Question about Hobart HL600 Legacy Stand Mixer
Can a three phase 440 volt h-600 mixer be re-wired to at three phase 208 volt
  • Hobart Expert
  • 119 Answers
No sir.
Posted on Nov 02, 2010
My Hobart h-600 is going backwards??? The peg is goin clockwise?
If your mixer's power is three phase, switch any two of the power leads to get it to run, turn the other way
Aug 18, 2015 | Hobart Food Mixers
I have Hobart D300 mixer which operates at 220V, 3phase supply and whereas the facility has 208V, single phase supply. Is there any recommended phase converters available for this product. Thanks
Hi Bill
I may be wrong here......
But I've been around Electricity for a long time.
Have Never seen a device that does phase conversion.
A Building site or home will either have Three Phase or Single Phase Power Available
BUT...A portable (Hired) generator could be "three phase" and you could use any one of those phases individually or all three phases.
I have 3 Phase supply to my house!
But I use 230 volt Single Phase for appliances.
My Bore Pump uses a 3 Phase Motor,
(so with a voltmeter it would read about 440 vAC to the pump motor).
Some Further Info:
A GENERATOR is basically a motor used the opposite way. Rotate a motor and it Generates.
The Phases refer to the THREE Windings in the supplying generator in your suburb.
A Large Magnet passes each winding in sequence giving you the three ripples in the supply.
Our houses can choose to have 1 Phase or Three Phases from the street when you set up your electric supply.
So... to confirm, look at the wires on the supply poles to the premises. Usually three in our area (Oz)
Most people are not aware that a car Alternator is actually three phase. The Rotor is the magnet that rotates.
The only difference with an Alternator is that each "Phase" is connected to 2 Diodes (6 total) to convert the three phase to DC to charge the vehicle.
The Regulator controls the voltage to the Rotor, thereby controlling the output.
So.... An Alternator could in theory supply 3 Phase in a mobile generator. Custom Made. Constant speed would determine the frequency of 50Hz or 60Hz.
Not sure what country you are in
Hope this Helps or gives you food for thought!
Three phase electric power
Jul 08, 2015 | Hobart Food Mixers
How do I reduce single phase voltage from 250 vac to 208 vac? I measured the voltage coming from the power company and I have 125 volts on each hot leg of the circuit. The mixer will stop after only 2 or...
Your mixer is 208vac? If it is 120vac and you are trying to run it on 250 I'm supprised you haven't burned it up. If indeed it is a commercial mixer with a 220vac motor I don't believe the difference is a problem. There may be a problem of ground. Some of our machines (if new) are so demanding of every thing being just right, it may detect there is no ground and shuts down as a result.
Mar 24, 2015 | Food Mixers
Three of my hobart mixers are spining wrong what is the problem
These must be 3 phase mixers (electrically there are two choices, single and three phase) Three phase cables typically have 4 wires, black, white, red and green (green is ground of course) To reverse the rotation of your mixers you would have to swap two of the three colors, and it doesn't matter which two of the three you choose, DO NOT SWAP THE GREEN, LEAVE IT ALONE. for example, just change red and black wires where it they connect to the plug. Of course turn off the power, unplug the the mixer, and usually you can take the plug apart and reverse the wires. If your units are hardwired you should call an electrician in to do it, it will only take a couple of minutes. cf652f29-33fe-4eee-8e37-1addfd1bcb1a.jpg aec28350-7e8b-4d45-a617-78e7a23dbf21.jpg
Sep 04, 2013 | Varimixer W20J Stand Mixer
Taking my P660 out out a building with 3 phase power and into one with only single phase. Converter says motor will run on 2/3 power. Good or bad idea????
Good!
MOTOR:
21?2 H.P., Hobart designed, high torque ball bearing,
ventilated within mixer enclosure. Single-phase is
capacitor-start, induction-run type.
Three-phase is
polyphase squirrel cage, induction-run type.
Single Phase 208V 20.0 Amps
240V 17.0 Amps
Three Phase 208-240V 8.6 Amps
Nov 26, 2010 | Hobart P660 Stand Mixer
I need a wiring diagram for the Hobart H600 which has a multi tap motor on and i would like to change the voltage on the motor to 200volt single phase 120/208 or even 120208 3phase. The wiring diagram is...
You cannot wire a three phase motor for single phase and you cannot wire a single phase motor for three phase. If you have a three phase dual voltage motor your options are 220 or 440 volts. If you have a single phase dual voltage motor your options are 120 or 240 volts. A 208 volt Hobart motor will only function correctly on 208 volts and is not dual voltage.
Aug 05, 2010 | Hobart H600 Stand Mixer
Only have two phase power power company refuses to install three phase can i run my hobart h600-t mixer serial#31-1068-582 ml# 104385 with just two phase?
first thing, there is no 2 phase pwr. there are only single phase or three phase.you have 2 choices either you can convert mixer from 3phase to 1phase which will be expensive, or you can get a rotophase which will make 1phase pwr to 3phase pwr to run mixer, dont go with static phase inverter, only the rotophase inverter
Jan 19, 2010 | Hobart H600 Stand Mixer
Electrical connection of hobart h600
it requires 3 phase with ground it is a four wire system
Jul 24, 2009 | Hobart H600 Stand Mixer
95 year old hobart mixer: two pole single throw switch
Im a tech for hobart and have seen old mixers but not that old.Hobart wont have parts but you could goto an electrical supply place,take the switch and ask them for something universal.
Dec 16, 2008 | Hobart HL600 Legacy Stand Mixer
Hobart HL600 Legacy Stand Mixer Logo
119 people viewed this question
Top Hobart Food Mixers Experts
Ross Keen
John Tripp
John Tripp
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Hobart Food Mixer Expert? Answer questions, earn points and help others
