Question about Samsung LE32R41BD 32 in. HD-Ready LCD Television
Turned on power and cannot get a picture, snowy background. Tried plug and play option which SEEMS to work but then when updating channels returns to snowy non picture. please help!!!
  • 112 Answers
Service Menu:
Turn off the TV.
Pres from the remote "Info"
Press "Menu"
Press "mute"
Press "power on"
Your in service mode :D
Now go to reset and chose it alal the settings will be restarted to factory mode and the tv will go standby mode if that cant fix the problem i`ll need more info about your cable , or terrestrial can you check if there is signal if your using cable :D
Posted on Oct 06, 2010
  • marieknox_d Oct 06, 2010
    Thanks very much for your advice, after checking everything I don't think I'm getting a signal, is this therefore a problem with my aerial?
TV plays fine when dvd recorder is off. As soon as you turn on recorder the picture gets snowy. It doesn't matter whether it is on video 1 or on the channel setting. I have changed all the cables, still...
It seems that you are keeping the recorder close to the TV set resulting distortion in the picture due to power supply hum,check by keeping it away from set if no change than check the reason of hum received from power supply of recorder by replacing electrolytic capacitors for leakage or proper shielding of power supply in side the recorder.
Jan 22, 2011 | Panasonic DMR-ES40V DVD-Video Recorder
Snowy picture
The remote doesn't effect the channels, I would say you have poor signal or interference from another device nearby.
Sep 12, 2008 | Orion1934 19" TV
Tv has only snowy screen. Used the remote to
What to do if you have an all snowy picture (blue screen or the TV displays unusable signal-no signal or no sync)
1 – If you are using a digital cable box or satellite receiver (make sure it’s on) and be sure your TV is set for either CH3 or CH4 (which ever you usually view it on). If you usually view it through video inputs (video1 or 2 etc.) make sure the appropriate input is selected.
If you still don’t get a signal see if you get picture using the DVD or VCR (if available) if you do than plug the satellite or Dig. Box temporarily into the place of the DVD (unplug DVD) you may have to use some A/V cables (RCA yel./red/wht like the ones on the DVD) to hook to the tv from the sat./dig. box. If you get a signal then the sat./dig box is ok. If not the Sat./dig box is not sending a signal and is either defective or needs to be rebooted (unplug wait 5 min try again).
2 – If you are using standard cable or antenna (source) if possible check that the source is good by connecting to another TV. Otherwise try running the source into a VCR and then out to the TV using video inputs (RCA yel./red/wht like the ones on the DVD) and then selecting the appropriate input. Try seeing if the VCR plays using standard CH3 (or CH4)
If the VCR plays on video input but not when connected to CH3 (CH4) then the tuner of the TV may be defective – see if you can use the VCR to change channel using the VCR remote.
Be sure to vote/rate me if this helped Thanks!
Nov 24, 2009 | Toshiba 32AV502U 31.5 in. LCD HDTV
When tv is turned on with cable channels picture is snowy. when dvd or vhs tape played through tv the picture is snowy
Try using the video inputs
Nov 13, 2009 | Televison & Video
Snowy picture on VCR with only certain channels
In all likelyhood, you have a bad ground somewhere in the cable. Try other channels through the VCR. If the ground is the problem, there will be a cluster of channels that are snowy with the rest being clear. Check the cable itself and all of the connectors along it.
If the cable and connectors are good, the tuner or power supply of the VCR could be faulty and cause this as well.
Dan
Dec 24, 2008 | Sony SLV-N50 VHS VCR
Snowy picture with catv 1 mono on screen
is tv making some.. sound...please tell me..
Oct 20, 2008 | RCA TruFlat 27F520T 27" TV
SAMSUNG LCD TV LE19R8.
my samsung ps-42s5h seems to have a problem with the screen, there is no picture and seems to make a pulseing noise. any ideas?.
Oct 01, 2008 | Samsung Televison & Video
Picture is snowy/dark
update: Well, we ended up calling the repair man and we had a bad Y-sustain board and also a bad Z-sustain board. According to the guy who fixed it, it was due to over use of the TV and using main power button instead of shutting off through the cable remote. 650.00 later and a few weeks later, we now have a fixed plasma. No real suggestions on how to get more life out of the new boards.
Sep 12, 2007 | Zenith P42W46X 42 in. Plasma EDTV
Intermittent snowy pictures under Channel 51
Probably needs a new tuner or something associated with the tuner.
May 31, 2007 | RCA F36673ET 36" TV
Samsung LE32R41BD 32 in. HD-Ready LCD Television Logo
529 people viewed this question
Henry  Thomas
Henry Thomas
