Question about Dell W2306C 23 in. HD-Ready LCD Television
Dell w2306c HDTV recently started having display issues. TV is 3 years old and now has horizontal stripes showing up on the screen. i've checked menu settings and disconnected and reconnected wires... help please!
  • Dell Master
  • 13,433 Answers
Hello
Lines on the panel are a problem with the display panel and the small circuit boards that connect to the panel. There is most likely a poor connection around that area of lcd display, the circuit boards or panels are on the side (either side or possibly both sides) and on the top or bottom.
Try pressing on the edge of the screen, on the plastic around the area of the line and see if it changes. There is probably a poor connection there.
if that is the case to properly fix the problem you would have to take the whole tv apart - inspect that connection area, resolder very small connection cable, theres a very high chance of making the problem worse or losing picture completely in that area of display..
Some people fix these problems by pressing or hitting the tv on that area. I DO NOT RECOMMEND hitting your tv, but as it is a connection problem that might help.
If problem doesn't get better by resoldering connections then most likely the whole display panel needs to be replaced and this will cost more than a new tv.
Posted on Oct 06, 2010
Osd is saying the main menu is locked how do i unlock
Win Tyler,
Information on resolving your locked screen on your LCD is listed below.
In the TV Menu Settings menu you can
select TV Button lock to lock the TV
Menu and the side panel buttons. When
this option is enabled, only the power
button functions. To unlock the TV Menu
and side panel buttons:
1. Press the Menu button on the TV. A message appears stating that the TV is locked
2. While the message is on the TV, press the channel up and volume increase button
simultaneously.
If you are using the DVI connector, you may need to verify the following settings:
Source - The default setting is Auto. The T V automatically detects if a computer (PC) or video
device is being used. If the image does not display correctly, you can select the source, PC or
Video, depending on the device you are using.
Color - The default color space is RGB. If the colors are not displaying correctly, you can change
the setting to YUV.
You can download and view the online users manual from the link below.
Manuals & documentation for your LCD TV W2306C
Product Support
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Nov 18, 2015 | Dell W2306C 23 in. HD-Ready LCD Television
46in Vizio LCD HDTV distorted black picture when tv is turned on
Hi There are three things that can cause this problem. Your lcd screen, t-con board or the signal board. Most likelly in your case since you say it's only half the screen it's going to be your t-con board. You can try removing it and cleaning all the contacts and replacing it see if that helps. If that doesn't help then replace it. If that does not solve it then it's going to be your screen.
You can get parts at www.interliquidparts.com
Nov 28, 2011 | Vizio VW46LFHDTV10A 46 in. LCD TV
Horizontal static-like stripes across the top 1/3 and bottom 1/2 of the screen. Please help!
You may want to check your tv display, cable box, satellite device. If you had an HD tv make sure they display or resolution setting is set to 16:9. If you have a standard def tv, make sure it's 4:3
May 16, 2010 | Samsung HP-R4252 42 in. Plasma HDTV
Dell W2306C 23" LCD tvs main menu is locked!
@ kennethrcalh you are awesome thanks for your help
Mar 20, 2010 | Dell W2306C 23 in. HD-Ready LCD Television
Purple verticle lines on flat screen Samsung TV
How does the tv menue look. Does it cover the stripes or do the stripes affect the menue. if menu ok main board if menu affected bad panel. If under 1 years it is still under Samsung warr. Even if older than 1 year contact Samsung to see if they will cover repair.
Aug 31, 2009 | Samsung LN-S4692D 46 in. LCD HDTV
Samsung HLN4365W picture not centered
turn the tv off, hit mute 1 8 2 power, the tv will come on in the service menue, look in that menue for vertival and horizontal adjust, after you adjust it, just turn the tv back off, it will save your changes
Jan 07, 2009 | Samsung HLN4365W 43" Rear Projection...
ARPI your the guru please HELP ME I just need to fix this TV
Dell will replace it if it's less than 3 yrs old but apparently their tech support people are clueless about this and have to be told what they need to look up. The replacement is a nice gesture except if you're like me and paid >$1,000 for this more than 3 yrs ago. I have had TV's > 20 yrs and don't reacall major problems with any.
These instructions were posted on the Dell Community forum http://en.community.dell.com/forums/
The following in and out of warranty TVs (W2600, W2306C, W2606C) with the No Power issue must go through Technical Support to initiate the exchange. Tell the technician to look up the following DSN document IDs to get the details on the in and out of warranty exchange process:
- 313698 Dell-Branded TVs Out-of-Warranty Repair Procedure - CTS/CBG/SMB/GTS-T/DOC. Tell them to scroll down to, Dell W2306C, W2606C, or W2600 TV Replacement for a No Power Issue
- 329986 TVs (W2600, W2306C, W2606C) with No Power. New exchange procedure - TV and Home Theater - Dell Community Forum
* Dell will cover this issue, regardless of the limited warranty status, for the W2306C, W2606C or W2600 TVs for 3 years from the original invoice date
* Once past the 3 year date from the original invoice date, we will not exchange the TV
* Units sent as replacements for this issue should be considered in warranty for 90 days after the replacement or for the remainder of the limited warranty term, whichever is longer
* You will need to provide to them the following information -
TV Service tag number:
TV Order number:
Name:
Shipping address:
Phone number:
Email address:
Reason: Dell LCD TV has the No Power issue
Jan 02, 2009 | Dell W2600 26 in. LCD Television
Everytime i turn my Dell 50in plasma tv off over night and turn it back on i get a messege that says FACTORY RESET MODE. i have to rescan the channels. i tried to do a factory reset but it asked for a code...
I have Modle # W2306C LCD TV Display ...lost remote... w/screen displaying the message "main menu is loccked" . None of the side buttons work {i.e. channel, vlolume, etc..} except the "on-off" button.What the hell??? HELP!!!
Dec 23, 2008 | Dell W5001C 50 in. Plasma HDTV
Discolored strips across top of screen.
If they are pink or blue stripes, I have seen this before. I hope the TV is less than two years old, because the optical block has to be replaced. The optical block has a two year warranty on the part, but you will have to pay labor. Just to double check, make sure you can see it on all inputs and also that it shows up on the menu and on screen display. If yes to all of these, it's the optical block and no adjustments will help. Be sure to rate this solution. Thanks!
Nov 08, 2008 | Sony KDF46E2000 46" Projection HDTV
Dell W2306C 23 in. HD-Ready LCD Television Logo
59 people viewed this question
Top Dell Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Dell Televison and Video Expert? Answer questions, earn points and help others
