Question about Poulan Wild Thing 2375 18" Gas Chain Saw 2.5 Cuin
The bar bolts are stripped, how do i take off and replace them?
    Sergeant:
  • 198 Answers
You might be able to drill out the old bolts in the saw and blade, then rethread to the next metric size up, if the screws are inside the housing. If the bolts go all the way thru, just get them removed the best way you can and then drill out to the next metric size, I'm saying use the next metric size because they usually have the next size bigger than SAE but in between the two SAE sizes. I hope that's not confusing to you and I hope that I at least give you some ideas.
Posted on Oct 06, 2010
  • jr1387ome Oct 06, 2010
    im talkin bout the bolt that holds the bar and chain,, i need to replace those bolts cuz they are stripped from takin the nuts off and puttin back on too many times
How to change bar bolts on mcculloch ms1635 chainsaw
The only reason I can think of to replace the bar screws is if one stripped or was broken since the bar is held on by nuts. The screws are installed in the engine case. The best thing to do is take it to a service center.
However, if you really want to do this, replacing part # 00083856-00 (JFT # 9214-310001) is not trivial. You will need to strip the housing off the saw to access the back side of the case. Once exposed the screw (bolt) can be turned out and a new one installed. After which, of course, you get to reassemble the housing.
Oct 13, 2014 | McCulloch Garden
How do I change the bar bolts?
Depends on Model. Some you will have to remove muffler, other models are actually inside of oil tank. Once you locate the Square head of the bolts, you can than tap them out gently from the other side using a hammer. Afterwards, tap new bar bolt in its place. NOTE: if bolt head is inside of oil tank you will need to drain oil first.
Jul 14, 2014 | Husqvarna 142 Chainsaw For Parts
Handle bars
just under the part the handlebars go through (the gooseneck)
there is a bolt that takes a 6 mm allen wrench, tighten the bolt, If it still doesn't tighten it might be stripped (there are ridges on the bars and the gooseneck).... Some bikes have 2 shims that fit around the bars, not sure if yours did or not, they could have fallen out when it loosened up if so you need to replace them good luck
May 31, 2013 | Cycling
Removal of alternator in 03 Altima 3.5 l
If you can't get a pair of 4'' vise grips to lock onto the bolts you might have to drive deep well impact sockets on them with a hammer,(use extension bars from your socket set to reach the bolts which you will need to replace once they have been removed)
Sep 25, 2012 | 2003 Nissan Altima 3.5 SE
Motobecane handlebars need tightening
If they are tuning left and right the the center bolt on the top of the goose neck will do it. If they are loose at the goose neck and moving forward and backward then you need to tight the bolt underneath at the point the bars are in the neck. If you can't tighten it anymore you have two choices but you must first determine if it is the handle bars or the goose neck that is stripped. If it is the handle bars then replace them and if it is the goose neck replace that. The other think you can do is make a shim from a piece of metal and wrap it around the bar and tighten the goose neck on that again.
Aug 07, 2012 | Motobecane Jubilee Deluxe
The handle bar stem on my sons mongoose is loose. I have tried to tighten the screw that connects to the stem but it doesnt seem to be stopping the bars from being shaky?
Your handle bars are most likely stripped or the mongoose head is stripped or a combination of both. Unscrew the bolt you just tightened and take the handle bars off to inspect the little splined area, if smooth than handle bars need to be replaced. The neck should also have those little lines horizontally this area should not be smooth. You can try to wirebrush the area and out it back together, see if that works or the cheapest thing to replace would be the handle bars. When I was a kid I would pin my handle bars so they would not move cause we did a lot of jumping of our bikes and had a lot of stripped handle bars. Mongoose is a good stem I would lean towards new bars. Good Luck...
Aug 16, 2011 | Cycling
Loose handlebars on a Mongoose XR-75 mountain bike. I tried to tighten them but they still are loose. Help!
Check the splines on the handle bar. Just loosen the "clamp" and slide the bar over to one side enough so you can tell if the are stripped or not. If they are then replace the bar, if not then reassemble and try to put a littlle extra torque on the bolt.
I have noticed with the 2 of these bikes that I have that the bars do not like to stay tight for long, they tend to work thier way loose about every other time we use them. I just keep tightening them untill the splines strip, then pick up a new bar.
Contact Mongoose for parts info at: www.Mongoose.com under "about" click ask mongoose.
Good luck.
Apr 04, 2010 | Mongoose MGX Maxim Dual Suspension...
I just replaced the tortionbar rod to the shock tower. The oise still exists like a bad ball joint or a wheel bearing when I hit a small bump. Can the rack steering system make a bad noise?
These vans are notorious for this noise. You are on the right track so far.
But not only do the sway/stabilizer links (what you replaced) wear out easily but also the rubber bushings where the sway bar is attached to the frame.
You will need to jack up and safely support the front end. Follow the bar until you see the brackets that hold the bar to the body/subframe. Look to see if the bar has been moving inside the bushing.
Sometimes it's hard to tell when its lifted in the air as it puts a little twist in the bar.
Often you can easily repair these tightening them up by adding a strip or two of a rubber inner tube. Actually I believe it is a better repair than new bushings in some cases because the bar can wear smaller too. Cheap fix, just a little time to loosen the bolts add the rubber strips, tighten the bolts and no more noise.
Nov 05, 2009 | 2001 Dodge Grand Caravan
2000 cadillac eldorado has a spoiler on the trunk with a strip of brake lights in it. Only part of the brake lights work now. Is this something that can be fixed by owner or better off taken to shop
You can fix it easily. The strip bolts in from the inside of the trunk lid.You may have to pull a felt lid liner down to access the bolts. The light bar in only serviced as an assembly so you will have to replace the whole thing. Good Luck
Jul 09, 2009 | 2000 Cadillac Eldorado
Stripped bolts
sounds like the bar stud is stripped out in the case. you might have to have a thread insert, like a Heli-coil, put in.
Mar 09, 2009 | Poulan Pro Chain Saw 46cc 20"
Poulan Wild Thing 2375 18" Gas Chain Saw 2.5 Cuin Logo
76 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
