Question about Denon AVR-2807 Receiver
HDMI connection??? Can't get connection with HDMI 1 or 2 with DISH and DVD. Works good with componet cables. I understand how much I don't know and would appreciate any help!! Thanks, Greg
  • gvstone Nov 06, 2008
    This is where I ended up with it, I do appreciate your help!!
    greg
    Scholar:
  • 93 Answers
Hi Greg,
Again, if you have a high definition dish box with HDMI output,and a dvd player with HDMI output,please connect them both directly to your TV HDMI inputs.
When watching TV(dishnetwork box).remember to switch the HDMI video inputs.
Same as your DVD player,you need to switch it under your TV video input.
solutiondoct
Posted on Nov 06, 2008
Toshoba tv dvd combo picture on my tv will not work but picture on the dvd works great
I assume you mean you have a Toshiba TV with a slot for DVD play also. You don't say whether your TV is connected to a dish, cable box or antenna. Regardless of which it is, the fact that the TV produces a good picture on DVD but not on regular TV means one of two things: Either you have the TV hooked up incorrectly OR you do not know that you must change the SOURCE from DVD to TV to get a picture. That is done on the remote with the source button. Typically, the remote will have DVD, TV and AUX (one or more) as you cycle through them by simply pushing the source button again and again, If that doesn't work, you've got the TV hooked up incorrectly and/or it just happens to be set at DVD for the source. Normal hookup would involve HDMI out from the cable box, dish or whatever to HDMI in to the TV. Play with the remote "source" button. You'll figure it out. . .
Jul 02, 2017 | Televison & Video
I have a Samsung LCD TV model #LN46B301FUZA, a dish VIP622DVR a pioneer VSX-D307 reciever and a Pioneer DV-414 DVD player that I am trying to get hooked up. The Dish tech hooked up the TV and DVR using a...
I can't find your TV model to have a look at the manual. Normally you'd use a 3-plug RCA cable (Red, White, Yellow) to connect the audio and video outputs of the DVR to an RCA input on the TV. Then, hoping you have RCA OUTPUTS from the TV, you'd use a 2-plug RCA cable to take an Audio OUT from the TV into one of the receiver's Audio inputs (assuming you want to play TV sound through the receiver.
If you have no RCA inputs on the TV, you can get an RCA to HDMI Converter from Amazon for $10-$15 to convert the output of the DVD player from 3-plug RCA to HDMI, then put that into one of the HDMI inputs on the TV. Likewise, if you have only an OPTICAL audio output from the TV you can get a converter for that -- Optical audio to RCA stereo -- and put that into your receiver as an input.
Jan 20, 2018 | Pioneer Computers & Internet
No signal
When your television reads no signal, is simply means it is not reading any information from any device. If you have a cable connected to it and it is showing the 'no signal' display, then you need to understand that either the cables are not connected properly or the dish is not working properly.
Try to test a DVD player on the television, if it still shows the no signal, then it means the inlet/port that you connect your cable is bad, but if it works, then you know that the problem is from the box or the dish.
First re run the cables from the box to the television to see if it works, then try out new cables, if it does the same, then you will have to contact the customer care service of the dish provider for assistance.
Take care and good luck
Dec 13, 2010 | Proview PA-32JK1A 32 in. LCD Television
I cannot get the Input 3 HDMI port to work. The Input 3 Componet videoworks, but when I unplug the componet video and put in HDMI port nothing works. I do have something else in the HDMI Input 1 port...
Hi.
To start ensure that each time you connect or disconnect the HDMI ports both TV and connected device are off.
Also ensure that HDMI input is active, as detailed here.
HDMI connectors carry voltage, and connecting the HDMI cable while TV or device is on may easily damage the HDMI port, making it unusable.
The HDMI 3 and Component 3 are separate input. The component input may work, and HDMI port may still be defective.
To test the port do the following:
Disconnect TV power cord, and connected device (eg. Receiver, DVD etc.).
Leave units disconnected for five minutes.
While power is disconnected, test connecting on port three a device that was previously working on HDMI 1. Also use a cable that you know is working.
Connect back power with HDMI cable already connected. If HDMI 3 is still not detected, then the port is defective.
In that case ring Pioneer at the number listed on the owners manual.This model is often advertised as only two HDMI inputs. Call Pioneer to ensure the third port can be enabled.
Dec 26, 2009 | Pioneer PDP-4350HD 43 in. Plasma...
Xbox and dish network problem
if you have like a dvd player then try hooking the xbox up to it in the front where the video is for the 3 plugs then try to plug dish network in the back of the dvd where the ant in plug is at then take the cord from the dvd player and plug it in the back of the tv if this dont work let me know
Aug 08, 2009 | Microsoft Xbox 360 Console
Tv has sound but no picture.
If it works on DVD but not on your Dish, and when you connected it to another house it had the same problem then it sounds like your input connection is bad on the TV. That is if I am understanding this right. From what I am reading your Dish network is not showing a picture but the audio is working fine. The DVD player works fine on the TV though. Then you took the TV and hooked it to another dish system and it was the same problem. That sounds to me like you TV is having a problem, either that or the cables for your Dish network are bad. Try switching to a different input, like the one the DVD player is on and seeing if it works there. If not, then the cables are bad and you just need to replace the cables. If it does work though where the DVD was working before then your TV input is bad on that port you were hooked to before.
Let me know if you have any other questions and if this was helpful. If you need some more clarification let me know, I hope this is helpful. Good luck and have a good weekend. Get it fixed before the Super Bowl.
Jan 25, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Hdmi switcher
First check individually if they work ,then connect to HDMI switch ,then change the position of the switch if it is a manual switch or connect the cable to the dish and check the dvd works...............
May 29, 2008 | Toshiba HD-A2 HD-DVD
AVR 1508 Reciever Setup Issue
AVR 1508 doesn't upconvert. Only components coming in on HDMI will go out HDMI.
Nov 28, 2007 | Audio Players & Recorders
Denon AVR-2807 Receiver Logo
299 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
