Question about Vehicle Parts & Accessories
I have a 1997 BMW 540i and when I set my factory alarm everything is fine - however, when I return to the car to unlock the alarm goes off every time. I then have to press lock again and unlock and it then stops. What could the problem be?
I have the exact exact same problem! anybody know how to fix this?
Posted on Nov 26, 2010
Recommendation for replacing the catalic converters for 1997 MBE 540i
The average cost for a Catalytic Converter Replacement is between $552 and $1097. Labor costs are estimated between $196 and $248 while parts are priced between $356 and $849.Get a personalized estimate based on your location and specific car. Estimate does not include taxes and fees.
some good after market cats can be had for less then half the prices stated above. press the helpful button
http://www.autopartswarehouse.com/shop_years/bmw-540i-catalytic-converter-1997.html
540i Catalytic Converter options
1997 BMW 540I 4 4L V8 Catalytic Converter RockAuto
BMW 740IL Catalytic Converters
Feb 04, 2016 | Cars & Trucks
1997 BMW 540i will not back up, when you put it in reverse it feel like it catches then flattens out?
transmission, issues, A/T?
get it serviced .
1: check fuse first.
2: check fluid levels.
3: do the FSM book tests. (its in the book under on car service)
May 02, 2014 | 1996 BMW 540i
How to reset factory alarm in 1997 Chevy Suburban without a keyfob
to disarm the factory alarm try unlocking driver door with the key. does it blow the horn or does it have a siren?
Jan 25, 2014 | 1997 Chevrolet Suburban
540i starting problems
Check connection to the starter? Try it in neutral? Is there an alarm installed? Maybe active but on silent
Dec 23, 2013 | 1997 BMW 5 Series
1997 BMW 540i key gets stuck in on position but won't start the car
u need a new key or its the ignition its self if u go to the dealer ship u can buy a new ignition and the key comes with it or u can try a new key but if u buy a key its just as expensive as duying the whole ignition
Nov 12, 2012 | 1997 BMW 5 Series
2002 BMW 540I ALARM GOES OFF ALL THE TIME BY ITSELF
Have the dealer keep the car and run a scan test on the security system while this alarm issue is occurring, then they can pinpoint the cause of the false activation of the system. That problem will likely be one of the door latch sensors is failing.
Jul 17, 2012 | 2002 BMW 5 Series
I need to disable my alarm on a 1997 bmw 528i.
Now im not sure since the manual says your model has the same alarm system as the 328i and on the 328i you can remove the module to disable by doing the following. you can unplug the control module. It is located under the glove box. Climb under the dash on the passenger side and remove a few screws on the trim panel under the glove box. Theres a black control module with a green connector. There should be a lock tab on the connector. press the lock tab and pull out the connector. The alarm should now be disabled. But if it has the special transponder key this may not work.
But if the only reason you want to disable it is because of the motion sensor setting of the alarm for no reason there is a solution for this. To disable the motion sensor, hit the lock button to arm, then hit lock button again within four seconds to disable motion sensor. Red light on rearview mirror should flash four times, then pause, then start flashing on regular intervals. this is most likely the reason if your having the issue where the alarm goes off every 20 minutes.
If you want to completely remove it below is a wiring diagram taken from the manual for you alarm system.
this is from the manual its the alarm wiring diagram.
Battery Constant 12v Positive Wire ( ): Red/White or RedBattery Constant 12v Positive Wire Location: Ignition Switch Harness
Starter Positive Wire ( ): Black/Yellow or Black
Starter Positive Wire Location: Ignition Switch Harness
Ignition Positive Wire ( ): Green
Ignition Positive Wire Location: Ignition Switch Harness
Second Ignition Positive Wire ( ): Purple/White or Purple
Second Ignition Positive Wire Location: Ignition Switch Harness
Parking Light Positive Wire ( ): Gray/Purple and Gray/Yellow. Use Both Wires. This vehicle has a dual parking light system that will require 2 extra relays.
Parking Light Positive Wire Location: At Headlight Switch
Power Door Lock Positive Wire ( ): White/Red
Power Door Lock Positive Wire Location: At Factory Alarm Plug. The alarm plug is a black 12 pin plug located just behind the glove box.
Power Door Unlock Positive Wire ( ): Blue/Red
Power Door Unlock Positive Wire Location: At Factory Alarm Plug. The alarm plug is a black 12 pin plug located just behind the glove box.
Door Trigger Negative Wire (-): Brown/Gray
Door Trigger Negative Wire Location: At Factory Alarm Plug. The alarm plug is a black 12 pin plug located just behind the glove box.
Domelight Supervision Wire: Turns On With Unlock
Domelight Supervision Wire Location: N/A
Horn Negative Wire (-): Brown/Red or Brown/Yellow
Horn Negative Wire Location: At Steering Column Harness
Tachometer Wire Negative Wire (-): Black
Tachometer Wire Negative Wire Location: At Instrument Cluster
Brake Light Positive Wire ( ): Blue/Red or Green/Red
Brake Light Positive Wire Location: At Switch Above Brake Pedal
Factory Alarm Disarm Wire (-): Disarms With Factory Remote Only. Factory Alarm Disarm Wire Location: N/A
Factory Anti-Theft System: Transponder Anti-Theft System, Requires Bypass And Extra Ignition Key. The 1997 model year vehicle may require a bypass module and an extra ignition key, if vehicle is equipped with a special key from BMW.
Factory Anti-Theft System Location: Transponder At Ignition Switch Tumbler
if you require further assistance please let me know and i will help assist you from there. Thanks, Midwest-Tek
Aug 27, 2010 | 1997 BMW 328
1994 bmw 540I e34 alarm went off and the stereo asks for the code I enter the code but when I press to eject the tape the stereo asks for the code again and stops functioning. I've been listening to the...
1994 bmw 540I e34 alarm went off and the stereo asks for the code I enter the code but when I press to eject the tape the stereo asks for the code again and stops functioning. IS THERE ANYTHING SPECIAL THAT I HAVE TO DO AFTER ENTERING THE CODE TO COMPLETE
Aug 10, 2010 | Car Audio & Video
The alarm system of my 1997 BMW 740iL is really annoying. I try to turn it off, follow the instruction of my manual, by press the lock key again after I locked the door. However, the red light of the alarm...
Flashing light mean something is been tampered with on car, either locks, ignition, radio etc, Had similar problem, could only be reset with diagnostic computer.
Jul 10, 2009 | Pro-Fit Pro.Fit Bm 51 97 Bmw...
Vehicle Parts & Accessories Logo
122 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
