Question about Kodak EasyShare V1003 Digital Camera
I haven't used this camera for over a year. I have it hooked up to the charger and into a wall outlet for several hours. All 3 blue lights on top are on. When I push on the kodak screen comes on then immediately goes to a black screen. The zoom moves a little but never goes back even with the camera. Thanks, Paula
    Brigadier General:
  • 11,967 Answers
Not using a rechargeable battery for over a year can cause it to completely discharge and die. That might be your problem.
Posted on Oct 07, 2010
Vibe bluetooth earbuds wont charge
That's a shame. However, this query is more for a forum dealing with audio equipment - this forum is for Cameras.
Sep 18, 2017 | Cameras
When I put the battery on the charger the light on the charger stays on for little awhile the it starts to blink, but when I try to use the battery it is not charged. So I am not sure if I need a new
Hi there! It sounds like you have our Linx stick vacuum or hand vacuum model. Plug only the charger into an outlet, the blue light on the charger should flash once. If the light on the charger flashes once then the charger is fine. Try resetting the battery by following these quick steps below.
1. Remove the battery from charger or cleaner
2. Unplug the charger
3. Insert the battery into the vacuum and turn the unit on for 30 seconds (even if it has no power)
4. Remove the battery
5. Plug the charger into an outlet, make sure the light on charger blinks blue once.
6. Insert battery into charger
The light should be a solid blue, indicating the battery reset worked. If so, allow the battery to charge for 3-4 hours, completely deplete battery on your next use and re-charge. If the light on the charger is still blinking, your battery will need to be replaced. I have included a link where you may go to purchase a replacement battery if needed. Hope this helps!
Search Results
Sep 21, 2014 | Hoover Floormate H3000 Upright Wet/Dry...
Why is my Samsung Galaxy Note 10.1" charging very slow.
There are a several reasons why the Galaxy Note 10.1 is not charging as much.
1. Too many application are turned on (check the task manager)
2. Too many notifications icon are turned on ( bluetooth, gps, wifi, etc.)
3. Plugging your charger using a computer
Are you using the original charger and plugging it into a wall charger?
How long did you use the Note 10.1 previous to noticing the damage? and was it extremely hot at the back?
If so, then maybe the battery isn't picking up from the charger. I've watched back to back movies while still using the charger but this can prove very devastating on the charger's outlet which became extremely hot after 4-5 hours or so of charging continuously. It turns out, the galaxy note 10.1 can withstand 8+ hours of ongoing movies but the charger outlet cannot. *If I didn't unplug it after 4-5 hours, the plug what have fried.
In this case, i believe the charger is more likely damaged than the Galaxy Note 10.1, which is more of a better scenario. Especially, since you charged it for over 24 hours, meaning it's charging something, but very slowly. Operating Galaxy Note while charging can prove detrimental in the charger's outlet and can in fact burn out.
I hope this info is helful,
Jason Chan
Jul 01, 2014 | Samsung Galaxy Note 10.1"
Hi, I'm having trouble charging my Nokia 6300i with a USB cord into a wall outlet with a charger similar to the apple wall charger. I haven't used the phone in over a year and i'm not sure...
Good day!!!
if you phone is not used over a years that can cause a lot of problem like the battery is gone or its drain because it not used for a long time..
I think that is your problem..try to replaced the battery to fix your problem..
thank you for using fixya...
have a nice day!!!
Jun 30, 2011 | Cell Phones
Ive been charging my blue tooth (new) for over 8 hours, the light is still red, and it wont even turn on! Can you help?
Try another outlet. If you're charging the headset through your computer, then use a wall charger. Leave it to charge overnight. If it wont charge, then bring it back to the store because your battery may be defective.
Dec 30, 2010 | Computers & Internet
I have a Peak 2,500,000 candle power cordless rechargeable spotlight (PKCOTN) and it's not recharging. I tried to recharge on the wall outlet and connect the recharger on the bottom of the handle to the...
There is a panel on the back which opens up to expose a 120 v house current charger. You must use an extension cord (not supplied) which will fit in the narrow channel. The supplied 12 volt car charger plugs in to the bottom of the handle. A red LED lights up when either charger is used. The manual suggests 24 hours of charging before use. My condolences.
Oct 24, 2010 | Sport & Outdoor - Others
Jassy 1103, will not start charging the battery.\r...
the 1103 uses an onboard charger. Charger's life span is about 3 years; some fail in 6 months, some in 6 years keep in mind. You can charge the 1103 using an offboard charger which are available for about $50.00 on Ebay. Search for electric wheelchair charger. You want one that has a 4 to 6 amp rating.
The offboard charger has a 3-prong connector on one end and the other plugs into a grounded wall outlet. Plug the charger into an outlet and the three prong connector into the female three prong connector located at the bottom front of the joystick. Give it a good overnight charge and it should be back up to snuff in the morning.
May 21, 2010 | Pride Jazzy 1103 Ultra Standard Power...
Optio a10 charger
if you don't see a light on the charger lite up its the charger, or the internal batteries are no longer excepting the charger. my first guess is the charger itself.
Sep 25, 2008 | Cameras
Powering the E-510 DSLR
The T is the thermister that the battery charger uses to determine the battery temperature and make sure it's not being damaged by high temperatures, you can safely ignore it when you hook up an external supply, it won't cause any errors on the camera or anything.
If you want to hook up a DC adapter to your camera just make sure it's a well regulated (a switching power supply should be just fine, like a wall adapter only they're typically much lighter weight but adapt AC to DC) and is the correct voltage. The reason I recommend a switching power supply is that traditional wall transformers only provide the rated voltage at rated load, meaning if you hook up a 12VDC 2A wall adapter to something that draws 1/2A it will have a significantly higher voltage that it has stamped on its case.
Happy Hacking!
Mar 30, 2008 | Cameras
Kodak EasyShare V1003 Digital Camera Logo
53 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
