Question about Hayward H Series Pool & Spa Heater 400k Btu Propane Gas Milivolt Ignition H400p1
How much does a new sensor cost? - Hayward H Series Pool & Spa Heater 400k Btu Propane Gas Milivolt Ignition H400p1
  • 990 Answers
Ignition sensor-about 70-80 dollars
temp sensor-about 50-60 dollars
These are two of the sensors in a heater. Price is about what the price is in my part of the world. You should find out what sensor and check local prices before you bank on Arizona prices. As they could change quite a bit depending where you live in the world.
Posted on Oct 07, 2010
I have a 98 neon that needs o2 sensor and egr valve fixed. Ive been quoted 340 repair bills for the work. Is that reasonable, or better to put 700 down start payments on a new car?
Carlos, Can you do any work your self new EGR valve $50.00, new O2 sensor $50.0 or less ordered through Rock auto.com, if car overall in good shape may be worth fixing. Especially if finances are tight. get a second even third estimate and this time ask them if you supply new parts O2 and EGR how much they want for labor, should not be more then 1.5 hours. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Upstream Oxygen Sensor Replacement Dodge Neon EGR Valve Replacement Cost for Dodge Neon RepairPal Estimate
how to clean an egr valve
Oxygen Sensor Replacement Cost RepairPal Estimate
Apr 28, 2016 | Cars & Trucks
How much will i pay for a new tdc sensor
Check pricing at Pelican Parts.com.
Nov 17, 2013 | 2003 Renault Megane
My 2006 Chrysler 300 hemi transmission keeps acting it shifts into first and then it wont shift after that if you shut down the vehicle and turn it off and start over then sometimes it shifts into all...
unless there was a code for your shift sensor then that was an expense that was not needed. the 1st thing I would suggest is a service. remove pan and have a complete trans flush then new filter and new fluids. about the same cost as the sensor. if not better, then it is probably internal and trans needs to come out
Sep 19, 2013 | 2005 Chrysler 300
Catalytic converter costs
I would wait on the cat. Have the heads and sensors done and see if the cat burns the coolant off.
Aug 07, 2013 | Hyundai Elantra Cars & Trucks
Bad computer or bad vacuum sensor?
cheapest is to have the computer checked then you will know how much it is going to cost.
May 19, 2013 | Cars & Trucks
2005 harley 1200c crank position sensor cost
Hi Anonymous, around $60. Have nice day.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Feb 02, 2013 | 2005 Harley Davidson XL 1200 C Sportster...
Wont start when cold out
If your vehicle is fuel injected the problem you describe could be result of a few different things: 1) Check your Idle Air Control (IAC) sensor/motor. This sensor is located on your vehicles, throttle body. The purpose of this sensor is to control the car's idle under various operating conditions including ambiant temperature. In order for it to function correctly, the internal components must be clean (meaning, little or no carbon build up) and it must be undamaged. Sometimes the IAC can be cleaned; however, if this cleaning procedure is not properly done, the IAC can become damaged. This sensor is also sometimes called the "Cold Start" sensor. A new IAC will cost $50-$100. 2) Check you Coolant Temperature sensor. This senso is located on the top of your engine and is screwed into your intake manifold. When this fails your car will experience starting problems when cold outside. A new Coolant Temp sensor will cost about $100. Take a look at two three solutions first. My guess is your IAC needs to be cleaned or replaced. Good Luck!
Please remember to rate this solution. Thanks!
Jan 13, 2011 | Ford Lincoln Continental Cars & Trucks
Won't idle in cold weather
The problem you describe could be result of a few different things: 1) Check your Idle Air Control (IAC) sensor/motor. This sensor is located on your vehicles, throttle body. The purpose of this sensor is to control the car's idle under various operating conditions including ambient temperature. In order for it to function correctly, the internal components must be clean (meaning, little or no carbon build up) and it must be undamaged. Sometimes the IAC can be cleaned; however, if this cleaning procedure is not properly done, the IAC can become damaged. This sensor is also sometimes called the "Cold Start" sensor. A new IAC will cost $50-$100. 2) Check you Coolant Temperature sensor. This sensor is located on the top of your engine and is screwed into your intake manifold. When this fails your car will experience starting problems when cold outside. A new Coolant Temp sensor will cost about $100. Take a look at these two solutions first. My guess is your IAC needs to be cleaned or replaced. Good Luck!
Dec 26, 2010 | 1999 Lincoln Town Car
1993 jeep grand cherokee put new sencor on, new fuel pump, new relay, coil pack and still is'nt getting any fire from coil. it just keeps cranking.
Crank position sensor mosly likey. Seems like you wasted a lot of money on unnessary parts. Crank sensor should cost about $40
Feb 24, 2010 | 1993 Jeep Grand Cherokee
Hayward H Series Pool & Spa Heater 400k Btu Propane Gas Milivolt Ignition H400p1 Logo
100 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
