Tascam 2488 system error code 3 - Audio Players & Recorders
  • rnst_yng Dec 30, 2008
    IT COMES ON AND SAYS SYSTEM ERROR CODE 1
  • Tirrell Apr 15, 2009
    Hi. I'm having a problem with my new Tascam 2488 neo. I've tried a few times to record my band while using the unit as the mixer. I have the main sliders routed to the house speakers, and the effects 1 routed to monitor speakers. The first time, about an hour into the recording, the unit partially stopped responding AND it stopped sending sound through the outputs to the amplifier powering the speakers. The tracks were still armed for recording and lit steadily as if it were still recording, however, the clock was not moving (as if were stopped). If i tried accessing the menu, it would say "Cannot do this while not stopped..." I ended up having to do a cold shut down and loose my data. This has happened a second time (possibly error code 3). On both occasions, I wasn't even touching the unit when the problem occured (i'm also the keyboardist) as I was playing at the time. Any ideas?
  • 1,512 Answers
Hi jamie2488
The error code means different things depending on what version of firmware the 2488 is running. It will tell you when you first fire it up what version yours is running. Check out this
This is a list of all error codes, depending on the firmware. The code you are experiencing means you cannot duplicate to the same track(duplicate to a new or different track). To resolve (for v1.0) , press exit/no (for v1.01) press exit.
I am more than happy to answer any other questions you may have about it, just give me a hoy :) Thanks for using FixYa, If you consider the advice I have given you as sound, a FixYa rating is a great reward for my efforts to help you. Cheers.
regards
robotek
Posted on May 29, 2008
  • Graeme Ross
    Graeme Ross Jun 05, 2008
    Hi, just a quick followup to see how you got on with your
    problem. If you still havent got it sorted, let me know, I am happy to
    do some more research and offer some more information and solutions. If its fixed...
    excellent!! A FixYa rating from you will close this unrated solution
    for me. Thanks for using FixYa. I am happy to answer any other
    questions you may have.
    regards
    robotek
Tascam 2488 system error code 1
I had
System error code:01
on my Tascam 2488 neo
Turns out it was a hard drive error. I tried everything. I used the "Quick Routing/Shift/Send/ShutDown" trick where you press all four buttons at once and keep them pressed down throughout while you power on the unit util you see a message saying "System Reset Complete. Now Power Down". Numerous times it came on and said stuff like "creating partition," "creating song" and "now working" but it always ended with "System Error Code:01". That trick is upposed to reset system par?meters to default and erase everything from the hard drive and reset the hard drive. I even removed the hard drive, hooked it up to my Windows 10 PC and used Windows utils to reate and/or delete partitions and both "quick" and regular format. I also tried all the hard drive utils from the manufacturers like a formatting and a scrubbing util etc.,.nothing ?orked until I downloaded, inst?lled ?nd used a low level format utility called "Hard Disk Low Level Format Tool," its installation file is called "HDDLLFsetup.4.40.exe" which is available from mul?iple internet sites, just search for it. Here is how to repair your Tascam hard drive or prepare any new hard drive for installtion or upgrade that is giving endless problems and system error codes on the Tascam:
1. Open your recorder and remove the hard drive from the Tascam. If you're unsure about doing this there is a YouTube video av?iable about how to replace your Tascam 2488 hard drive.
2. Connect that drive by any means available to your laptop or PC. I used a USB to SATA ad?pter and connected it to my laptop, I also successfully did this using my desktop PC.
3. Run the "HDDLLFsetup.4.40.exe" application and install it.
4. Now use the newly installed "Hard Disk Low Level Format Tool" utility.
5. Select your hard drive then the low level format tab and don't sele?t the "quick" option, make sure it does a full low level format. It'll be slow and t?ke some time. Any hard dive prepared like this will ?ork in the Tasc?m except incompatible or damaged hard drives.
6. Reinstall hard drive into Tascam and simply power on the Tasc?m. Do not use any special boot up tricks with any key combinations, just turn it on.
7. Select "yes" when asked if you want to form?t the drive. W?it a few seconds until it completes cre?ting and working. It should boot up to normal use mode and be ready for recording within 3 minutes. If yours takes longer your hard drive may be damaged and need replacing. I tried other hard drive utilities from Hitachi, Seagate, S?msung and Western Digital but none worked. O?ly the "HDDLLFsetup.4.40.exe" was able to fix the problem.
Dec 15, 2012 | Tascam 2488 Portastudio Multitrack...
Error code 3
Straight out of a Tascam 2488 manual...
When editing tracks, you have selected the
same track as both source and destination
for a duplicate operation.
Press EXIT and try again.
Jan 20, 2011 | Tascam 2488 Portastudio Multitrack...
Recording stops and recorder freezes with tascam 2488mk2
this has happened to me too- with different system error codes also not referred to at all in manual !!! i don't know of solution- and have lost the current recording session by having to just turn the device off and hope for the best... i plan on contacting tascam after this project is complete since my unit is still under warranty - GOOD LUCK out there
Jun 21, 2009 | Tascam 2488 Portastudio Multitrack...
Tascam 2488 SDRAM error
Jose
I had the same problem. I sent it back to my place of purchase and they sent it to an authorised Tascam repairer. Unfortunately they sent it back twice saying it was fixed when it wasn't. They then decided it needed a ne main board which was going to cost $800 AUS, excluding any labour to install it. In the end I got angry and went straight to the TASCAM distributor and told them my problem and that it was unnaceptable that such an expensive unit needs a new main board in such a short space of time. To my surprise they came back and agreed to replce the main board for fee and the service repair centre did not charge me either. DON'T pay for this. It is obviously some problem with the unit. RING TASCAM in your area or the authorised distributor.
Hope this helps.
Jan 28, 2008 | Tascam 2488 Portastudio Multitrack...
Instructions
Link to Tascam 2488 documents page:
http://tascam.com/Products/2488_downloads.html
Individual Items as Listed:
Link to the Tascam 2488 product brochure:
http://tascam.com/Products/2488/2488_bro.pdf
Link to the Tascam 2488 application guide:
http://tascam.com/Products/2488/2488_AppGuide.pdf
Here's the link to the Tascam 2488 quick start guide:
http://tascam.com/Products/2488/2488_quickstart.pdf
Link to the updated Tascam 2488 manual:
http://www.tascamcontractor.com/ftp_resour...w_additions.pdf
Link to the Tascam 2488 manual additions:
http://www.tascamcontractor.com/ftp_resour...e_additions.pdf
Link to the Tascam 2488 MIDI Parameter Mapping
http://www.tascamcontractor.com/ftp_resour...ontrol_v0.2.pdf
Link to TASCAM 2488 Hi-Res images:
http://www.tascamcontractor.com/ftp_resour...488_images.html
Nov 10, 2007 | Tascam 2488 Portastudio Multitrack...
I can't figure out how to record on 8 tracks at the same time.
Nov 07, 2007 | Tascam 2488 Portastudio Multitrack...
Tascam 2488
Oct 23, 2007 | Tascam 2488 Portastudio Multitrack...
615 people viewed this question
 Grubhead
Grubhead
