Question about Maytag Refrigerators
I have a Maytag Frigerator/1998 MTB1553. It is leaking on the floor. How do I find the problem. Where is the drain hole and how do I get to it.
catriver
  • 878 Answers
SOURCE: Leaking on floor only after shuts down.
Griz, check the vent and see if you have bunch of gunk thats collecting water in it. Sometimes the spray arms are cracked and direct water into the vent. If this happens you will have leaking down the center of the door. Catriver...post back
Posted on Aug 14, 2006
  • 240 Answers
SOURCE: Whirlpool Cabrio Washer- When draining, water leaks out of hole
probably rubber hose from tub to pump broke, access from back or bottom, (cabrios are open bottom) pump in rear. there is a recent bulletin about tub ring not channeling water from dispenser completely into tub
Posted on Mar 14, 2009
kram26
  • 544 Answers
SOURCE: water leaking under frigerator on the left side
HI,
your drain is clogged. you may have a catch for your drain where you see leak coming from. that may pull off and you can see if their is trash build up in it. you are going to need to take the panel off the back of freezer. inside back of freezer you will see screws. they will need to come out, If you have ice maker that will need to be removed also. once back panel is off you will see your coils beneath the coils it will most likely have a sheet of ice. turn machine off and take a hair dryer and defrost the ice. once ice is gone take a cup of hot water and run thru drain to see if unclogged. repeat if drain is not clear. the ice in drain tube will eventually un clog. use a steamer. much quicker.
any further question let me know.
Posted on Mar 29, 2009
emissionwiz
  • 75235 Answers
SOURCE: 04 buick rendezvous drain tube holes
run a piece of wire down them, rebar works well for this
Posted on Sep 09, 2009
milten1
  • 1304 Answers
SOURCE: Maytag washer MAH6500 leak - door boot issue?
there is a drain hole at the very bottom of the sump
about 1/4 in
if you ahve any other holes you will need a new boot
there is no real way to patch them, most patches will not flex enough to stay in place
ive included the part number you can order from sears
22003070
the best way to get one over on sears is to order it
then you cazn either fix it kinda hard but id walk you through it
or when the part arrives shedule service, just tell them its leaking
only when the tech gets there tell them you have a boot
sears hates self diagnostics and you will go to the bottom of the list
Posted on Oct 07, 2009
How to access drain hole for maytag model mf12269vem3
please check your ice maker to make sure it is not jammed up water can leak into fridge
Nov 01, 2013 | Freezers
Freezer side of unit leaks water onto floor. this model does not have icemaker.
You have a clogged defrost drain tube. Look in the back bottom to see the drain trough, should have a hole for drain water. Pour a mixture of 1tbsp. eco friendly bleach and 1 qt. of water followed by clear water.
Dec 11, 2010 | Maytag Refrigerators
Found water leaking from our maytag side by side model MSD2142ARW. Disconnected ice maker 4 weeks ago thinking it was that, and still leaking and has ruined my new laminate floors. Is the freezer gasket or...
The defrost drain hole in the freezer side is frozen closed.
Turn off the fridge.Remove the bottom bin and look on the back wall of the freezer for the drain pan. It will have a block of ice in it. Use a hair dryer to defrost the pan AND the drain hole inside the pan,until you can pour a cup of water through the drain hole.
Dec 28, 2009 | Maytag Freezers
My Maytag wide by side is leaking water from the
Yes. Your defrost drain hole in the lower rear of the freezer is frozen over with ice. Turn off the fridge. Remove the shelves and bins from the freezer side. Break up any ice on the floor of the freezer and dispose of it. Use a hair dryer to melt the ice over the drain hole in the rear portion of the freezer. Once it is clear pour a 1/4 cup of bleach into the drain hole.
Dec 20, 2009 | Refrigerators
WATER LEAKING OUT OF FREEZER DOOR
The defrost drain hole in the bottom of the freezer has frozen over. Turn off the fridge. Remove the shelves and bins. Remove the rear panel of the freezer. You will see ice on the bottom rear of the freezer. Use a hair dryer to melt the ice,especially in the drain hole once you get through the surface ice. Once the drain hole is clear,pour a cup of hot water through the drain hole followed by 1/4 cup bleach. Re-install your parts and turn the fridge back on.
Sep 21, 2009 | Maytag MSD2454G Side by Side Refrigerator
Freezer leaks water even after water supply turned off
Remove the food from the lower portion of the freezer and remove the 2 screws which hold the rear freezer panel on . Remove the panel and use a hair dryer to defrost the ice built up over the drain . Once you see the black drain hole , concentrate on defrosting the hole . Once defrosted , the ice water will drain into the hole . I would use a small hose inserted into the drain and blow thru , to remove any debris built up inside the drain . Reinstall the panel and food .
Aug 09, 2009 | Maytag MSD2454G Side by Side Refrigerator
Maytag top laoder stacked washer LSG1000
If it only leaks in drain it has to be a hole in the drain hose or a plugged up house drain.
Dec 15, 2007 | Maytag LSE7806A Top Load Stacked...
Magic chef water running on floor, from under risper, i removed crisper did not see drain hole ice maker not hooked up
leaking from frig side or freezer side? If its freezer side the drain hole is behind back wall. Get you trusty blow dryer out...
Oct 16, 2007 | Maytag MZD2766GES Side by Side...
Refrigerators Logo
35 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
isaac johny
isaac johny
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
