Question about Hotpoint RLA50 Refrigerator
Hotpoint rla50 fridge is freezing up - Hotpoint RLA50 Refrigerator
  • Hotpoint Master
  • 43,501 Answers
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Oct 08, 2010
Rla50 fridge ices up
You may have the settings incorrect. I would try the middle setting to set if that would be better. Here is the manual:
http://kitchen.manualsonline.com/manuals/mfg/hotpoint/rla50.html?idRes=599970
May 06, 2012 | Hotpoint RLA50 Refrigerator
We have a hotpoint side by sie firdge. The water dispense on the door is leaking. Help
It could be duct door is sticking open. This a common problem. The selnoid gets rusty and sticks open. I hope this helps.
Aug 23, 2011 | Hotpoint RLA50 Refrigerator
The fridge is freezing my food
heatman101
Oct 06, 2010 | Hotpoint RLA50 Refrigerator
Fridge freezing up
Check the fridge sensor. On my Hoover HNMF2805AL80 f/f, first I replaced control module - still freezing.
Have just replaced cheap fridge temperature sensor. Part No. 97061619. Trouble is you have to cut into insulation at back of fridge to replace. I just plugged in sensor & placed inside fridge at back at the bottom - so far so good, only lettuce freezing now, everything else v. cold but not frozen. :)
Jun 02, 2010 | Hotpoint RLA50 Refrigerator
Fridge of my Hotpoint FFA90 fridge-freezer freezes
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Mar 11, 2010 | Hotpoint FFA90 Bottom Freezer Refrigerator
Hotpoint larder fridge RL150G keeps freezing at the back fitted n
flap controling tempature not closing to controle tempature 9inside ref
Dec 09, 2009 | Refrigerators
Water appearing on fridge floor because of blocked drainage hole
Clean out the drain hole with a thin flat bladed s/driver then pour some water down the hole so you no you have cleared it.
Sep 29, 2009 | Hotpoint RLA50 Refrigerator
Black tray above compressor is filling up with water on a RLA50
hi there.the tube your speaking about comes from the rear of the fridge down to the plactic tray on top of the compressor...and is used for conveying condensed water from the fridge to the dri tray where it is evaporated by the running heat of the comressor....excessive water can be caused by a faulty fridge door seal....door not closing correctly...and the possibility that your fridge setting is to low....or sited close to a working radiator
regards Sir Galahad
Aug 12, 2009 | Hotpoint RLA50 Refrigerator
THE REFRIGERATOR FREEZER DOOR STAYS SHUT BUT THERE IS NO SUCTION AND I AM GETTING ICE CRYSTALS INSIDE THE FREEZER. WHAT COULD THE PROBLEM BE?
there is some thing wrong whit your door gasket, check your door gasket all around and see if is seal properly, if is broken there is places than custom make fridge gaskets. if by any chance you tuck your doors a part, may be than you dint properly adjust the door or you are missing a shim if so.
use some coins to adjust the hinges. buy placing in between the fridge body and the hinge.
place a piece of paper on the fridge and close the door it shut hold the paper all the way around the door.
Good luck :)
Apr 06, 2009 | Hotpoint RLA50 Refrigerator
Hotpoint RLA50 Refrigerator Logo
295 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
