Question about Ridgid Wts2000l 10" Wet Tile/stone Saw Cash Saver Lk
No power from cord to machine....like a fuse is blown. Is there a fuse to replace or power protector?
  • 7,733 Answers
Try this link for a diagram->link.
Posted on Oct 06, 2010
Why would my Bernina 880, 10 months old, not boot up?
While the surge protector is an excellent thing to use, BERNINA sewing machines also have a set of fuses in the power supply. There is a chance that one of these fuses has blown. My recommendation would be to take your machine into your local BERNINA dealer to get it checked out. As long as you have checked the cord, the surge protector, changed plugs on both, and checked the circuit breaker in the house, it is probably an internal issue that is best fixed by a certified BERNINA technician.
You can find a nearby dealer, at the enclosed link or go to the store where you purchased your machine.
Find Dealer easily find your nearest BERNINA dealer BERNINA
Nov 02, 2015 | Bernina Sewing Machines
Why printer cant get power. is there a reset button. has the power save button got something to do with it .
I doubt that the fuses built into the machine to protect it somewhat from major power surges have blown although it is possible. First thing to check is that the power socket you use is ok. Try plugging another device into it like a lamp and see if that works. If it does then that is ruled out. Then check the power cord you use is ok. Try plugging in your printer to another power cable you know works (such as your desktop power cable) and turn it on. If it works then replace the cable. If it still is not working then it will be internal to the printer. Time to replace the printer. This time however be sure to get a surge protector for your printer (the device regulates power running through it and will even out any small surges and completely stop any major surges. The more you spend on the surge protector the better it is and generally the higher the insurance coverage is for devices using it if they are damaged.
Sep 07, 2014 | Brother MFC-685cw InkJet Printer
Dead Dirt Devil Featherlite
1. Power cord not firmly plugged into
outlet.
1. Plug unit in firmly.
2. Blown fuse or tripped breaker. 2. Check fuse or breaker in home. Replace fuse/
reset breaker.
3. Needs service. 3. Take to service center or call 1-800-321-1134.
4. Thermal Protector activated.
4. Unplug cleaner. Allow to cool for 30 minutes
Nov 03, 2012 | Dirt Devil Featherlite Bagless Vacuum...
I have a problem with the power supply board with my TV (Samsung LN46A750). I had a fuse blown and tried to replace it (with a like fuse, of course). Replacing that fuse and attaching the power cord let...
Power supply board have power surge parts,but not totally dead,it just giving to much power some where,that why it keep killing ur fuse.This problems,u must have great electronic skills to track it down.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.Power surges are rarely happen,but the surge protector will stop massive power will go the protector when it happen instead all the power will go to the tv itself.
Mar 16, 2011 | Samsung Televison & Video
When i turn on the cb it does not light up and no one can hear me.
Check the in line fuse to make sure it is not blown. I would also check the cb pa switch
Jan 27, 2010 | Cobra 19 DX IV CB Radio
Old uniden cb radio. i have plugged it in and i know i'm getting power through the cigarette lighter, but no power when i turn on the radio. no lights, no sound, nothing. please help. any ideas?
Hello there
There is a internal fuse on the inside of the unit that might need to be replaced and also check the fuse that is in the power cord ok?
best regards michel
Sep 14, 2009 | Uniden Radio Communications
My Wii console won't turn on.
Usually, after a power outage, a power spike (when the power returns) can disable/blow the fuse in the AC adapter for the Wii.
First:
- unplug the Wii's power cord from the wall, and leave it unplugged (from 5 mins. to 5 hours). Then, plug it back into the wall. (Unplugging the power cord from the back of the Wii will not help. You need to unplug the power cord from the wall.)
- This usually helps reset the fuse circuit in the AC adapter, and your Wii should work again.
- THEN, buy a SURGE PROTECTOR power bar, and plug all of your expensive items into it (to prevent this from happening again).
Second:
- open the panel on the AC adapter box in the power cord; since the screws are proprietary, you will need to creatively use existing tools to turn the screws
- check the 3A fuse in that box; if it looks blown, then replace it
Third:
- it might be cheaper to replace the AC adapter with another one
Fourth:
- get the unit repaired
Hope that helps!
Aug 09, 2009 | Nintendo Wii Console
My computer will not turn on it will not do anything, i remember hearing something blow like a fuse, it is connected to a surge protector it was the only thing that messed up
you fried your power supply inside the computer. check all connections and try plugging directly to known good outlet first. but it sounds like a blown power supply
Jul 16, 2009 | E-Machines eMachines Desktop PC
The tv died
My ilo Does This Every time We Have A Power Outage Did You Reset It????? Unplug The Tv And Hold Down The On Off Power Button For 30 Seconds Then Release And Plug It Back In And Check.
Jan 07, 2009 | iLO 3200 32 in. LCD Television
Emachine with XP home edition doesn't start
Hi hearalso, down to the basic's. Replace power cord.
No help there than, remove the case's side panel to expose the motherboard. (Normally it is the left side panel while facing the front of the PC.)
Look closely for a small (green in color) led light. The power cord must be connected to the PC & connected to you're power strip but do not press the power on button on the PC.
The green led tell's you the board is receiving 5volts. Check all connections. Un-plug & reconnect every data & power connector in your PC. (Double check). There is a fuse inside your power supply that may have blown. Check you're manual page, Approva Statements B-1. Fuse Warning Instruction Caution.
Check fuse in power supply. (Unplug power cord before opening).
If you can not power up the PC after all of the above than if possible, swap out the power supply.
Replacing the power supply is the last step.
If you have more questions, feel free to ask.
Good Luck!
Mike
Apr 09, 2008 | E-Machines eMachines Desktop PC
Ridgid Wts2000l 10" Wet Tile/stone Saw Cash Saver Lk Logo
212 people viewed this question
Top Ridgid Saws Experts
ken skalski
John Trevino
Are you a Ridgid Saw Expert? Answer questions, earn points and help others
