Question about Gateway MX3228 Notebook
Battery and adapter problems
My adapter is not charging my battery. i got a new one and ive come to realize that there is physical damage. who can i go to to get it fixed?
  • irm9 May 28, 2008
    im sorry. i got a new adapter.
  • crabbypup May 11, 2010
    you got a new adapter or a new battery? please elaborate on the physical damage.
All you need is a new ac plug or board
Posted on Mar 25, 2009
    Scholar:
  • 106 Answers
If the laptop is old enough(or has been used enough) or has ever beed used to the point the laptop has shut itself off, but then you restartd it again, then your battery may be at fault. it may have gone into a coma(this actually does happen) and the battery is now completely dead. you will be unable to charge it and may have it explode if you do attempt to do so. you will need a new battery if that is the case. but if the problem is simpy with the connector, you will need a whole new laptop(or a new mother board, which is so expensive that you might as well get a new laptop) hope that helps.
Posted on May 28, 2008
My phone wont charge at allits not the cable ive tried several ive tried about everything
  • I am guessing that you have tried multiple wall power adapters. I am also assuming that you have tried several usb cables. If you have not tried a different wall power adapter and power cable go do this first.
  • If I were you I would remove the battery and hold the power button down for 30 seconds. Then replace the battery and back cover. Try charging the phone. If it works you are good to go.
  • If this does not work something major is wrong with your phone. It is most likely a loose charging port. A cell phone repair tech can fix this issue. I would see if your phone is under warranty first.
  • Make sure the cost of the repair is worth it if your phone is broken. Compare the cost of a repair to buying a new phone.
  • This could also be a bad battery, water damage, etc. A bad power port is the most likely cause of your problem.
May 25, 2015 | Samsung Galaxy Mega 6.3 Mobile Phone
Acer Aspire One battery only charges to about 23%
Sadly, the only other thing you can do is buy a new battery in this instance; or continue with what you're doing.
One of the things you could do, is do not charge the computer until it dies. Batteries have a life span, and this as you may or may not know is reduced by charging, or even worse damaged more by just keeping it plugged in, charging it when it's half way charged and such on so fourth. You can increase life span by just letting it die, and then recharging it. It sounds like your battery has got to a weak point from all that charge, unplug, fall, charge. I apologize for your battery.
Feb 23, 2013 | Acer Aspire One Netbook
Acer Aspire 5734z-4725 battery not charging
If your laptop computer runs normally on the ac adapter, but the battery won't charge, please try the following troubleshooting steps:
1) Remove the battery from the system.
2) Look at the connectors in the bay and on the battery for signs of physical damage.
3) Check the battery charge by pressing the status button or image on the battery near the LED's. Note: The lights indicate the current amount of charge on the battery. If all the LED's come on when you press on the butto, the battery is fully charged. If fewer lights are lit, then the battery is partially charged. If any lights flashm or blinkm there could be a problem with the battery.
4) Reinsert the battery; puch until it locks into place and the latch snaps back to the locked position.
http://www.chargerbuy.com/replacement-acer-aspire-5734-ac-adapter-19v-90w-cord.html
Feb 22, 2013 | Acer Aspire 5315 Notebook
Acer aspire zg5 battery not charging
If your laptop computer runs normally on your acer aspire one zg5 ac adapter, but the battery won't charge, please try the following troubleshooting steps:
Jan 09, 2013 | Computers & Internet
Non dell battery for dell inspiron 1515 not charging
Dec 09, 2012 | Dell Inspiron 1501 Notebook
Power issue
The Acer TravelMate 3000 is a laptop intended for business travellers who need the extra muscle of a fast processor and dual batteries. With mobile computers, it is very important to have not only a good rechargeable battery, but a solid power supply that needs very little maintenance to be able to keep operating. Losing a power supply or battery on a long trip can be extremely inconvenient, and there are several actions you can do to troubleshoot and prevent that situation.
Power Supply
The power supply (PS) is generally a solid piece of hardware not prone to damage or breakdown. The most common causes when a laptop is not receiving enough power from the PS is when one or more of the connections (wall, adapter or pc) gets loose. If your laptop informs you that it is not recieving enough power (or any) from the PS, make sure to manually inspect it to ensure the connections are solidly together and plugged in. While inspecting the cord, look for crimps or exposed wires that indicate serious damage. Crimps can typically be straightened out, but if there is physical damage to the cord, it must be replaced. Additionally you can check the adapter, the rectangular box, to see if it is overheating. As a precaution against fire, there are circuit breakers inside the adapter that will trip if the adapter begins to overheat. Normally, these circuits require you to unplug the power cables from the adapter, cord and wall before reassembling them in order to reset. On rare occasions, the circuit breaker will fail to trip and actually burn out from the inside; this requires replacing the entire PS.
Battery
The most common reason for power troubles on the Acer 3000 TravelMate, as well as most laptops, is a faulty battery. Batteries have a limited lifespan, and their ability to store a charge gradually reduces over time. Excessive use and overheating rapidly drain the battery and can often prematurely kill the battery. If you are having problems with a new battery or laptop charging or storing a charge, remove the battery and inspect it for physical damage. When inspecting the battery, pay careful attention for liquid, burn marks or pitting. If you discover any of these, carefully clean the battery and its connectors (copper ends) with a dry cloth. Once clean, reattach the battery and plug the PS back in to the laptop and wall. When possible, you should always use the PS instead of relying on the battery. This will prolong the battery's life.
I hope you find it very helpful. Thanks.
Aug 22, 2011 | Acer Aspire One PC Notebook
BATTERY UNABLE TO CHARGE, ALTHOUGH PHONE WORKS
Well, the white to pink dot is a sign of water in the phone. It is a moisture indicator and the first thing the repair fols look for so they can deny any claims.
They second thing is you can get an external battery charger for the razor. They run about 5 dollars and allow you to charge the battery seperate from the phone.
Razr V3 external battery charger
May 27, 2009 | LG VX9400 Cellular Phone
Charging problems
The AC adapter is only used as an alternate power source for the camera. It is not intended to charge the battery for the camera in any way. In order to charge the camera's lithium battery you will need the charger that is designed for that battery.
Apr 11, 2009 | Olympus Stylus 600 Digital Camera
Battery will not charge
Seems to be a motherboard issue either with the battery connection or the adapter port.
Nov 15, 2008 | Dell Inspiron 1501 Notebook
Sony PSP not charging
ok heres what you do 1. try blowing in the adapter slot 2. take out the mem. card & the battery for 24 hours 3. buy a new psp
Apr 30, 2007 | Sony PlayStation Portable (PSP) Console
Computers & Internet Logo
80 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
