Question about Panasonic PT-53WX53 53" Rear Projection HDTV-Ready Television
Color is off with double image? - Panasonic PT-53WX53 53" Rear Projection HDTV-Ready Television
  • Panasonic Master
  • 1,606 Answers
Is the image bow-tie shaped, with red, green or blue fringing effects? If so, one of your convergence amplifiers has gone bad. (Bow-tie: at least one of the three primary colors in the picture goes out to the corners, but the top, bottom and sides are bowed in at the center.)
If it is simple color fringing, with no color grossly misplaced, something has messed up the convergence. This may be caused by a strong magnet near the set (for example, a poorly shielded audio speaker), moving the set so its orientation in the geomagnetic field is altered or its components mechanically shifted (rough handling).
If a convergence amplifier is bad, replace it before doing anything else. If you just have minor fringing, see your owner's manual for instructions on using the remote control to adjust convergence. If it isn't in the owner's manual, you'll need the service manual. Caution: if you try to adjust convergence with a failed convergence amplifier, not only will it not help, but you will have a lot of extra work trying to get it back to normal after you replace the amplifier. Try a small adjustment along one edge of the picture. If one or more of the selected color dots in the convergence pattern won't move, and you are sure you are following adjustment directions, stop immediately and proceed with hardware repair.
Convergence amplifiers are usually marked STK392-nnn where nnn is a specific variant number. Two are used; I usually change both because quite a few people have changed one and had the other die not long afterwards. Sometimes there is a fuse in the power feed to these modules that is also blown. If you change the fuse without replacing the amplifiers, you'll probably waste a new fuse.
Posted on Oct 06, 2010
Image quality
Try to print in single color mode CMYK and
check which color is faulty and replace that color drum.
Aug 25, 2013 | Sharp MX-2300N Color Copier
Double image & wave's of colors
Hi, the double color images and wavy is due to a couple of power amplifiers that overheat and fail. in this case the number is stk392-110, available from most e stores.
Oct 29, 2010 | Hitachi 50GX30B 50". Rear Projection...
Double images on screen
IT SOUNDS LIKE A PINCUSHION PROBLEM. IN MOST CASES IT IS DUE TO CAPACITORS GOING BAD ON THE BOARD. OTHER TIMES SOME TV'S HAVE LARGE MICROCHIPS THAT RUN THE PINCUSHION AND COLOR SYNC. HOPE THAT HELPS.
Feb 20, 2010 | RCA HD52W56 52" Rear Projection HDTV
Double image
In all probability you need to have the convergence amplifiers replaced. A very common problem with all projection sets.
Jun 02, 2009 | JVC AV-48WP74 48" Rear Projection...
Hitachi 42" Wide Screen TV - color seperation, double images
Replace Both of your convergence ICs they are big black ICs and ck resistors RK4246,50,54,58,62 i have the values if you need them they are 1.5ohms up to 3.9ohms.ICs will have STK392-110s if this is the number on yours upgrade to 180s
Feb 19, 2009 | Hitachi 43GX01B 43" Rear Projection...
Double images from printer
This is normally caused by a defective toner cartridge
Sep 03, 2008 | HP Color LaserJet 2600n Printer
Double image
change color toner with original Hp tonars
Mar 16, 2008 | HP Color LaserJet 2600n Printer
Colors and Images
sounds like loose connections on the convergance amps ic's
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Dec 25, 2007 | Toshiba 65HX81 65" Rear Projection...
Double image 6 your old unit
KIT10 $29.50
Repair Kit for Hitachi convergence Chassis DP-14G
KIT10 Includes 2 pcs STK392-150 , 1 each of the following 1W axial lead fusible resistors:
http://www.digitalhome.ca/forum/showpost.php?p=564268&postcount=220
Nov 25, 2007 | Hitachi 61UWX10B 61" Rear Projection...
Panasonic PT-53WX53 53" Rear Projection HDTV-Ready Television Logo
78 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
