HW305 Humidifier putting out hot steam...Is that normal?
this is a steam and misting type humidifier, the water tanks will not heat up, the heating element is internal to the unit, just make sure you clean it periodically and I would suggest having a fan asst to help move the humidification around the room, hope that helps
Jan 20, 2009 | Kenmore Humidifiers
Loud noise
Replace the water valve... It"s vibrating when closing. Do you have hot water feeding the unit?
Oct 22, 2008 | Aprilaire 550 Humidifier
760 motor
I would say it depends on your mechanical aptitude. i do not think it is very difficult.
Mar 28, 2008 | Aprilaire 700 Humidifier
Vicks 5100 humidifer need help filling and operating
You can down load the manual in pdf format from this site:
http://www.amazon.com/Honeywell-V5100N-Ultrasonic-Humidifier/dp/B000056HL5
Scroll down to Product Manual [205kb PDF] & download.
If you do not have Adobe Reader which is used to read the pdf file you can download that from this link for free:
http://www.download.com/Adobe-Acrobat-Reader/3000-2378_4-10000062.html
I believe the manual will answer all of your questions..
Good Luck & Best Regards.
please vote...
Mar 06, 2008 | Vicks Ultrasonic V5100 Humidifier
Humidifiers Logo
546 people viewed this question
Top Kenmore Humidifiers Experts
Mack Baxter
ftykjg
ftykjg
julian hayes
julian hayes
Level 1 Expert
Are you a Kenmore Humidifier Expert? Answer questions, earn points and help others
