Question about Sub-Zero 695/O Side by Side Refrigerator
Ice forms inside the refrigator in the middle on the left side about 6 inches in circumfrence
    Sergeant:
    Champion:
  • 351 Answers
It has lost it refrigerant that an ice ball from low gas
Posted on Oct 08, 2010
Where is the drain plug on the inside of my m.tag refrig. mod.MFI2569VEW
If the water is showing on the freezer side, more than likely you have a clogged drain. This occurs when the machine goes into defrost and the melted ice somehow is prevented from draining and therefor refreezing and blocking the drain for the next defrost cycle. The best way to resolve this is to unplug the machine for atleast 24-48 hours to let all ice melt. If thats not an option that you want to use the actual repair method would be to 1) unplug the machine 2) empty everything out of the freezer so you'll have room to work 3) take all the shelving and baskets out 4) locate the screws on the rear wall inside the freezer and remove them 5) take the back panel off exposing the evaporator coils ( the aluminum ) 6) directly below the coils is a trough of sorts and the drain is usually in the middle and runs out the bottom, remove the ice by carefully chipping it out or by using a hair dryer or hot water. 7) once all the ice is gone, the drain is visible and water can flow smnoothly down the drain dry the area and reassemble
Jun 02, 2012 | Refrigerators
I bought a maytag side by side in 2002; model # MSD2454GRQ, SN 18157432AL, REV # 18. Ice is forming at the bottom of the maytag freezer department. Overnight ice will form at about 1/8 inch and left has...
Defrost problem: 3 components. Defrost Heater. Timer (circuit board or motorized) & Thermostat.
Remove cover on the inside back wall (usually 6 screws). Note frost pattern. (bottom of evaporator coil)
Put refrigerator into defrost cycle and note the defrost heater come on, or not. (careful heater can glow red hot)... Unplug Frige and test defrost components. Replace bad component... Refrigerator should defrost every 8 hours. when the cycle slows or quits the freezer will freeze over the evaporator coil and no air flow = no cold air...
Nov 15, 2010 | Maytag MSD2756G Side by Side Refrigerator
No ice instead water dripping down into freezer making icicles
If you have icicles, where are they forming at? If on the front of the ice bucket, then look at the dispenser shoot door is closing all the way. The way to check that is to look into the shoot while holding a flash light (or bright light) up into the dispenser from the front side of door. You should see no light.
Now if you have ice buildup around the inside of bucket, mainly from the ice maker to the bucket then you either have an ice maker that is leaking water or you have a water valve that is not shutting off all the way. Suspect water valve if you have ice buildup within water inlet tube on top of ice maker. Frozen water within tube is good indication that water valve is leaking.
Look inside refrig side of refrig, usually located on right top side of wall, you will find a tag with model number and serial number. Need both to get you the right part number for ice maker or water valve.
Oct 08, 2009 | GE Profile PSW26P Stainless Steel Side by...
Freezer set to 0 actual temp - 1 Refrig side set to 37 actual temp drops to 30 and frezes items in refrig.
Set the refrig temp to 42 degrees . Also check to see if the damper (top left in refrig section ) is closing to stop the air flow into the fridge section . Sometimes they will stick due to ice build up inside the damper . Sometimes also , putting a knife inside and wiggling it around , will break it free , however , it may have to be replaced along with the #1 thermistor .
Aug 09, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Sub-Zero 690 Refrig Side Ice Forming on Back Wall
replacing leaking evaporator on Sub Zero Video
Jun 09, 2009 | Sub-Zero 642
Refrigerator doesn't defrost
theres a defrost control on the unit that is probebly bad. its in the upper right of the refrigerator aand depending on the unit is either solid state or mechanical
Mar 26, 2009 | Kenmore 53342 / 53344 Side by Side...
Freezer is freezing
common problem is part number 67003375 adaptive defrost control. also reccomend replacing part number 67003964 at same time. control located in refrige behind left upper panel. def therm clipds on evaporator behind panel in freezer.
Feb 06, 2008 | Amana ASD 2624 Side by Side Refrigerator
Sub-Zero 695/O Side by Side Refrigerator Logo
109 people viewed this question
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
ACME Sub Zero...
ACME Sub Zero...
Sal DeAngelo
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
