Question about Sony Playstation 3 (PS3) Console
BLUE RAY DRIVE
HELLO MY NAME IS MICHAEL I OWN A PS3 THE SYSTEM WILL TURN ON AND I CAN DOWNLOAD GAME VIA PS3 NETWORK BUT THE SYSTEM WILL NOT ACCEPT ANY DISC. AND WHAT I MEAN IS I TRY TO PUT THE DISC IN AND NOTHING IT WILL ONLY GO IN ABOUT HALF WAY AND THEN IT BEEPS AND WILL NOT TAKE THE DISC IN. ITS ALMOST LIKE THE MOTORS FOR THE DRIVE ARE NOT WORKING. ANYTHING YOU CAN SUGUEST WOULD BE GREAT. I NEED SOME HELP I WANT TO PLAY GAMES BUT CANT.
  • 1 more comment
  • michael5406 May 28, 2008
    no the thing is spotless inside. it will not take any type of media its like the hole drive is not functioning. the motors will not take in the disc and the the tray looks as if it is off. one side will go up and the other will not and the hole thing just seems to be off badly and i read you posted to someone else you might be able to help them with step by step process to fixing this problem. i mean at this point i cant use the drive at all so its not like iam going to mess anything up more than it already is messed up. so any help you can give would be great please....... i am pretty good at fixing things but i have never worked on a ps3 before so this is all new one to me i have fixed 360 over and over again. so any help you can give would be great. thanks.
    i dont think the motor is working at all but not for sure i have not messed with it to much i was wanting to see if anyone could help me out before i started to really mess with it......
  • michael5406 May 29, 2008
    ok i took another look at the drive and i found out that the drive does nothing no motor functions no sounds not anything i think the drive is dead all together or the controller board and i have heard that you have to match the controller with the motherboard so does this mean that iam totally up that creek without a paddle????? please someone help me out!!!!!
    Scholar:
  • 106 Answers
Yeah, sony doesn't have good customer support. umm. how long have you had it? if it is dusty around the vents then it is probably dusty inside too and *may*be preventing the drawer from moving properly. but it may also be the belts/gears /motors.
Posted on May 28, 2008
  • crabbypup May 28, 2008
    well, are the pins that allow the tray to slide in place? are all the 'ramps' in place and intact? do all the gears turn? is the motor even making an attempt to turn on? (note, it is operated by one motor that opens the drive and closes it then rotates the laser assembly up into place to read the disc)
Error code for sony 3 807
"Hey, here is a list and a reason of some of the error codes you may encounter whilst connecting your PS3 online, also the required ports need to be opened in order to play online.
Playstation Network Required Ports
TCP 80
TCP 443
TCP 5223
UDP 3478
UDP 3479
UDP 3658
Playstation 3 Error Code List
0710102 - DNS Error; No DSN server available.
8001050B - Will not play demo hard drive games, when blue-ray disc is inserted - Cause unknown
80010510 - Will not play hard drive games - Cause unknown
8002b241 - DVI has no audio.
80028EA5 - Unknown
80029023 - Exchanging Key Information exchange has timed out
80029024 - The attempt to obtain an IP address has timed out
80029564 - Downloaded Game will not install - Cause unknown
8002F997 - Can not update XMB firmware
8003051E - Game will not Save
80031150 - System Settings Fail to Save - Possible Blue Screen "Setting information is corrupted.Press the x button to repair and restore default"
80130203 - PS3 connects to internet but not to network - Typically means that the required ports are not open to connect to store but PS3 can connect to internet.
80710092 - "An error has occured. you've been signed out from the ps network" - (connection dropped?)
80710102 - PS3 Cannot connect to the router with current IP information - Try rebooting your router
80710541 - The connection to the server timed out.
80710B23 - PS3 Network is Down or PS3 Network is too busy to respond"
http://community.us.playstation.com/thread/2996553?start=0&tstart=0
Apr 17, 2011 | Sony Playstation 3 (PS3) Console
My ps3 wont accept any disks an a the blue light wont turn on. what do i do?
seems you have a BDL problem its most common on early PS3 consoles, aside from YLD. you may have to replace the blu ray drive.
