Question about KitchenAid KDRP463LSS Dual Fuel (Electric and Gas) Kitchen Range
Have a KitchenAid kdrp463 dual fuel range that is 6 years old. Last night the oven stopped working and it will not heat up at all. Gas burners and the griddle atop the unit work fine as does all other electric connections. Thoughts????
jsrock516
  • 5911 Answers
SOURCE: Gemini Range Dual Burner
Unfortunately, you cannot repair one element of a dual burner. It all comes as one unit. When one portion of a dual or triple element goes bad, you must replace the whole element. I believe the part number is 1032746 and runs about $70. You will have to lift the glass top to access the burner elements. If you decide to pursue this on your own follow these steps: 1. Unplug range and/or turn off main breaker. 2. Open oven door to access screws under front edge of cooktop. Remove two screws and the top should tilt up. 3. The top will not stay up on it's own, so you will need some assistance holding it up. Some ranges have a couple of disconnect plugs that you can unplug, so you remove the entire top and lay it somewhere to work on. If this is the case with yours (as I suspect it is), lay some soft towels down on the kitchen table or counter top and lay the cooktop upside down. This will make it much easier to work on. 4. Remove affected element by disconnecting the wires first. You may want to write down how they came off, so you can be sure to reconnect them in the right order. 5. Remove mounting brackets holding element in place. Pay particular attention to the numbering scheme on the bottom of the element and where the brackets are mounted. The new element usually doesn't come with new brackets which means you have to take the brackets off the old element and put them on the new element. Make sure you install them in the same numbered holes as they were located before. 6. Reconnect wires and reinstall cooktop, making sure you reconnect the disconnect plugs if equipped. Now, be careful when working on the cooktop while it is upside down. Make sure you don't apply too much pressure on the glass or you could crack it. Also, use extreme care NOT to touch the element surface as the oils from you hands can cause hot spots and effectively ruin it. The bake light material in which the element is mounted is also very fragile. DO NOT put to much pressure on it or it may crack and break. Once you get the cooktop reinstalled and power reapplied, op test it to make sure BOTH elements are working. It is normal to see a little bit of sparking at first with new elements and/or an odor. Test the entire range of the element and make sure it regulates like it should. I hope this helps you.
Posted on Aug 04, 2007
SOURCE: 8 year old kitchenaid gas range nom fire in the oven
I went to the kitchenaid web site for parts and found a trouble shooting section. I read about how a electronic glow coil works and discovered that mine was just old and did not reach the right voltage to open the gas flow valve.
Posted on Feb 21, 2008
SOURCE: garland range griddle top
I have a 48" Garland griddle 4 burner thermostat controlled and I can't have it above low all the way across because it is so hot it burns my eggs. I have 1/4 of the griddle I can cook an egg on, if I turn the griddle where it should be at 250,300,300,350 the whole griddle turns black. I need a repair man to turn down the temperatures that it is set on. please sent a reply to janmid_86@hotmail.com with all the repair companies that are available in around Orillia/Barrie Ontario Canada Thank you
Posted on Jun 04, 2009
tony2155
  • 64 Answers
SOURCE: range has error of stuck key
need to replace touch pad not cheat
Posted on Jun 23, 2009
SOURCE: kitchenaid gas range model KGRS807S - oven starts then stops
earl am16 error
Posted on Apr 16, 2010
How to fix gas burners
The electronics are controlled by AC using a simple plug usually. If you can locate the plug and reach it you may be successful resetting things by unplugging the cord, wait a minute or two and then plug cord back in. Try the burner controller again. If still doesn't work then controller module may need to be replaced.
Oct 14, 2014 | Dacor DR30DLP-H 30" Distinctive Dual Fuel...
Oven wont work everything else is fine
As your oven is electric there is a heating element in the oven, have a look in the oven to find it and check the little plug in caps on the end to make sure they are not loose. If they,re ok check the switch on the front panel sometimes the knob comes loose on the spindle if that's all ok it may be the switch has failed. Good luck.
Jun 16, 2014 | GE Profile JGSP44 Dual Fuel (Electric and...
I have 48 " 6 burner stove natural gas.Stove is
the glass in the ovens should not crack when self clean is used. it could be that there was a minut crack in the glass or a build up of moisture in between to door windows that expanded at the extra heat but this should be brought up with the manufacturer for replacement.
I hope this was useful.
Jan 05, 2011 | Viking 48" 6 Burner, Griddle Professional...
All 6 ranges and the large oven work well.the small oven won't li
My gas oven stopped working properly - called in the repair man and he replaced two of the three ceramic ignitors. (I have a two oven model). Apparently they only last / work well for 3-5 years. Kinda sounded crazy to me - but verified on the internet they are required to be replaced. Not sure I'd call the repair man next time - get the part yourself, one screw & two wires to replace. I'm no expert - but that solved my problem.
May 22, 2010 | DCS RDS-486GD Stainless Steel Dual Fuel...
Basically my gas oven is not heating up properly, the temperature is not hot at all, and food is not getting cooked properly
this is a milti burner unit / and sounds like the ignitors or weak / look below the oven door edge for a glow if orange there bad they need to be white hot .. burners may come on but not all the time .. ****
Dec 05, 2009 | Viking 48" 6 Burner, Griddle Professional...
Kitchenaid DF Range F04 error code
I have a dual fuel kitchenaid convection range and I put it in self cleaning mode last night. Afterwards it said F 04 on the display. The doors open again, but neither of the ovens work
Nov 17, 2009 | KitchenAid KDRP487MSS Dual Fuel (Electric...
Kitchenaid Model KGST307HBS5 intermittent will not heat up
the gas leak can be the safety valve. in side the oven where the burner sits on you have to remove the burner to get to it.
Dec 09, 2008 | KitchenAid KGST307 Gas Kitchen Range
Feb 20, 2008 | KitchenAid KGRA806PSS Gas Kitchen Range
GE Profile Spectra XL 44 gas oven
If you can smell the gas when you turn on the oven, it may be on a separate igniter that has gone bad. I would check this first. If you are not getting gas to the oven, there is possibly an issue with the supply line.
Sep 25, 2007 | GE Profile JGSP44 Dual Fuel (Electric and...
Open Questions:
See all KitchenAid KDRP463LSS Dual Fuel (Electric and Gas) Questions
KitchenAid KDRP463LSS Dual Fuel (Electric and Gas) Kitchen Range Logo
100 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
