Question about Canon PC-941 Copier
My Canon - PC 941 keeps coming up with this error code "EO 10". Need assitance please. Thank you!
checkitright
  • 1362 Answers
SOURCE: canon pc-6re error code EO 10
E010 Clock pulses fail to be generated or the PLL lock fails to be released due to a fault in the main motor, etc. Related drum drive unit and main drive unit
There is a problem with the motor of the drum or the main motor itself.
Posted on Nov 11, 2008
  • 8 Answers
SOURCE: my canon copier PC-745 won't power up it has error code EO
i think the problems is in the delivery roll,the rubber is need to be change with the new one
Posted on Feb 04, 2009
  • 523 Answers
SOURCE: Canon pc-6re
hi do this to reset the fuser unit:
go to service level one by pressing  *28* then copier --function--clear--error-ok
if that doesnot work either replace  thermistor
Best regards
I’m happy to help further over the phone at https://www.6ya.com/expert/mustafa_06f84c65ab5cc745
Posted on Mar 02, 2009
goodgold
  • 389 Answers
SOURCE: Canon PC 941 copier. Paper jam indicated with no paper.
Can be that sensor of the passing of the paper or was broken off flag, or sensor has wedged in position james, more often such can be in block of the fastening, when paper stuck extract. Try its see, this possible behind do. Good luck
Posted on Sep 20, 2009
  • 4 Answers
SOURCE: Canon PC 940. replaced
the heat element is not heating up check the connections at either end of upper fuser roller. unpluging copier for 20 minites should reset the error
Posted on Aug 19, 2010
Error code eo
Hello Gary, I am happy to assist you! I see that your Frigidaire dishwasher is displaying error code EO; however, is it possible that the code is missing a number or character(s)? Typically error code "E0" is follow by another number. In the meantime, you can reset your dishwasher. This can be done by either unplugging it or flipping the household circuit breaker off. It is important to wait approximately ten minutes and then turn on your appliance. If resetting the power does not correct the issue, could you please advise me of the new error code or if it continues to display "EO"? With this information I can better address the issue at hand. Thank you! - Z
May 20, 2014 | Frigidaire 24 in. FDB1050REC Stainless...
I can not reset Eo on my canon pc 941
You don't. You have to replace the fixing film assembly of the copier. The fuser is not heating up correctly and is creating the error.
Apr 29, 2011 | Canon PC-941 Copier
How can I slove earror EO, in my BW PC-940
You can have this Error Code resolved, I am just not sure that it would be wise. These are the facts. You have a 10 year old machine which has an EO error code which means there is a problem with the Fusing Unit. The parts required to fix the error code are anywhere from $150.00 to $250.00 depending on if you go with the whole fusing unit or just the Fixing Film Assembly which is going to contain the defective part(s). There is some dis-assembly of the machine required in order to replace the parts. If you hire someone to do this you are looking at another $100 to $200 in labor depending on who you call. So you could easily spend $250 to $450 to repair the problem. These type of small copiers are sold brand new at Office Depot and other stores now days for $100.00. They will also have a USB port so you can hook it to a PC and use it as a printer. I am in the repair business and have been for 27 years. I would not recommend that any of my customers make a repair to this machine of this magnitude. I have in fact referred 2 of them in the last 5 months to go buy the new Canon D340 instead of repairing the old one.
Good Luck to you and Thank You for using Fixya.
WheatlandServices
Dec 23, 2010 | Canon PC-940 Black and White Copier
Canon copier 940 trouble code EO?
Odds are that you are getting a error code E000. It is saying that you have a problem with your fuser unit. You can try to unplug the copier for a short time. But you will mostly need a new fuser unit. Good Luck
Sep 07, 2010 | Canon PC-940 Black and White Copier
EO appears at switch on then machine switches off
EO is a error code. You have a problem with the fixing unit. You will most likely have to replace the Upper Fuser Unit....
Aug 21, 2009 | Canon PC-860 Black and White Copier
Canon ir 8500 error code 001-010 and E 001-003
You can start by downloading this software, a new driver dated April 7, 2009
canon driver for the ir 8500
Apr 15, 2009 | Canon Office Equipment & Supplies
My canon copier PC-745 won't power up it has error code EO
Feb 04, 2009 | Office Equipment & Supplies
Canon pc-6re error code EO 10
Nov 08, 2008 | Canon IMAGERUNNER 6570 Copier
Eo-10 code
hi im jules_09,no the copier is not dirty or jammed,if there is a paper jam it will indicate paper jam there is no error code for that,if the copier is dirty you can see it in the print.reset the error code in the program,if the error code is still there checkfusing unit then the optic sensor
Nov 02, 2007 | Canon PC-940 Black and White Copier
Canon PC-941 Copier Logo
65 people viewed this question
old marine
old marine