Mar 23, 2011 | Sony Playstation 3 (PS3) Console
My ps3 has error 80710723 and says it needs to update. when i try to update it i get the error and cannot connect to the network.
Download the update from your PC save it on a usb flash drive. On the flash drive create a folder and name it PS3 and inside of that folder make a folder and name it UPDATE. Save the download into the file that you named UPDATE make sure you name the downloaded file PS3UPDAT.PUP.
Put the usb into a usb port on your PS3 and goto system update and do the update via storage. Make sure the files and the downloaded contene named files are all in upper caps.
Feb 08, 2011 | Sony Video Game Consoles & Games
I cant install PS3 firmware update 3.15. I can download it but I cant install. error code is 8002f147. what should I do. next question. my ps3 wont turn on by pressing ps button. ( controller) just the...
I've got exactly the same problem i'm running 3.10 on my PS3 and have tried restoring the system doing a full format of the drive you name it. nothing works. The update 3.15 downloads fine but it gets to 21% of the install and brings up this 8002F147 error. I can't play any Blue Ray films on it or go on the web as all it wants to do is run this update which it can't. Additionally I also can't turn on via
the PS button. It's a 80GB one that i've just brought off ebay.
Ps. I called Playstation support at the weekend and they advised that I take it around my friends and try running the update which made no differnce which I thought it wouldn't as i've tried it via flash etc which downloads fine it's an install problem......
Please help......
Jan 29, 2010 | Sony Playstation 3 (PS3) Console
My ps3 won't play blue ray movies!
Cause
PS3 has a AACS (Advanced Access Control System) is a copyright-protection technology that is used on Blu-ray Discs. The copyrighted content is protected by setting an encryption key on both the disc and the device used to play the disc.
An AACS encryption key expires in 12 to 18 months and must be renewed, so no matter if you have a new PS3 or using it already make sure you keep upgrading your PS3 firmware regularly.
Solution
There are two ways to update as listed below:
* Update via Internet
* Update via Storage Media
Download the update data directly to the system from the Internet. The latest update is automatically downloaded.
Select Settings -> System Update, Download the latest update data from the Internet. Follow the on-screen instructions to complete the operation.
You also perform this system update via a storage media, Use update data saved on a disc, Memory Stick™ or other media. Download the update data from a Web site using a PC
Hope this helps, Wishing you happy holidays and happy Gaming
Regards
KreativeGeek
Dec 21, 2009 | Sony Playstation 3 (PS3) Console
Ps3 wont read any games 2 yrs old
if your ps3 it doesnt read any games that are to years old you may want to download a system update go where system update is an delect that
Nov 13, 2009 | Sony Playstation 3 (PS3) Console
My PS3 playd cd dvd but not blue ray games
Problem with the laser it sounds like. If you still have the system apart with the dvd drive out, go ahead and replace the laser. You can usually find them on Ebay.
Aug 08, 2009 | Sony Playstation 3 (PS3) Console
Ps3 blu ray lens cleaning
What are you saying you screw up your $600 dollar console. OMFG i mean common man. Jeez luis. Well since you have your ps3 already open your ps3 system you should open again and extract cod4 out of your blue ray drive before you hook it up and all that. So take the game out connect the blue ray drive back put the system together and power it up. See if that works.
Oct 07, 2008 | Sony Playstation 3 (PS3) Console
Ps3 problem
Needs a new blu ray drive 130$ on ebay If you need one I have one at 100$ shipped let me know I can help you install!
May 28, 2008 | Sony Playstation 3 (PS3) Console
Ps3 not reading any disks
Normally ps1-ps2-ps3 has Red laser beam lens system. So it cannot read Blue ray disks. its not possible until you change it lens system. there are some commericially available Blue laser lens system. Buy one and fix it with authorised service personnel. all the best
Dec 22, 2007 | Sony PlayStation® 3 (60 GB) Console
Sony Playstation 3 (PS3) Console Logo
54 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
