Question about Panasonic PT-47WX49 47" Rear Projection Television
Moving TV Would it damage the TV if I laid it on it's back side for moving purposes? My vehicle will not accomodate the the tv standing upright
  • Panasonic Master
  • 8,617 Answers
No it doesnt hurt them. I transport projection screen Tvs all the time by laying them down flatt all the time. You may have to adjust the convergence a little when youre finished moving it, but it wont hurt it.
Posted on May 29, 2008
How long does a plasma TV need to sit upright after being laid on its face before you can power it up without damaging the television?
Instantly. It is a mixture of Argon, Neon and other gasses. Not a slow moving liquid like we used last century in fridges.
Apr 02, 2017 | Televison & Video
How do I attach the tv stand to a 40 inch Coby television?
This requires some care---set will have to be laid face down--the screen unit or display panel is EXTREMELY fragile---the set must be laid down so the entire frame around the screen is supported and no pressure is exerted on the actual screen! One wrong move or downward pressure can damage/destroy the screen.
The base is attached with several bolts that come with the set--exact length and thread type is critical. They may all be same or different lengths. Line them all up and tighten with hand--snug them down evenly with a tool---NO downward pressure on screen when doing this.
If have lost or do not have the bolts contact the maker who will tell you size, thread type and number of bolts.
Carefully when done lift set upright.
Apr 17, 2012 | Coby TF-TV3217 32 in. LCD TV
Can I lay down an Emerson 4.6 cu ft refrigerator to fit in my car to transport
Even though it's not the preferred method of transport, it's OK to lay a refrig down for moving, even new R134a if you pay close attention to the refrigerant lines.
Determine where the suction line runs up into the freezer. This is the largest tube connected to the compressor, and is usually (though not always) visible running up the back of the cabinet.
As long as the refrig is laid down on whichever side allows this line to stay 'high', there'll be minimal oil migration, and when you arrive at your destination, just stand it upright for an hour or so and it'll be fine. Obviously, the shorter the trip, the better.
If the suction line runs up the door handle side, just duct-tape the doors securely closed before you lay it down to keep them from opening and getting damaged. It helps to lay a block of wood under the top end, just to keep it inclined a bit, too.
I've been moving refrig's for some 32 years now, and while moving them in an upright position IS best, sometimes you just can't. I work out of a van, and have often laid both refrig's and upright freezers down for transport with no ill effects.
May 12, 2011 | Emerson Microwave Ovens
The refrigerator is approx. 4 years old (side by side model). It was recently moved 100 miles. It was working fine in its old location, moved it 100 miles and now it does not cool or freeze. The lights...
if you laid it on it's side you could have damaged the sealed system.the machine has to be standing upright just like when it's in your kitchen or the compressor can get damaged,if you stood it back up and didn't run it for a few days the oil might go back down into the compressor but if it was moved on it's side and started most likely you damaged the compressor,or a wire or something got knocked off while moving it if it was moved correctly.is the compressor running?
Apr 13, 2011 | Westinghouse WRS3R3EW 33" 22.6 Cu. Ft....
I have a Sony Wega KP-FX432M91 Prjection TV. I am moving house and I want to know if I can lay the TV flat on it's back to move as it's too tall to stand upright in our vehicle
Please do not lay tv on its back because of its internal design, things are mounted inside vertically and screws are holding them in place. Laying tv on back will put force on screws that might came off or get loose and you will end up with a distorted picture on tv screen.
Move tv in stand upright position, it is safe.
Hope this will help.
Thanks.
Mar 25, 2011 | Sony KP-FX532M91 TV
Hi - I have to move a Daewoo upright fridge/freezer. It is too high to stand upright in my van, can it be laid on its side? Thanks
Yes, it can be laid on its side but when you get it to its location, stand it up and DO NOT plug it in for a few days to let the compressor oil run back down out of the system. After that everything will be fine.
Nov 01, 2010 | Refrigerators
To transport a loewe spheros 42 plasma unit with rotating stand does the tv unit detach from the stand? I understand that the plasma tv should be transported in an upright position only is this true?
Yes, it should be transported in upright position.
When we moved, our moving company arranged a crating company to crate our Spheros unit. They built a crate around the TV and secured it in an upright position along with the rotating stand. They then put a tilt sensor (you get the serial number of the tilt sensor) to make sure that the moving people don't tilt the crate. They also un-crate it at your destination. The only problem is that the TV is already quite heavy to begin with (~180 lbs), and with the crate, it becomes almost impossible for the movers move it in perfect upright position....though our movers really tried hard.
Sep 30, 2010 | Loewe Spheros 42HD 42 in. HD-Ready Plasma...
Moving the TV
TV should be in upright position during transportation in some safe packing around it.
Thanks.
May 13, 2010 | Toshiba 50H82 50" Rear Projection...
SELL TV: HOW DO WE MOVE IT
Howdy,
The best way to transport the TV is standing up with the front secured to a 'side' of vechile. If you don't have that choice lay the TV down on it's face. With both make sure you have plenty of moving blankets.The side would be my last resort because of stability. DO NOT LAY ON BACK!!!!
Good Move, big IRISH.
Dec 28, 2009 | Hitachi 50UX57B 50" Rear Projection...
Moving tv
no u will be ok only on plamasa tvs will this effect it sumtimes
Feb 03, 2008 | Samsung HCN653W 65" Rear Projection...
Panasonic PT-47WX49 47" Rear Projection Television Logo
348 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
