Question about Whirlpool Dryers
Need a schematic for GEX9868JQ0 dryer - Whirlpool Dryers
  • 5,911 Answers
There should be a wiring diagram and tech sheet inside the operator console, or inside the dryer cabinet. Most appliances come with this literature as a standard policy, so repair technicians have reference material to aid in troubleshooting. Remove the back of the operator console and check there, first. If you don't find any literature there, you can open the cabinet as follows and check inside:
1. UNPLUG the dryer and remove the lint screen.
2. Remove the two screws that were under the lint screen and lift the top panel.
3. Unplug the door switch connector plug and any ground wire that may be installed on the casing.
4. Locate the two screws that hold the front panel in place. There should be one screw on each side in the cabinet interior.
5. With the door shut, lean against the front panel and remove the two screws that hold it in place. Once the screws are removed, grasp the front panel at the top center and lift straight up to remove.
You should now have complete access to the dryer interior.
If you no longer have any of the literature that came with the appliance you can order replacements at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
The part numbers are as follows:
Tech Sheet - LIT3978624
Wiring Diagram - LIT3977777
If you need an owner/operator's manual, you can obtain a replacement copy at managemylife.com. Just enter your model number under the "Manuals" link and your owner's manual is available in .pdf format that can be downloaded or printed for FREE.
If you require further assistance, please post back and let me know. I hope you find this information helpful.
Posted on Oct 06, 2010
I need some help with the order of wires on the timer switch on a creda dryer model 37382
Need schematic for this . Try out the attached website - often they include then along with parts schematics. Search Over 2 1 Million Appliance Parts
Sep 20, 2015 | Dryers
Where can I get the schematic for my Kenmore dryer 110.73952101
the schematics sheet is under the head unit of the dryer where the timer is. In some dryers, the ones with the bottom front tray, you can find it in an envelope along side the wall of the dryer.
Jul 06, 2014 | Kenmore 63942 Dryer
Whirlpool Dryer Model 6646AQ1 need schematics to diagnose why the dryer won't turn on. Electrical connections all checked and working. ???
Did you look inside the dryer? Full schematics & troubleshooting procedures are usually in either the back control panel or around the drum.
Gary
Aug 31, 2011 | Whirlpool WED4900XW Dryer
I have a Whirlpool Dryer Model number GEX9868JQ0 and it will run however; it is not blowing hot air? How do we remove the kickplate (front or back) to check out what is wrong? Please advise.
A typical problem that causes tumble dryers to stop heating up is the thermal overload cut-out devices. These are safety devices, and are some times "single-shot". That is, if they operate, and shut off the heating element, then they need to be replaced, usually as a pair along with the thermostat (they look very similar). The other common fault is that the heating element fails. However, if the thermal cut-out was the problem, LOOK FOR A CAUSE. If it is a condenser drier, check the condenser box is not clogged with lint/fluff
Oct 30, 2009 | Whirlpool GGQ8831L Gas Dryer
Need a schematic for model 110.76732500 gas dryer and how to open the unit and replace the motor.
Go to www.searspartsdirect.com , enter your model # and you will get a good parts schematic for your dryer.
Oct 05, 2009 | Dryers
I need a wiring schematic for my maytag dryer model PYET344AZW
http://www.applianceaid.com/images/smedwd.jpg
Mar 14, 2009 | Dryers
Dryer will not start
Check the following:
Is the power cord plugged in?
Has a fuse blown, or has circuit break er tripped?
Was a regular fuse used? Use a time-delay fuse.
Is the dryer door firmly closed?
Was the START button firmly pressed?
Is a cycle selected?
Mar 07, 2009 | Whirlpool LGV4634JQ Gas Dryer
Schematic
f7607c2.jpg and its even for a dryer, maytag mde260 series
It wont look much like the dryer you are working on, but unless you tell the problem,,,,,,,
Sep 17, 2008 | Dryers
Dryers Logo
163 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
