Question about Dell Computers & Internet
Hi this is mahesh i have problem with my dell inspiron1564 the problem is it restarts automatically and some times locksup the system......................... why it happens it gives the bluescreen error 0x00000124
  • 38 Answers
This kind of problem takes a little troubleshooting and time. Check to make sure that the power plugs are plugged in securely. (Both ends) Also, if you can, unplug the power, open up the case and check the plugs from the power supply to the motherboard and make sure they are secure. This is assuming that it is a desktop, not a laptop. Be sure to touch the metal case to discharge static first or you risk damaging the components. Could also be overheating. Make sure that the holes on the case are not covered by dust, an that the fans are all working properly. If desktop, you can plug in the ccomputer and turn it on for a short time to check the fans. There should be fans on the case, inside of the power supply ( you can look at the back of thr computer to see if it's working), and on the CPU (processer). If you have a laptop, unplug the power, then remove the battery, and get a can of air and blow dust from all of the air holes around the sides and under the computer. be sure to keep the can upright or it may sprat liquid into the computer. Vacuuming is not recommended, as a vacuum hose generates a lot of static, and may also blow out components. Good luck with it.
Posted on Oct 07, 2010
Plz plz help help problem with dell inspiron1564 corI3 becom so slow when installing xp
This problem may be due hardware compatiblity. If you have installed windows Xp and its still running slow then its better to download and install the latest drivers that control you system.
I would suggest to use a driver scanning tool to download and install the latest drivers. you can get one here: http://www.DriverScanner2013.net
Sometimes such problems occurs due to corrupt windows installaion files. So try to change windows disc.
Dec 05, 2012 | Computers & Internet
Windows7 unlock codes for dell inspiron1564
Sorry this is not a warez site. You'll need to contact Microsoft.
May 31, 2012 | Dell Computers & Internet
OmLaptop restarts after being shut down Its a Dell 1545
Hi 1940miker...
Try this solution to your problem
Your computer is set up by default to auto start when a problem occurs.
The computer is configured to automatically restart when Windows stops responding.
To view this setting, follow these steps:
Click the Start button, right-click My Computer, click Properties, click the Advanced tab, and then click Settings under Startup and Recovery.
Under System Failure, view the Automatically restart check box.
If the Automatically restart check box is selected, Windows automatically restarts if the computer stops unexpectedly.
Please take time to rate me
Sep 04, 2011 | Dell Inspiron 1545 Notebook
I have a dell Inspiron1564 not working touchpad
Is there a switch just above the touchpad to turn it off? Is there a keyboard combo (Fn key plus a special function key) that turns the touchpad on and off?
If you find neither, you may have to take the computer apart and check the connection. You can find directions for all this at support.dell.com. Just enter you service tag number or choose the computer from the list they provide.
Jul 11, 2011 | Dell F3534 Touchpad
My dell inspiron1564 webcam is not working when i open it shows plug in a supported device so please solve the problem
click start control panel view devices and printers you should see your webcam from there
if you are have trouble with your webcam
click start control panel administrive tools ,computer management ,device manager scroll down image devices you could see a yellow question mark?
right click to reinstall drivers or update driver
hope this helps
Apr 05, 2011 | Computers & Internet
My laptop won't detect any wireless connectivity, what should i do?
hi
your system is Inspiron 1564, is that correct ..? if you want further help, i need your service tag # located on back of laptop, in order to research the problem. or you can do it yourself and just read the service manual.
firstly, this will take about 20 minutes for review -- this llink will help you get started , review the page and select the links that you can brief yourself and get to know your system better
http://support.dell.com/support/DPP/Index.aspx?c=us&cs=19&l=en&s=dhs&~ck=mn&SystemID=inspiron1564
this link is for service manual , specs, and set up guide
http://support.dell.com/support/edocs/systems/ins1564/en/index.htm
next , this link will give you driver updates.
i hope this serves you well !
Nov 05, 2010 | Dell F3534 Touchpad
Hi I have a dell inspiron 1525 and it always worked fine but now when I go to turn it on the start up repair comes up and runs. Then a window comes up that says "startup repair cannot repair this computer...
hi zachgibbons,
Try this, restart your pc then press f8 continuously, this will take you to safe mode. then after that go to start>run> type in msconfig (windows xp) , and start>search> type in msconfig (windows 7)
this will open up the system configuration under the general tab
select the diagnostic start up then apply>ok>restart
Hope this helps,
thx
banaple
Sep 02, 2010 | Dell Inspiron 1525 Notebook
Locks up on system boot, can boot into all the safemodes, couldn't fix the problem so reinstalled windows, got it to boot. Installed drivers one by one and the video card driver cause system lockup and...
Install the system again from scratch, install all drivers exept the graphics driver. Get the computer on the internet, right click on my computer, choose properties and goto device driver, click on the plus sign next to display adapters, right click on the device and choose to update driver use the internet option to install the drivers. It takes a few minutes so be patient. This should solve the freezing problem you have. Post back if you still have problems.
Feb 18, 2010 | Dell OptiPlex 760 MT Desktop Computer
Input textbox
so simple
my_txt.restrict = "A-Z 0-9";
my_txt.restrict = "A-Z";
whatever u can specify in it
Jun 25, 2008 | Macromedia Flash MX
Computers & Internet Logo
163 people viewed this question
Alun Cox
