Question about D-Link DI 514 Wireless Router (DI-514)
When i follow the setup cd to configure my router to my computer it works until the last step where its checking the internet connection and then i just get an "ERROR. please try again" some advice on the subject would help thank you.
  • D-Link Master
  • 7,733 Answers
This link is a simulator that give the configurayion as you perform as usual---------->LINK.
Posted on Oct 06, 2010
Cable modem internet works when directly plugged into desktop, but when run through the router, no connectivity
Most cable Internet Service Providers (ISP) use a Media Access Control (MAC) Authentication to establish Internet connections for end-users. A MAC address is a unique 48-bit (6-byte) integer that is attached to an Ethernet NIC for each computer. To set-up your Linksys router to a Cable ISP, you have to do MAC Cloning. MAC Cloning is a procedure which enables a router to copy the MAC address of the PC that's registered with the ISP.
To setup a Linksys router with Cable connection you need to perform five steps:
  1. Verifying Internet Connection
  2. Connecting the Devices Together
  3. Checking the Router's LEDs
  4. Configuring a Linksys Router for a Cable Connection
  5. Power Cycling
NOTE: Before proceeding, use the computer that can go online when connected to the modem and follow the steps below.
Connect the Broadband modem to the computer using an Ethernet cable without the router installed and make sure that the Internet connection is active. If it is not, contact your ISP. If it can go online, the PC connected to the modem is the one that's registered with the ISP.
kb4682-001_en.png NOTE: The image may vary depending on the computer and modem you're using.
Once an active Internet connection is established through the modem, connect the modem and the computer to the router by following the instructions below.
After ensuring that you have an active Internet connection, connect the modem to the router's Internet port and the computer to any of the four Ethernet ports. For instructions, click here.
After connecting the devices, check the LEDs by following the instructions below.
The Linksys router's front panel will indicate the status of the connection. After connecting the broadband modem to the WAN or Internet port, the computer to an available numbered port and powering on the router check the lights on the front panel of the router. For instructions, click here.
After checking the router's LEDs, configure the router for cable Internet. For instructions, follow the steps below.
kb4682-002_en.png For Telstra Cable internet users, please contact Telstra to confirm if your internet connection is using DHCP or HB (Heart Beat) signal. There should be no other machine running HB client upon doing this procedure.
Step 1:
Access the router's web-based setup page. For instructions, click here.
NOTE
: If you are using Mac to access the router's web-based setup page, click here. If you forgot your IP address, click here. If you forgot your router's password, click here.
Step 2:
When the router's web-based setup page appears, click the drop-down arrow under the Internet Connection Type field and select Automatic Configuration - DHCP.
(a) If you are NOT using Telstra HB, proceed with DHCP setup.
NOTE: If you are a Telstra Cable internet user and you're using WRT120N, WRT160N v1, WRT320N or WRT610N, please select Telstra Cable.
(b) If you are using Telstra Cable, proceed with the following setup. Obtain your user name and password from Telstra. Please disable any HB client that might have been previously running on the PC after the router is configured.
Step 3:
Click kb4682-005_en.png.
Step 4:
Click MAC Address Clone.
Step 5:
Select Enabled and click Clone My PC's MAC.
Step 6:
Click kb4682-012_en.png.
Step 7:
Click Status. Check the value of the Internet IP Address. If the Internet IP Address has numbers, this means the router has been properly configured. You should now be able to access the Internet. If you're not online, perform a power cycle to synchronize the router with the modem. For instructions, click here.
NOTE:
If the Internet IP Address is all zeroes (0.0.0.0) click kb4682-008_en.png first then click kb4682-009_en.png. If the Internet IP Address is still all zeroes (0.0.0.0) perform a power cycle. For instructions, click here.
If the IP Address starts with 192.168.1.xxx or if it has the same first three numbers (octets) as the router's IP address, change the router's LAN IP address to a different LAN segment. For instructions, click here.
Once the router is configured, perform a power cycle. For instructions, follow the steps below.
Power Cycling
Step 1:
Shutdown the computer.
Step 2:
Unplug the router's power cable.
Step 3:
Unplug the Broadband modem's power cable and wait for 30 seconds.
Step 4:
Plug in the Broadband modem's power cable and wait for its lights to appear stable.
Step 5:
Plug in the router's power cable once the modem's lights appear stable.
Step 6:
Power on the computer on and test the Internet connection.
NOTE: If you're not online after performing this procedure, you may need to upgrade the firmware of the router.
