Question about GPS
My nuvi 650 na is not chargeabl and screen dosn't show up any map touching , where to? view map, travel kit, no working clock is work and also screen is on &off, pleas solve my ploblem
  • ehnsuluke Oct 06, 2010
    GPS 650 na When the power swich turn on .screen light is on turn off light is off when the power
    on sceen show up 1, where to ? 2.View Map 3.Travel Kit when I touch three of one It dosn't
    work those function stop
    President:
  • 2,777 Answers
It sounds like the unit has failed... I am a bit confused by your question though. So you do get the display to come on? Or does it not even turn on? And it won't charge at all?
Let me know
Tim
Posted on Oct 06, 2010
  • Tim Grayson
    Tim Grayson Oct 06, 2010
    Ah ok I understand a little better what you mean here. That means the internal processor for your Garmin has failed unfortunately. There is no real fix for the unit. I would call Garmin to see if they can repair it under warranty (I think the warranty is 2 years on this unit). Their number is 1-800-800-1020
    Let me know what they say, but your unit is completely failed for sure, no easy fix on this one. You may be better off just replacing it if they can't fix it for you.
    Tim
I have a garmin 1350 that shows only Russian? How do I change it to english?
i have a garmin Nuvi when i turn it on i select agree it loads up all maps then it opens with 6 separate screens select locale you should see at the top of a list A with country and languge press thst to change you the languge also
agree and loads up the maps then it will have 3 options where to view map and travel kit press travel kit then it has 2 more options words and phrases and bilingual dictionaries press bilingual dictionaries there you will see translation of english to spanish french german and many other countries
hope this helps
Jun 27, 2011 | Audio Players & Recorders
Garmin 660 opens to where to/view map/travel kit/after that touch screen does nothing.good battery an ant signal.thanks
This is a well know issue with this unit and caused by a touchscreen failure. Please see this link for more info. Too much info to retype here:
http://www.sharc.net/gps_LCD_repair.htm
- Jim
May 27, 2011 | Garmin Nuvi 660 GPS Receiver
Touch screen not responsive after speaker replacement It worked before speaker replacement.
To calibrate the touchscreen on a nuvi 300 or 600 series:
1. Power the unit On.
2. From the Where to? / View map screen, touch Settings (wrench icon).
3. Touch Display.
4. Touch Recalibrate.
5. A new screen will display that says Press Dot.
6. Touch the center of the dot.
7. Keep touching the center of the dot as it moves around the screen.
8. When Calibration Complete appears on the screen, please touch OK.
The touch-screen will now be recalibrated.
Nov 04, 2010 | Garmin Nuvi 360 Bilingual GPS Navigator...
MY GARMIN NUVI 650 NA SUDDENLY STOPPED WORKING. WHEN I TOUCH THE SCREEN NOTHING HAPPENS... (THIS MACHINE HAD BEEN WORKING SINCE 2007). PLEASE HELP
Is it charged? If you are using the cigarette lighter adapter plug, there is a fuse in the silver tip of plug...... unscrew it carefully..its spring loaded... check fuse
Oct 27, 2010 | Garmin Nuvi 660 GPS Receiver
I have a garmin nuvi 660. the touch screen isn't working
  3. Touch Display.
The touchscreen will now be recalibrated.
If your touchscreen is not responding to any touch and preventing you from recalibrating the touchscreen using the instructions above, please follow the steps below:
  1. Connect your nuvi to your computer with a compatible USB cable.
  2. Open the Garmin Nuvi drive located in MyComputer/Computer. (Note: Mac users can locate the Garmin Nuvi drive icon on the Desktop.)
  3. Open the Garmin folder.
  4. Locate and delete the GUPDATE.GCD file.1
  5. Safely disconnect your nuvi from your computer.
  6. Power the nuvi Off.
  7. Power the nuvi on by holding the power button.
  8. Continue holding the power button down for 1-2 minutes until the screen calibration option displays.
  9. Touch the center of the dot as it moves around the screen.
  10. When Calibration Complete appears on the screen, please touch OK.
The touchscreen will now be recalibrated and should respond properly.
Oct 24, 2010 | Garmin nuvi 650 GPS Receiver
I have a garmin nuvi 660 it says "the screen is currently locked. press the power key to unlock." I have done this several times and even loaded up the latest software. I still get this message. When...
The on / off switch on top has 3 positions, it locks all the way right, when the unit is on make sure you have it in the middle.
There are icons near power button that indicate right side lock.
Oct 10, 2010 | Garmin Nuvi 660 GPS Receiver
Nuvi 650 touch screen stopped working
My Garmin Nuvi 650 would boot up and load maps, but I could not enter my access code. Screen would not respond. Turned off & on a number of times, but still same problem. This occurred on first use after upgrading the maps. Thinking it may have overheated on the dashboard of my truck, I held the device in front of the air conditioner vent for about five minutes to cool it down. When I then turned it on, it worked fine. For the rest of my 3-week vacation, I kept it cool & out of the sun when it was not turned on. No problems after that.
Jul 17, 2010 | Garmin StreetPilot c340 GPS Receiver
I have a garmin nuvi 360. I want to know if you can send me instructions for it for free and my question is. When I turn on my gps unit, why wont it just bring up where I am and just show where im going....
www.garmin .com
they have a downloadable user/owners manual section.
In the search field type in the model number and what you want. I did it for mine and got my manual.
Aug 28, 2009 | Garmin Nuvi 360 Bilingual GPS Navigator...
Touchscreen not responding.
There are three levels of fixes, please try them in order:
1. Reset the GPS using the Reset button, on the back, just under the Antenna Hinge. Resetting will turn off the GPS, and then turn it back on, if connected to power. Test, if fixed, great, otherwise, go to fix 2.
2. Turn the power off, then press and hold the powerbutton for up to 2 minutes. The GPS will turn on, and display a "PreBoot Mode" message. When that message disappears, and the screen calibration screen appears, follow the on-screen instructions, and you are fixed. If you still cannot use the touch screen, repeat fixes 1 and 2 several times, just to be sure., then go to fix 3
3. The touch-screen glass has probably broken or lost its connection with the GPX motherboard. You can order new touch screen glass on the web and install yourself, if you are techy in nature, otherwise do a search for "garmin nuvi 660 repair" and choose your service.
Jun 19, 2009 | Garmin nuvi 250W GPS Receiver
GPS Logo
23 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
