Question about GE Tritonr XL GSD6260JCC Dishwasher
Dishwasher is leaking brown fluid from bottom right side. What is this and how to fix?
4 Suggested Answers
Greg20
  • 149 Answers
SOURCE: Brown liquid leaking from bottom of door on right
water is getting inside door and sound deadening material is washing out..remove door panel and locate the source of the leak(look around the dispenser)
Posted on Jun 13, 2009
jsrock516
  • 5911 Answers
SOURCE: kenmore dishwasher leaking from bottom of door
This is commonly caused by a worn door seal. Over time, these seals compress to the point where they no longer seal correctly, or food particles and grime get caught between the door and seal and leave small air gaps. The silverware tray (if located along the left or right side) can also cause damage to the door seal as utensils get caught on the seal surface as you roll the lower rack in and out of the tub. As water splashes up against the inner door facing it rolls out the bottom of the door, or down along the sides instead of staying in the tub. The only other items that can contribute to leaking are:
1. A dishwasher that is not level, which causes the door not to seal properly.
2. The inner door panel being warped causing the door facing not to be even for the gasket to seat properly.
3, Dish placement. If you place bowls, serving trays and large tumblers in the front row of the bottom rack on some dishwashers it can contribute to water being deflected over the front edge of the tub and out the bottom of the door (Believe it or not, I've seen it happen).
NOTE: Most dishwashers do not have a seal across the front lip of the tub. That's why it's important to have a good door seal and to load it properly.
If you've loaded the dishwasher properly and confirmed it is level (front to back and side to side), then here are your options:
1. Replace the inner door panel at a cost of about $115.
2. Replace the door seal at a cost of about $35-$40.
Parts can be purchased from any of the following websites:
searspartsdirect.com
appliancepartspros.com
pcappliancerepair.com
repairclinic.com
Use whatever parts source you like, but I have found these to be the cheapest and most reliable sites to order parts from. Shop all of them for the best price.
NOTE: The inner door panel is listed under the Door Parts section. The tub gasket will be listed under the Tub Parts section.
I think I would pursue the cheaper option, first. Its also the much simpler option. To replace the door seal, follow these steps:
1. Pull the old door seal from the groove around the wash tub facing. Take note of which surface area of the gasket is inserted in the groove and which surface is facing the door. It may not seal properly if you install the gasket the wrong way.
2. Clean the area really well to ensure there are no food debris or soap deposits. Also clean the inner door area where the door meets the gasket. You need a clean surface for the best results.
3. Locate the center mark of the new gasket. This will be a small paint spot or small groove on the gasket (this surface is the side of the gasket that will be inserted in the groove around the tub facing). If there is no center mark, fold the gasket in half and mark the location with some chalk, or hold with your fingers.
4. Locate the top center part of the wash tub facing and align the center mark of the door gasket at that point. Begin pushing the gasket into the groove with your hands and work your way around and down along each side.
5. Make sure the gasket is inserted all the way around the tub facing to the point where it meets the wash tub bottom. You can pull the gasket out and readjust as necessary.
This repair should take you about 30 minutes or less to complete. Its simple and requires no tools. The door will be tough the shut for a while until the gasket compresses and takes the door shape. Do not slam the door if it becomes difficult to shut. Simply close the door and the push firmly at the point just above the door latch until the latch clicks. Slamming the door can damage the control panel components, the door latch and/or the hinges. If you have questions, or require additional assistance, please let me know. I hope this helps you.
Posted on Sep 10, 2009
heatman101
  • 43501 Answers
SOURCE: Kenmore Elite Drawer Dishwasher leaking
Here is a tip that I wrote about dishwashers and them leaking.
Leaking Dishwasher
heatman101
ppi
Posted on Sep 29, 2010
Kenmore portable dishwasher leaking on corner and side of bottom right side (facing the dishwasher)Can this be fixed?
Without model # I cannot give you part # but most likely the door gasket needs replacement
Jan 17, 2017 | Kenmore Dishwashers
1993 MARK VIII HAVE OIL OR TRANS LEAK ? MINUTE I START CAR, DRIVERS SIDE. HAVE TO SHUT IT OFF. LEAKS BAD. CANT SEE WHERE ITS COMING FROM ANY IDEAS
Would recommend to steam clean complete engine compartment, to include the bottom.
Next, top your fluids and place clean towels or rags. Start your car until leak is present. With flash light Che k where from. If fluid is redesh in color, it's transmission fluid. If it's dark brown or black, engine oil.
Check bottom of oil and transmission pans for possible cracks or damage.
Dec 09, 2016 | 1993 Lincoln Mark VIII
Dishwasher leaking out the bottom of the front door
Here is a tip that I wrote about leaking dishwashers...
There also is a link in there to another tip on how to buy parts online for your dishwasher...
Leaking Dishwasher
http://www.fixya.com/support/r4546178-leaking_dishwasher
heatman101
May 15, 2010 | GE Nautilus 24" Built-in Dishwasher
It is leaking muliple substances. one is red leaking on the right side of the car and right next to the red leak its a tube looking thing that is frayed and leaking a clear oily substance, the other is...
The "Red" is transmission fluid, the "Clear" is most likely power steering fluid, or it could be "refrigerent oil" from the A/C. I don't know what could be leaking in the rear of the car maybe oil from one of the rear struts or maybe brake fluid. Do the brakes seem to work OK yet? If so it's probably not brake fluid. It could be condensation coming out of the muffler, there a weap hole in the muffler to allow excess water to run out. It might be picking up some color from the muffler. The transmission and the power steering are the biggest concerns you don't want to let the fluid level get low on either of those. If the transmission is leaking on the right side it's most likely the axel seal or maybe the pan gasket. Neither of these should be an expensive fix. But, you should get it to a shop and have it checked out. Try to find an independent shop instead of the dealer the independents are usually cheaper and do just as good of work. Get an estimate!!
Feb 09, 2010 | 1997 Buick Skylark
Power steering fluid all of a sudden just leaked out everywhere after i started the engine. i looked under the hood and the fluid is light brown, like air is getting in somewhere. there is a hose (if...
If the hose is split, replace the faulty hose and refill the power steering fluid. (When the engine starts up, the power steering pump pressurises the system which is why the leakage occurred after you started the engine).
Dec 25, 2009 | 2001 Hyundai Santa Fe
Brown liquid leaking from bottom of door on right side minutes after dishwasher starts.
Jun 13, 2009 | Maytag MDB7100AWB Dishwasher
Fluid leak appears to be off of transmission
Yes there should be 2 plugs on the side of the tranmission for this. one at the bottom is for draining and one about 1/2 to 3/4 up the side of the trans is for filling.
See if you can find the leak and fix that first. After its fixed then get the right fluid for your truck, check owners manual, and fill it to the top of that fill plug.
Manual trans fluid is good for 100k or more.
Mar 25, 2009 | 1998 Ford Ranger SuperCab
Fridgidaire Gallery Series Dishwasher Leaks from bottom
Leaking Dishwasher
heatman101
wre
Mar 01, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
GE Tritonr XL GSD6260JCC Dishwasher Logo
1,251 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