Sep 28, 2010 | Linksys Wireless-G WRT54G Router
How to instal printer on dilink dir-888
i 1 D-Link DIR-855 User Manual 0
Section 2 - Installation
If you are connecting the router to a cable/DSL/satellite modem, please follow the steps below:
1. Place the router in an open and central location. Do not plug the power adapter into the router.
2. Turn the power off on your modem. If there is no on/off switch, then unplug the modem’s power adapter. Shut down your computer.
3. Unplug the Ethernet cable (that connects your computer to your modem) from your computer and place it into the Internet port on the router.
4. Plug an Ethernet cable into one of the four LAN ports on the router. Plug the other end into the Ethernet port on your computer.
5. Turn on or plug in your modem. Wait for the modem to boot (about 30 seconds).
6. Plug the power adapter to the router and connect to an outlet or power strip. Wait about 30 seconds for the router to boot.
7. Turn on your computer.
These instruction are on the CD that came with the router
Here is the start:
D-Link DIR-855 User Manual 13
The DIR-855 includes a Quick Router Setup Wizard CD. Follow the simple steps below to run the Setup Wizard to
guide you quickly through the installation process.
Insert the Quick Router Setup Wizard CD in the CD-ROM drive. The step-by-step instructions that follow are shown
in Windows® XP. The steps and screens are similar for the other Windows operating systems.
If the CD Autorun function does not automatically start on your computer, go to Start > Run. In the run box type
“D:\DIR855.exe” (where D: represents the drive letter of your CD-ROM drive).
When the autorun screen appears, click Install Router.
Section 3 - Configuration
Configuration
This section will show you how to configure your new D-Link wireless router using the web-based configuration utility.
Web-based Configuration Utility
To access the configuration utility, open a web-browser such as Internet Explorer and enter the IP address of the router (192.168.0.1).
Select Admin from the drop-down menu and then enter your password. Leave the password blank by default.
If you get a Page Cannot be Displayed error, please refer to the Troubleshooting section for assistance
Click Launch Internet Connection Setup Wizard to begin.
If you want to enter your settings without running the wizard, click Manual Configuration and skip to page 19.
follow the prompts.
You also can go to D-Iink.com for setup instructions
Apr 20, 2010 | D-Link DIR-855 Wireless Router
My router was working fine until I upgraded from Vista to Windows 7 and then tried 192.168.1.1 to check my router settings and I went to a google search page and not the router configuration so i used the...
HI Friend
1. Turn on the router and connect the desktop to router
2. push and press the reset button,which is at the back of router, for 30 seconds and after that turn off the router for 30 seconds and turn it on after 30 seconds.
3. Now open 192.168.1.1 and check your router settings.
4. If the internet does not works then in the router setup page click basic settings, click MAC address clone
5. Select the enable button and click the Clone tab. Click save settings and turn off the router for 30 seconds.
Enjoy
Regards
Chiranjeet
Dec 27, 2009 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
Wireless router 300M no acces to the internet
You need first to configure the router to work with your modem, if you have the setup CD of the router just that one and then follow all the steps on the setup CD after you're done running the setup CD of the router power down modem and router for 1 minute then plug the modem first wait for about 30 seconds and then plug the router back , after that check if internet is already working........
Nov 07, 2008 | Sitecom xDSL/Cable Broadband Router DC-200
Set up my belkin g router
You may have to configure the belkin router depending on the type of ISP that you have.
Basically, you can do these to configure your router:
1. connect the computer to the numbered port of the router and connect the modem to the internet/WAN port.
2. turn off the modem, router and the computer for 30 seconds
3. turn on the modem first, wait for the lights to stabilize then turn on the router, wait for the lights and lastly turn on the computer.
Sep 04, 2008 | Belkin (F5D7230-4) Router (587009)
Configuring the BEFW11S4 for the first time
To configure your router to share your Internet service, please follow the steps below: 1. Check with your Internet Service Provider to make sure that service is active. You usually can determine a good link to the service if you can bypass the BEFW11S4, plug directly into the ISP modem unit, and get a good connection. 2. While plugged into your provider?s modem and able to get online, run the bundled Router Setup Wizard CD-ROM program that came with your router. This will configure the router automatically for you. 3. If the Setup Wizard CD-ROM from Step 2 fails to configure your router, you may need a manual configuration. While plugged into the provider modem unit and able to get online (Step 1), visit http://kb.linksys.com, and search for the name of your Internet service provider for detailed instructions on manual configurations. 4. Once one computer is able to access the Internet through the router, the router will then be configured. Other machines can now connect to the router without re-configuring it a second time. 5. If you are still having difficulties setting up your router, please contact Linksys Technical Support so that we may further assist you.
Feb 16, 2006 | Linksys BEFW11S4 802.11b Wireless...
D-Link DI 514 Wireless Router (DI-514) Logo
24 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
