Question about Radio Shack Pro-97 Handheld Scanner
All channels locked tried to reset dosent work
  • 4 more comments
  • racilmah May 28, 2008
    should i take it back to radio shack
  • leesecw Jun 30, 2008
    i initialized my scanner, now it says all channels locked out. I tried entering pgm and then 1 and this doesnt work. Anyother solutions?
  • Anonymous Aug 11, 2008
    all my programed channels are lost... all the memory that I installed is gone and it does not scan any thing.
    the only message I get is: "all channels locked"
    this happens when the scanner is not "plugged-in"
    solution: re-program the memory??
  • rafeg Sep 21, 2008
    I like the scanner, I think, but its so user unfriendly, I'm getting pissed off to the point that I might just smash this thing to bits!
    the pro 97 says " all channels locked out" I have reset the scanner as per booklet but it won't clear! I am just about fed up with this piece.
  • Anonymous Sep 23, 2008
The best way to use this scanner, for the beginner, is to program a few frequencies. look up online the frequencies for your area. Usually two precincts per freq. then turn on the scanner, when it says "all channels locked" push "pgm" then the freq, xxx.xxxx, then press "ent" the scanner will then scan that freq. If you have too many freq's you will hear too many scattered reports, in other words durring the pause in conversation the scanner will move on to another broadcast and you wont hear the first broadcast in its entirety. when I first got the thing I figured I had to program all channels and sub channels and sub sub channels, its not that hard, I was over-complicating it! this is of course only one way to use this multi purpose scanner, and I am a beginner, good luck.
Posted on Oct 10, 2008
Yes, it fixed the problem,thanks
When turning it on hit the PGM then the number 1 that should fix it.
Posted on Jun 16, 2008
No sound through mic
what you should do is first check the volume and if that dosent work try reseting your computer
May 17, 2016 | Supersonic Sc-31 5.1 Channel DVD Player...
How to disabled key lock on ultra samsonic television
Hi, I don't actually know how to unlock your specific TV. But here is a basic guide to unlock your tv.
    1)Turn on the TV and grab the remote.
    2)Look at the screen. If you see a blank screen with a red key on the bottom of the screen, press 'Function' and 'Mute' at the same time. This should unlock the channel. This should unlock the channel. This is an option for people who want the TV to stay locked out, want to be able to bypass the lock to watch a certain show or channel. All others channels will remain locked and the TV will fully lock when it is turned off.
    3)Unlock all of the channels on the TV by entering the factory reset code. There are 3 main reset codes that TV Manufacturers set. These are 0711, 6688 and 3308. Try each one until you find the one that works. This will factory reset the TV.
    4)Call the technical support service number in your owners manual if none of those codes work. A technician can help you troubleshoot the television because the problem may not be the locking control. When you call, make sure you have the model number and the serial number.
    5)Or take it to a TV repair shop.
How to Unlock TV eHow
Dec 27, 2015 | Ultra Computers & Internet
My screen dosent work i cant unlock my iphone but the home button and lock button work help me
what has happened ?? just the screen has stopped try a reset hold both home and off button for 5 secs
Jan 12, 2013 | Apple iPhone Smartphone
How do you reset a trio stealth pro tablet after being locked out?
I have a trio stealth pro tablet and I'm lock out how do I get back in
Jan 10, 2013 | Tablets & eReaders
Need instructions to unlock channels. No lock code was put in and some channels are locked and say we need the lock code?
Try 0000 or try 7777.
If one of these codes work, you will asked to reset the code.
Reset the code but do not use 0000 or 7777 as the new code.
Good Luck.
May 17, 2010 | Televison & Video
Freeview has locked on one channel and won't retune
Used the solution of another user and it finally worked after a few attempts
Oct 01, 2009 | Samsung LE26R74BDX 26 in. HD-Ready LCD...
Lg vx 9900
first try the last 4 digints of your number if that dosent work then i would try calling custemer support
Apr 03, 2009 | LG enV VX9900 Cellular Phone
How do you reset a locked out channel when the code is forgotten?
Try pressing simultaneously the QV and 9 on the remote to bypass the parental lock. Then press the MENU button and go into the menu to turn the lock off. At least this is how it works on several other old Mitsubishi televisions. I don't have anything on ***********'s model, but this is worth a try. I hope it works for you.
Nov 12, 2008 | Mitsubishi Televison & Video
Locked out, channel or child lock how to re-set
I know one code please try if it helps 1 press mute button once on remote control handset. 2 once again press &HOLD remote hand set mute button. 3 while keeping mute button pressed press menu button on tv set. good luck
Sep 17, 2007 | Toshiba CF36G40 36" TV
Radio Shack Pro-97 Handheld Scanner Logo
428 people viewed this question
Top Radio Shack Radio Communications Experts
Greg Cann
Greg Cann
Are you a Radio Shack Radio Communication Expert? Answer questions, earn points and help others
