Question about Lanier 1205 Copier
The paper is coming out like a folded fan. - Lanier 1205 Copier
  • nall_edward Oct 06, 2010
    Thanks for the help. The copier is at church. I will work on tonight. I am sure this is the problem.
    Thanks
    Eddie
  • Lanier Master
  • 13,433 Answers
Hello.
This is probably because there is something that doesn't belong inside the printers paper path.
  1. Turn off the printer / copier.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Advanced
If that doesn't help then you would have to start taking apart the machine to find the object or source of trouble inside. A service manual would be recommended as the paper path has alot of small moving parts and taking apart the whole printer will be very complex, it will turn into alot of small parts.
It may be best to get a professional to inspect the machine, if you can't find whats causing it by opening all the covers and looking closely with a flash light or similar. I would not recommend taking apart the printer yourself too much as if not put back together the right way it might make the problem worse.
Posted on Oct 06, 2010
What is a paper folding machine?
This is a machine that folds papers or letters instead of you folding them all by hand. It can fold statements, invoices, brochures, etc. It's really useful for businesses. It can fold about 1800-18000 papers in a single hour.
Jan 17, 2013 | Office Equipment & Supplies
Persistent paper jams - is there a cheap solution or should I invest in a new laser printer? The paper jams/get stuck in the back and won't come out.
If they get stuck in the back, you could have a bad fuser.
If paper comes out the back and goes up towards the delivery assembly and then
starts to fan fold...the delivery assembly needs to be cleaned or replaced.
When you print the paper comes out the back of the printer thru the fuser and
up towards the delivery assembly and then into the exit tray. those are the rollers at the very top of the printer, in the back that need cleaning or replacing. A little alcohol on a cloth works pretty good.
Feb 21, 2011 | HP LaserJet 4 plus Printer
The paper is printed on but jams up into many folds and needs to be manually extracted.
this is a common problem the uuper fuser claws on the fuser unit are worn the paper folds like a fan replace the upper and lower claws on the fuser unit this will fix the problem
Jan 10, 2011 | Konica Minolta DiALTA Di200 Copier
When receiving a FAX or printing a receipt, it repeatedly jams. The paper is found inside the back cover baked into a folded fan shape.
This folded pattern indicates that the jam is being caused by a physical obstruction in the paper path section. I would suggest manually feeding a thick piece of cardstock paper and seeing if you can find the location of the jam, as it is most likely a piece of trapped paper or plastic tab that has come out of its original position.
-David.
Nov 05, 2010 | Brother IntelliFax-2820 Laser Fax
The cooling fan does not come on , but will come on with a/c
I believe the fan should only come one when the engine is getting hot. not at idle
Feb 23, 2010 | 1997 Chevrolet Cavalier
The paper fold when i print documents from pc? why?
the printer roler settings have changed or the roller has gone faulty ... get the printer serviced
Jan 12, 2010 | Brother MFC-7220 All-In-One Laser Printer
HP Laserjet 4M makes accordion folds in the paper before jamming
I have found that with laser printers that have an occasional "crinkle" problem that "fanning" the paper does alleviate the problem ... but it will not if there is an actual feed/hardware problem with the rollers
Mar 13, 2009 | HP LaserJet 4M Printer
Paper fan folds inside the fax machine.
THERE IS SOME THING BLOCKING THE PAPER PATH, MAY BE PAPER OR SOME THING FELL IN THE MACHINE GOOD LUCK BROTHER TECH
Jan 27, 2009 | Brother FAX-2920 Plain Paper Laser
Martin Yale Paper Folder Problem
Im not familiar with a paper folder but if its anything like a printer, it probably has a maintenance kit you can buy or you may have to replace the rollers. Alot of the times they have a rubber grabber that wears out or a roller that gets dirty and doesnt catch the paper evenly and pulls it through at an angle, crinkling it. Check for debree or paper particles that may be floating around inside.
Jan 02, 2008 | Computers & Internet
Paper jam in a Dell 1710
This is a terrible terrible printer. Aside from taking the printer apart it seems like your only option is to pick the paper out bit by bit with needle nose pliers.
Dec 12, 2007 | Dell 1710 Laser Printer
55 people viewed this question
Top Lanier Office Equipment & Supplies Experts
George Mclaughlin
Anthony Karuku
Are you a Lanier Office Equipment and Supply Expert? Answer questions, earn points and help others
